Aspico Samba Member
Posted: Mon Nov 13, 2017 5:05 pm Post subject: Shocks? |
Bought this "off roaded" '73 Thing and decided to go with a complete new look (see rendering) I'm wondering if I can get it a bit lower than stock by simply replacing the shocks and tire size? It's currently raised a bit in the F&R, which I believe is from the 4 "coil over" shocks and off road tires that are installed (see pic)
I don't want to "slam it" so a new beam seams a bit extreme. Just want it an inch to an inch and half lower over all with the wheels and tires filling up the wheel wells/fenders. Is there a shock setup (KYB, Bilstein, Koni) and tire size (15" wheels) recommendation any of you Thing aficionados could suggest? Thanks in advance...
YDBD Samba Member
Joined: February 25, 2017 Posts: 891 Location: Bavaria, Germany
Posted: Mon Nov 13, 2017 9:42 pm Post subject: Re: Shocks? |
Yes swapping out the coil overs for standard oil shocks will most likely drop the ride height down. The KYB GR2's are gas shocks they have less push than the KYB Gas Adjusts do, but more than stock oil shocks and help with handling on the road. No idea on the exact change of ride height.
Tire size will also lower the ride height, you can go with a smaller profile tire. You didn't say what was on it, but if you have 185x15 SR, the S means the sidewall is 70% of the 185 (width) so they are about 130mm tall as the side wall. If you get the same width in a street tire 185x15 60 it would be 110 sidewall height dropping the ride height 10mm. 165x15 60 would drop around 20mm.
Hope this helps _________________ '56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing" |
74 Thing Samba Member
Posted: Tue Nov 14, 2017 8:09 am Post subject: Re: Shocks? |
Red Koni's ride real nice on a Thing. |
Aspico Samba Member
Posted: Tue Nov 14, 2017 1:07 pm Post subject: Re: Shocks? |
Thanks YDBD! For sure going to take your advice. Are the KYB GR2's the same as the KYB Excel G? Found this while searching for GR2's - "Both products are identical, except for the product name and paint color. KYB sells products throughout the world. Some part numbers fit vehicles from various countries that share the same chassis platform but, have different nameplates"
Don't want to make a mistake, plus they seem pretty inexpensive - $17.97 at Summit Racing as opposed to $37.97 for the KYB Gas-Adjust. |
YDBD Samba Member
Posted: Tue Nov 14, 2017 9:21 pm Post subject: Re: Shocks? |
That I don't know, I have the GR2s on my buggy.
I hope it works out. _________________ '56 pan Dune Buggy since '69
'67 bug
'64 baja
'60 dune buggy
Rev. Scott Samba Member
Joined: June 04, 2006 Posts: 770 Location: Philo, Ca.
Posted: Tue Nov 21, 2017 12:02 am Post subject: Re: Shocks? |
Gray KYB GR2's in front, red/white KYB's in back. good solid combo. _________________ "I haven't seen one of those since I was shootin' at 'em!" |
