mattscook27 Samba Member
Joined: August 12, 2017 Posts: 9 Location: fallbrook, ca
Posted: Sun Aug 20, 2017 3:59 pm Post subject: Pushing clutch wont allow me to change gears |
i have a 1961 vw beetle that i just recently got running. At first when i drove it i noticed it was hard to change gears but disregarded it. The other day was driving it and at first was able to get all 4 gears but as i kept driving it could only get reverse unless i spent a long time trying to go forward but only had first and second. eventually i lost all gears in the sense that my clutch doesn't seem to be working.i can start engine but pressing the clutch pedal doesnt allow me to change out of neutral(itll just grind). What could it be, it seems as my arm doesn't move that much when i press the pedal, or is it throw out bearings? doesnt make any sounds tho. |
vwjetboat Samba Member
Posted: Sun Aug 20, 2017 4:14 pm Post subject: Re: Pushing clutch wont allow me to change gears |
clutch cable stretching/ breaking ... have you tried adjusting it more ? look at cable to see if its coming apart ? |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Sun Aug 20, 2017 5:40 pm Post subject: Re: Pushing clutch wont allow me to change gears |
Check clutch pedal play. Should be about 3/8" to 3/4", personally like to shoot for just under 5/8". Need to check that now and then, especially when you just installed a new cable or clutch parts recently. Waiting till you can not shift means you put a lot more wear on the syncros in the transaxle, and clutch disc. You can cause so much heat from the clutch not fully disengaging that you can have the clutch pressure plate spring/s loose their springiness, leaving you with a clutch that slips anytime you try to drive up even a slight hill. So better to adjust for proper clutch pedal play before it becomes a much bigger problem.
_________________ In Stereo, Where Available! |
bluebus86 Banned
Posted: Sun Aug 20, 2017 6:00 pm Post subject: Re: Pushing clutch wont allow me to change gears |
the cable can stretch, and eventually break, the cables hook on the pedal shaft can also wear out, bend, and fail. often the symptom will be less and less clutch disengagement, until it completely fails. so check the cable and the hook on the pedal shaft that attached to the cable. either one of these failing will cause the symptom you discribe. when you put it back together with new parts, be sure to lube the cable and the hook to reduce wear.
good luck _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Sun Aug 20, 2017 7:29 pm Post subject: Re: Pushing clutch wont allow me to change gears |
i did all that and put another spacer on that rubber tube(blanking on what its called) tightened it until the play was about .8 inch,(measured with measuring tape). fixed the problem, but was driving it and clutch cable broke haha. But thanks so much for helping with the first issue. |
bluebus86 Banned
Posted: Sun Aug 20, 2017 8:42 pm Post subject: Re: Pushing clutch wont allow me to change gears |
mattscook27 wrote: |
Yup, they usually stretch before they break, when my pedal hook went, it slowly bent over days of clutch use, then it failed, I figured it was the cable, bought a new cable, started to pull out the old one, and noticed the failed pedal hook, back to the vw store for a hook and returned the new cable. all is good now for the second 330,000 miles on the hook. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Sun Aug 20, 2017 8:48 pm Post subject: Re: Pushing clutch wont allow me to change gears |
i did all that and put another spacer on that rubber tube(blanking on what its called) . |
Boden tube. Well fix the broken part and adjust the pedal. That should fix it, but do inspect everything to make sure it stays fixed. _________________ In Stereo, Where Available! |
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Sun Aug 20, 2017 10:22 pm Post subject: Re: Pushing clutch wont allow me to change gears |
And there's the long-shot problem, the pilot bearing built into the "gland nut" that secrures the flywheel to the crankshaft, it can go bad, and "grip" the input shaft, so the transaxle never sees a full release even if the clutch is working properly. I say "long shot" here since gland nut pilot bearings seldom go bad (compared to crank-mounted pilot bearings on type 4, late vanagon and inline-mounted watercooled engines)
The actual movement of the clutch arm really isn't that much, here's what I see on my 62:
_________________ Andy T.
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Mon Aug 21, 2017 6:49 am Post subject: Re: Pushing clutch wont allow me to change gears |
glutamodo wrote: |
Eric & Barb wrote: |
Check clutch pedal play. Should be about 3/8" to 3/4", personally like to shoot for just under 5/8" |
Nice pieces of information. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
