gtsmed Samba Member
Posted: Mon Aug 21, 2017 12:39 pm Post subject: turbo oil return |
I have a t04 turbo that I am installing on a2332 EFI. It will be going into a bug with hideaway headers. Can I drain my turbo oil into the opening where the fuel pump was removed. Or do have to return to the oil sump which means a bung welded to the side of the sump. |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Mon Aug 21, 2017 1:14 pm Post subject: Re: turbo oil return |
As I've understood it, you need to get the most flow, and frothy oil from the turbo has a lot of volume. You have to drain it into open air (like the fuel pump opening), and never below the sump line, otherwise the oil will impede flow.
No turbo expert here, by any means.
Someone will chime in that they drain into the sump, and everything is fine, but I still think it's a bad idea, in the long run. |
gprudenciop Samba Member
Joined: July 06, 2008 Posts: 606 Location: portland or
Posted: Mon Aug 21, 2017 1:26 pm Post subject: Re: turbo oil return |
If you are going to run a hideaway header the easiest thing to do is get a bugpack thinline sump and weld a bung to the side of it.run the largest return hose possible. _________________ Never look down at anybody unless you are helping them up..
Loaning someone your strength instead of reminding them of their weakness = kindness.. |
theDrew Samba Member
Posted: Tue Aug 22, 2017 9:51 am Post subject: Re: turbo oil return |
i welded a an-10 bung on the side of my sump.
key is making sure its downhill
_________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
1985 Vanagon Campmobile w/ 2005 EJ25 |
Posted: Tue Aug 22, 2017 10:24 am Post subject: Re: turbo oil return |
The best way to route the drain is to use one of these.
https://www.cbperformance.com/product-p/7627.htm
Than use a 7 inch piece of pipe that clears the exhaust pipes add some fire sleeve, an fitting on the end and a small an hose to the sump. I wish I had taken a picture but I didnt. It barely clears and you don't have excess hose. Forgot to add you can tap hole for 5/8 threads. _________________ Never look down at anybody unless you are helping them up..
Bugsy61 Samba Member
Joined: March 20, 2011 Posts: 256 Location: Peoria, Illinois
Posted: Tue Aug 22, 2017 8:31 pm Post subject: Re: turbo oil return |
I've been draining mine into the fuel pump opening since 2001. Works great. |
Posted: Wed Aug 23, 2017 12:06 am Post subject: Re: turbo oil return |
Bugsy61 wrote: |
I would love to see this!! Do you have any pictures of you defying the laws of gravity with a hideaway header? ? _________________ Never look down at anybody unless you are helping them up..
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2335 Location: Mount Airy, Maryland
Posted: Wed Aug 23, 2017 11:57 am Post subject: Re: turbo oil return |
Oil needs to flow down hill so Baja header can use the fuel pump location and the hideaway must use a sump or Type 3 Dip stick location. _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
kangaboy Samba Member
Joined: August 28, 2010 Posts: 1063 Location: St. Louis, Mo
Posted: Wed Aug 23, 2017 1:39 pm Post subject: Re: turbo oil return |
FreeBug wrote: |
Been flowing mine from the hideaway header to the sump for a while. Never had a problem. As stated above, the key is to have it sloping down hill. That, and a big drain tube (5/8" for me) _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote: |
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out |
Posted: Wed Aug 23, 2017 6:52 pm Post subject: Re: turbo oil return |
Yup, I have a baja header. Sorry. I missed that he had a hide away header. |
