rustednuggs Samba Member
Joined: June 29, 2008 Posts: 508 Location: Summerdale
Posted: Mon Aug 21, 2017 7:04 pm Post subject: Jump Seat |
Hello - I am looking for a jump seat and how they install into a 1980 Vanagon? If all at all possible? I was just told about these a few days ago. We have five in our family, so I need to add another seat or another seatbelt.
Appreciate it in advance!
Rustednuggs |
scottz Samba Member
Joined: April 13, 2008 Posts: 477 Location: Bellingham, WA
Posted: Mon Aug 21, 2017 7:49 pm Post subject: Re: Jump Seat |
Here is a search with a bunch of info on jump seats. You would have to source a used one. They do require some welding to install properly and require a mounting bracket, don't forget the bracket!
https://www.thesamba.com/vw/forum/search.php?searc...=titleonly |
Posted: Tue Aug 22, 2017 3:42 am Post subject: Re: Jump Seat |
Thanks for the reply and link. Is a jump seat the special mounting bracket, with just a front seat from a vanagon, or is it a "special" size seat or something?
Thanks
Rustednuggs |
OddN Samba Member
Joined: August 19, 2010 Posts: 690 Location: Northern Norway
Posted: Tue Aug 22, 2017 4:44 am Post subject: Re: Jump Seat |
rustednuggs wrote: |
Thanks
Rustednuggs |
It is a special seat that shares some parts (like the seat back) with the front seats.
So if you get a jump seat with torn fabric, you could replace the back with a front seat back without too much trouble. So you can then have a jump seat with arm rests if you want.
Also the seat bottom has a somewhat similar size as the front seat. The front seat bottom is a little wider but fits in the frame of the jump seat as long as you use both foam an fabric from the same seat. _________________ 1991 VW Multivan syncro 1,9 TD |
Posted: Tue Aug 22, 2017 4:48 am Post subject: Re: Jump Seat |
Thanks that helps, because the forums are all over the place. A Carot and or a jump seat.
So I have an 80 vanagon with a complete parts vanagon with seats. Sounds like I can use that but the seats are in great shape. Looks like I need the mounting bracket.
TY
Rustednuggs |
