rayroc Samba Member
Posted: Mon Aug 21, 2017 7:34 pm Post subject: anybody change their crank sunroof to fully manual? |
wondering if anyone has a fully manual sunroof out there perhaps circumventing some obsolete parts or isn't it even a possibility? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51117 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Aug 21, 2017 7:45 pm Post subject: Re: anybody change their crank sunroof to fully manual? |
I had a bus with broken cables and a wooden wedge to keep the back up or jam it open, worked OK unless the wedge came loose and you pood a little when stepping on the brake brought on a woooOOOSH, SLAM! followed by a similar occurence when you drove away from a stop.
Maybe some sort of strap and snaps to keep it open or closed in various positions would have helped?, I just fixed it properly and enjoyed a functional crank open roof, I miss that bus. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7537 Location: Santa Cruz
Posted: Mon Aug 21, 2017 10:53 pm Post subject: Re: anybody change their crank sunroof to fully manual? |
busdaddy wrote: |
worked OK unless the wedge came loose and you pood a little when stepping on the brake brought on a woooOOOSH, SLAM! followed by a similar occurence when you drove away from a stop. . |
Priceless... _________________ Bus Motor Build
What’s That Noise?!? |
SGKent Samba Member
Posted: Tue Aug 22, 2017 7:20 am Post subject: Re: anybody change their crank sunroof to fully manual? |
rayroc wrote: |
just pull the crank handle off, pull the two screws holding the gear and pull the gear out. Use a small wooden wedge to start to open it and you can push it back. Pretty much all the parts are available these days new or used. The biggest obstacle to it working right is the owner's wallet. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Tcash Samba Member
