Vanagon Nut Samba Member
Posted: Tue Aug 22, 2017 6:15 pm Post subject: Instrument light bulb holder assembly & the metal piece |
Hi all.
I'm sure the answer is here somewhere but I can't find it.
On the instrument cluster white plastic bulb holder, does the metal piece position like this? ( I think this is correct)
Is that piece simply a shim to keep the plastic piece from slipping?
edit: yes. This is correct.
_________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN
spitsnrovers Samba Member
Joined: December 17, 2005 Posts: 925 Location: Calgary, Canada
Posted: Wed Aug 23, 2017 7:08 am Post subject: Re: Instrument light bulb holder metal piece |
I can not make out what that piece is, or where it is supposed to go.
How does it relate to "Instrument Bulb Holder"? _________________ '88 VW Westfalia
'75 Triumph Spitfire 1500 |
cmayna Samba Member
Joined: August 18, 2014 Posts: 1148 Location: SF Bay area, CA
Posted: Wed Aug 23, 2017 7:36 am Post subject: Re: Instrument light bulb holder metal piece |
It's an upper reflector. Yes for the top image. _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
dsdunbar Samba Member
Joined: December 19, 2014 Posts: 564 Location: Crozet VA
Posted: Wed Aug 23, 2017 8:52 am Post subject: Re: Instrument light bulb holder metal piece |
djkeev wrote: |
Instrument cluster.....
Dave, you're awesome. Way to go above and beyond to help someone out! _________________ '89 2WD Westy "Grey Goose" - Manual 4spd
Crozet VA
Vanaru EJ25, Peloquin |
Posted: Wed Aug 23, 2017 10:46 am Post subject: Re: Instrument light bulb holder assembly & the metal piece |
cmayna: thanks.
David: thanks too!
That detail on the hinged bit was something I was unaware of.
After doing some custom wiring on the ribbon, one bulb was acting up. Figured I'd check the white plastic to make sure it hadn't fallen apart at bulb hole. Otherwise no real reason to remove that white plastic part. But I'm sure I'm not the only one to have done so!
VE7TBN |
kamzcab86 Samba Moderator
Posted: Fri Aug 25, 2017 4:47 pm Post subject: Re: Instrument light bulb holder assembly & the metal piece |
When I put LEDs in, I discovered one of the reflectors had fallen out (making the incandescent even worse than it was). Both, however, looked like crap, so I polished 'em up for even better reflection:
(Bottom: before; top: after)
_________________ ~Kamz
2016 Golf GTI S
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Fri Aug 25, 2017 5:54 pm Post subject: Re: Instrument light bulb holder assembly & the metal piece |
Glad you started this thread. What exactly is the function of this piece? Since they were all painted black from the factory it can't be a reflector. Perhaps a shield to avoid glare. Why wasn't it a reflective surface to improve the lighting? Only the shadow knows. |
