timped2006 Samba Member
Joined: January 14, 2014 Posts: 102 Location: Battle Ground, WA
Posted: Tue Aug 22, 2017 9:29 pm Post subject: Where to LOCATE the transmission in a '71 Bus? |
Long story short, I'm doing an EJ22 swap in the '71. Just wondering if anyone can tell me how big the space should be between the top of the 002 tranny and the bottom of the firewall. I want the transmission to be in the right spot when I bolt up the new motor. Hope that makes sense. Thanks! |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Tue Aug 22, 2017 9:46 pm Post subject: Re: Where to LOCATE the transmission in a '71 Bus? |
I can't answer your question directly, but suggest bolting transmission up to new engine, and roll it up under there to check and modify clearances. |
Posted: Tue Aug 22, 2017 9:50 pm Post subject: Re: Where to LOCATE the transmission in a '71 Bus? |
I see what you mean. I guess I'm just wondering if there's an exact place the trans is supposed to sit for proper shifting or is it just a matter of clearance? |
Posted: Tue Aug 22, 2017 10:52 pm Post subject: Re: Where to LOCATE the transmission in a '71 Bus? |
Well, IIRC there is a forward mount... and then there's a carrier that mounts with two long bolts above the starter, roughly 11 O'clock and 1 O'clock. These mounting locations pretty much dictate where the transmission lives. Seems kind of unwieldy to try to get placement measurements because the body of the bus and the case of the transmission don't really offer a bunch of nice flat or square places to set your measuring tools up, but if you took a bunch of time you could probably crawl under there and come up with something.
Just seems easier to shove the mass under there on a dolly and start modifying clearances as needed. Sort of a tedious process, but likely more efficient in the end. But you're not the first person to do this, so I imagine there is some more information out there that is waiting to be found. Sorry I could not offer anything better. |
Posted: Tue Aug 22, 2017 11:54 pm Post subject: Re: Where to LOCATE the transmission in a '71 Bus? |
I appreciate your input. Of course, the early Bays don't have a transmission crossmember like the late Bays. I'll probably just have to see where everything falls and make it work. |
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1086 Location: wherever my baywindow takes me.
Posted: Wed Aug 23, 2017 7:42 am Post subject: Re: Where to LOCATE the transmission in a '71 Bus? |
Don't be surprised after you "see where everything falls" that it already works and you don't have to "make it" do a thing. It's a "71 bus. Unlike the 72 and later there is not much adjustment to the drive train package. Fractions of an inch if any.
Just make sure that once the shift linkage is hooked up that the shift rod does not rub on the shift rod tube and the linkage moves freely. that's about it. Otherwise stop obsessing and bolt it in! |
lightice Samba Member
Posted: Wed Aug 23, 2017 7:53 am Post subject: Re: Where to LOCATE the transmission in a '71 Bus? |
Wouldn't it be more important that the CV joints are lined up properly to the rear hubs?
Just asking because I may potentially face this as well. |
Posted: Wed Aug 23, 2017 8:40 am Post subject: Re: Where to LOCATE the transmission in a '71 Bus? |
lightice wrote: |
Without getting into why. The short answer would be... Nope! |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Thu Aug 24, 2017 8:06 am Post subject: Re: Where to LOCATE the transmission in a '71 Bus? |
_________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Fri Sep 15, 2017 1:18 pm Post subject: Re: Where to LOCATE the transmission in a '71 Bus? |
Thanks! |
