tds3pete Samba Member
Joined: April 04, 2004 Posts: 914 Location: Seattle, WA
Posted: Wed Aug 23, 2017 3:14 pm Post subject: EVC cracked top repair option |
After a catastrophic failure resulting in two cracks, due to driving from a warm garage into below zero in the Wyoming night, we tried the plastic weld gig with no luck. It kept failing. Here is what I expect to be a permanent solution :
The straps are 5" wide .062" aluminum in three pieces, cut to fit. The bonding agent is 3M 5200 fast dry. The paint is VW R902 Arctic white with with clear coat. The ends were installed all at once and allowed to cure, then we cut the cross pieces to fit and installed the next day.
For the record, we have two 95 EVC's in the family. This one is not mine. Hopefully I will not have to do this again on mine. _________________ '58 Westy camper-come and gone
'73 Westy-bought new in Holland,now gone
'86 Syncro weekender-come and gone
'79 Westy...Oscar
'95 Eurovan Camper/5 spd...Marsha Mellow
Zeitgeist 13 Samba Member
Posted: Wed Aug 23, 2017 3:22 pm Post subject: Re: EVC top repair option |
Really nice work! Any chance you could scan the profile of that buck and post it up? I'll bet there are folks here who could really benefit from having that at the ready...for the inevitable. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Wed Aug 23, 2017 3:25 pm Post subject: Re: EVC top repair option |
Zeitgeist 13 wrote: |
Really nice work! Any chance you could scan the profile of that buck and post it up? I'll bet there are folks here who could really benefit from having that at the ready...for the inevitable. |
I could but the profile varies end-to end as well as the width of the top. It is pretty easy make a cardboard female template at your desired location and then trace it onto plywood for the sheet metal shop to use as a form. _________________ '58 Westy camper-come and gone
'79 Westy...Oscar
'95 Eurovan Camper/5 spd...Marsha Mellow |
Posted: Wed Aug 23, 2017 3:27 pm Post subject: Re: EVC top repair option |
Ah, gotcha. That makes sense. _________________ Casey--
y u rune klassik? |
eurovank Samba Member
Posted: Sun Aug 27, 2017 6:09 pm Post subject: Re: EVC cracked top repair option |
Wow. Good work! Any pics of the cracks before they were fixed? Were they transverse across the top and pretty straight? |
Posted: Mon Aug 28, 2017 5:21 pm Post subject: Re: EVC cracked top repair option |
eurovank wrote: |
I don't have pix. One crack was side to side shifting about 2-3" fore and aft. The other crack went from one side about half way across, shifting about 2" fore and aft.
We chose to wrap the half-way crack all the way across for appearance and added insurance. _________________ '58 Westy camper-come and gone
'79 Westy...Oscar
