Country buggy transmission
lightice
lightice is offline
PostPosted: Wed Aug 23, 2017 5:02 pm    Post subject: Country buggy transmission Reply with quote
Hi, anyone has any experience with the country buggy transmission?
I came into possession of a H case transmission.
It has large nut RGBs.
I have checked on thesamba for the owner's manual and only found the philippine version, but that didn't include the gear ratios in them.
PostPosted: Wed Aug 23, 2017 10:44 pm    Post subject: Re: Country buggy transmission Reply with quote
I don't know if the ratios are the same as a Bus large nut transmission but this dedicated transmission thread may help you
https://www.thesamba.com/vw/forum/viewtopic.php?t=658674
lightice
lightice is offline
PostPosted: Thu Aug 24, 2017 8:33 pm    Post subject: Re: Country buggy transmission Reply with quote
Hi Everett, I've checked through that thread.
The problem is the country buggy was produced after 67, while it used the large nut.
PostPosted: Thu Aug 24, 2017 10:35 pm    Post subject: Re: Country buggy transmission Reply with quote
Does this brochure help?
https://www.thesamba.com/vw/archives/lit/68countrybuggy.php
Specifically
lightice
lightice is offline
PostPosted: Fri Aug 25, 2017 6:30 am    Post subject: Re: Country buggy transmission Reply with quote
I did glance through the material, but totally missed out on that.
Thanks!
Guess some who advised were wrong in that not all the gears were the same as the H case buses ones.
The third gear is different.
Did VW ever had a fine tooth 0.82?
Or did they retain the 0.82 coarse tooth?
Wonder what's the 1.26 one. Question
lightice
lightice is offline
PostPosted: Sun Aug 27, 2017 9:24 pm    Post subject: Re: Country buggy transmission Reply with quote
That's a bummer, I was hoping it was the longer 1.22 so I could have a 'stock' gearing on my bus.
lightice
lightice is offline
PostPosted: Sat Sep 02, 2017 11:40 pm    Post subject: Re: Country buggy transmission Reply with quote
Coming back to the country buggy transmission.
Anyone has any parts diagram?
The reduction boxes look distinctively different from a split bus reduction box.
lightice
lightice is offline
PostPosted: Mon Sep 04, 2017 10:58 pm    Post subject: Re: Country buggy transmission Reply with quote
Someone sent me the diagram of the reduction boxes, but not the transmission.
He also quoted the transmission parts as having:
Gear Train (3rd Speed) - 113 311 275A
Gear Train (4th Speed) - 113 311 341
Which is contradictory to the sales brochure.
if search the p/n the third would be a 1.22 and forth would be a 0.89.
nbturbo
nbturbo is offline
PostPosted: Thu Oct 05, 2017 11:15 pm    Post subject: Re: Country buggy transmission Reply with quote
I came by a C/B front end and transmission complete many years ago.I have decided to overhaul the lot in readiness for a project.I have discovered that Holden Commodore front disc rotors fit straight onto the C/B spindles,so have had some adapters made to mount the Holden calipers.I have bought a full set of new bearings and seals to make it happen.I have located a double sided IRS gearbox with 4.12 diff and having that converted to swing axle and crown wheel turned over.I will do a disc brake conversion on the reduction boxes with the 5x120 stud pattern.This will give good highway speed with some big wheels on the back.
