72 T3 or 71 Super trans in a 74 thing
sharkskinman
Lateral Lunatic
sharkskinman is offline
PostPosted: Thu Aug 24, 2017 11:34 pm    Post subject: 72 T3 or 71 Super trans in a 74 thing Reply with quote
Gear ratios ?
Is one better than the other for the thing?
Mine pops 1st gear
I have adjusted plate and cable and checked the shifter linkage (can be replaced but ok enuff for now)
Checked fluid
If I hold it In place I can feel it popping regularly but every half second
Friend might have a thing trans but I have the above 2 cars if I need them
T3 is Not currently in use and $$ wise I have less in it
But both cars are worth engine n trans at least..
Having trouble selling super so thinking just pull the motor n trans n sell body n such cheap
71 Supervert..72 rusty fasty.. 74 Mexi Safari (thing)..65 C10
Me of Course wrote:
Extremity is relative to how far your willing to jump
Ward Cleaver wrote:
You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards
PS3 Black Ops "NKOGNEATO"
sharkskinman
Lateral Lunatic
PostPosted: Sat Aug 26, 2017 1:21 pm    Post subject: Re: 72 T3 or 71 Super trans in a 74 thing Reply with quote
NY thing
NY thing is offline
PostPosted: Sat Aug 26, 2017 1:48 pm    Post subject: Re: 72 T3 or 71 Super trans in a 74 thing Reply with quote
If I remember correctly, I put a super tranny into my thing with the only difference in gears being the thing had 4.12 and the super had 3.88 r/p.
1-4 was the same. This is referring to AT and AV trannys
The super tranny may also need a nose cone conversion mount.
With the new 3.88 gear, I am able to go to a higher too speed in each gear, but it takes longer to get there. That's where a bigger motor comes in.
sharkskinman
Lateral Lunatic
PostPosted: Sun Aug 27, 2017 5:14 pm    Post subject: Re: 72 T3 or 71 Super trans in a 74 thing Reply with quote
my super altho im going to check the number on it
'67-'72 (AH) (a) 3.88 3.80 2.06 1.26 0.89 4.125 3.67
the 72 fasty i have... depending on trans number
'71-'72 3.61 3.80 2.06 1.26 0.88 3.875 3.41
'72-'77 3.79 3.78 2.06 1.26 3.875
so im to believe that putting my 72 fasty trans in it would be the best for all around?
i drive T3s 70-75 all the time
thing and a square bout the same weight too
and my 72 has a complete D-Jet F.I. engine in it too..Hmmmmm
Bruce
Bruce is offline
PostPosted: Wed Aug 30, 2017 11:00 pm    Post subject: Re: 72 T3 or 71 Super trans in a 74 thing Reply with quote
Type 3s never came with a 3.88 R&P in the trans. Only 4.12.
sharkskinman
Lateral Lunatic
PostPosted: Tue Sep 05, 2017 2:13 am    Post subject: Re: 72 T3 or 71 Super trans in a 74 thing Reply with quote
so will the T3 trans fit in and bolt up properly?
the Thing nose cone IS a 311 number
have wed and thurs off so im trying to get that swapped if it will work
and if i can get a seal kit for it quickly
Bruce
Bruce is offline
PostPosted: Sat Sep 09, 2017 1:02 pm    Post subject: Re: 72 T3 or 71 Super trans in a 74 thing Reply with quote
The Type 3 hockey stick is different. Use the original one from your Thing trans.
