mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Wed Apr 18, 2018 12:30 pm Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
Kevin Sharpe wrote: |
germanx wrote: |
And no matter how many people will ask the moderator to stop me from spreading bad mood, a state of the art Diesel engine still is by far causing the least damage considering the full resource cycle, not only the middle part of driving the car. |
I'm happy to debate why I think you're wrong and provide evidence to back my assertion... however, I won't derail my build thread to do that... feel free to start a topic on electric transport in the "General/Chat" forum... that's what we did on the SSVC forum |
looks like you are building from a recycled Tesla and a recycled VW bus. No reason to not do that, power generation will be cleaner in the future, why wait?
keep on keeping on _________________ regards
Uli
Kevin Sharpe Samba Member
Joined: August 28, 2017 Posts: 535 Location: IRL & US
Posted: Thu Apr 19, 2018 10:53 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
fan/rad support bracket in place... still to come are the side panels that will seal the 'cooling cabinet' and some splash protection for water thrown up by the rear wheels (we've taken the precaution of using IP67 fans and will use boots on the light fittings).
The basic idea is that cooling air will be sucked in from the slots on the side of the bus, travel down through the radiator (not fitted in the photos), through the fan, and finally exit via the hole behind the rear wheel. At this time we've no real idea how much/little cooling the electrical systems require so this is an experiment to say the least
Posted: Tue Apr 24, 2018 7:30 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
3D printing the prototype water pump mounting brackets... another great example of open source and design sharing
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Tue Apr 24, 2018 11:20 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
Will that become the final mount or do you have to have it made in metal? |
Posted: Tue Apr 24, 2018 2:54 pm Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
BarryL wrote: |
This prototype was printed in PETG (an 'improved' ABS) which is both cheap and quick to print. I expected to have some tolerance issues because the design is 'tight' but it all worked out fine.
I will now have some printed in Nylon and run those in the bus. It would be easy to have them printed (or CNC'ed) in Aluminium or Steel but that's really only economic when you have volumes of 10 or more. |
Posted: Wed Apr 25, 2018 3:01 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
Zero EV (here) have just announced a LSD for the small Tesla drive unit... not something I will fit initially but with ~350HP available it might be needed when I step on the gas at the drag strip
Posted: Tue May 01, 2018 11:48 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
Frame for twin chargers and HVJB ready for mounting under the rear seat
Posted: Wed May 02, 2018 3:20 pm Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
Some great progress with the open source motor controller... here's the large Tesla drive unit in a BMW 8 Series conversion
Posted: Fri May 04, 2018 3:58 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
Change of plan on the cooling... I found a couple of CSF Drag Race Radiators which at 14.5" x 10" x 3.5" (~6" with fan fitted) are a good fit for the 'cooling cabinets'
Will be a shame to have such beautiful items out of sight
http://csfrace.com/the-king-cooler/
coolerthanelvis Samba Member
Joined: June 30, 2003 Posts: 924 Location: San Diego, CA
Posted: Fri May 04, 2018 10:05 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
Your prop rod is on backwards. The "prongs" should curve to the right and be hidden behind the bracket when the decklid is fully open. Also prevents injury when messing around in the engine compartment. _________________ Shawn
SV2s member #420
'68 Westy
"Do or do not, there is no try."
-Silent Bob |
Posted: Fri May 04, 2018 10:20 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
coolerthanelvis wrote: |
Your prop rod is on backwards. |
Many thanks, I'll get that changed |
BarryL Samba Member
Posted: Fri May 04, 2018 10:25 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
Come on Elvis...you of all people should know if he flips it that will reverse the polarity. |
Posted: Sun May 06, 2018 12:59 pm Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
BarryL wrote: |
LOL. Then he will have 4 reverse gears and one forward! _________________ Shawn
SV2s member #420
'68 Westy
-Silent Bob |
Posted: Sun May 06, 2018 1:45 pm Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
BarryL wrote: |
LOL. Then he will have 4 reverse gears and one forward! |
Luckily this is not an issue with a tesla drive unit _________________ regards
Uli
Posted: Thu May 10, 2018 8:37 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
I'm reusing the steering wheel/column and switchgear from a 1980's Rolls-Royce. Includes 'gear' selector and cruise control for the Tesla drive unit and supports wide range of steering wheels including heated
busterbow Samba Member
Posted: Fri Jun 01, 2018 2:19 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
Any more news |
Posted: Fri Jun 01, 2018 6:09 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
busterbow wrote: |
Any more news |
Unfortunately I've been busy helping with other projects
