nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Wed Dec 13, 2017 7:49 pm Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
Cool Stuff! how's the bus coming? |
aggri1 Samba Member
Joined: February 17, 2006 Posts: 380 Location: Melbourne, Australia
Posted: Wed Dec 13, 2017 11:00 pm Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
Wow, I'm debilitatingly interested, especially if the main bits become available commercially. Have a '67 modified somewhat by previous owner (nothing serious) just waiting for such an upgrade... Definitely will be following this thread with zealous interest. |
Kevin Sharpe Samba Member
Joined: August 28, 2017 Posts: 535 Location: IRL & US
Posted: Fri Dec 15, 2017 8:48 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
nlorntson wrote: |
The company making the production IRS with the Tesla motor mount are behind schedule and we've decided to proceed with our modified Red 9 Design IRS for now. I hope to record a new video in the next couple of weeks showing progress to date |
aggri1 wrote: |
Great! It's a fun project for sure |
Posted: Fri Dec 15, 2017 12:21 pm Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
I'm curious as to the future purpose of the grear shift? Will you still be able to use it as a Forward or Reverse selector? |
edgood1 Samba Member
Joined: September 30, 2004 Posts: 2049 Location: Plymouth, MA
Posted: Fri Dec 15, 2017 12:35 pm Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
nlorntson wrote: |
you could make it the throttle!
Using the tesla components is awesome. I just wish they were more readily available and cheaper. I'm still looking into finding a salvaged Nissan Leaf and transplanting the drivetrain over to the bus. _________________ 1987 Syncro Westfalia powered by Subaru
'65 Westfalia |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Fri Dec 15, 2017 12:40 pm Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
good point, probably just needs a nice block-off plate.
Might as well delete the emergency brake lever. Expecting that to be electronic as well?
Clutch pedal?
somebody could come up with a real minimalist design for the front.
digital gauge, digital key fob, no ignition keys, etc _________________ regards
Uli
Posted: Sat Dec 16, 2017 6:39 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
nlorntson wrote: |
Sure, if you wanted you could rig up a switch to use the existing gear selector... I plan to remove the gear selector to gain some extra space at the front... I'll probably use a selector on the steering column. |
Posted: Sat Dec 16, 2017 6:43 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
edgood1 wrote: |
I'm still looking into finding a salvaged Nissan Leaf and transplanting the drivetrain over to the bus. |
A friend of mine recently purchased a 2014 low mileage Leaf drivetrain for 600 Euros (~700 USD) and while not as integrated as the Tesla drivetrain it can produce ~300HP with an inverter upgrade (the Tesla open source inverter design that I'm using will soon support the Leaf). |
Posted: Sat Dec 16, 2017 6:55 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
mandraks wrote: |
Might as well delete the emergency brake lever. Expecting that to be electronic as well? |
The Tesla donor cars use electric parking locks on each wheel. These are integrated into the brake callipers which are rather large for the bus and therefore I will use a traditional mechanical brake.
mandraks wrote: |
Clutch pedal? |
No clutch required
mandraks wrote: |
somebody could come up with a real minimalist design for the front. digital gauge, digital key fob, no ignition keys, etc |
Absolutely, almost anything is possible... I'm using the traditional looking gauges with electric sensors for the primary interface but will have a small tablet installed on the overhead ventilation box for displaying detailed system data, GPS, etc. |
Posted: Sat Dec 16, 2017 10:44 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
Busy couple of days installing the Red 9 front suspension upgrade
Posted: Mon Dec 18, 2017 12:09 pm Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
Experimenting with the connector that supports both rapid AC and DC charging
Posted: Wed Dec 20, 2017 11:26 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
We've been running some heating/cooling tests on the Tesla battery modules
Posted: Wed Dec 20, 2017 11:31 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
So for perspective, what are we looking at there in terms of number of modules and physical dimensions and weight? |
Posted: Thu Dec 21, 2017 4:28 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
3D mockup of proposed Tesla module layout for the two battery boxes. One box (8 modules) will be mounted under the floor between the chassis rails, and another (6 modules) above the motor where the petrol tank was located
I had originally planned to build a new chassis that would accommodate all batteries under the floor. However, battery technology is improving so quickly that I decided to shoe horn the batteries in and revisit in a few years when they are half the size/weight.
Posted: Thu Dec 21, 2017 5:05 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
nlorntson wrote: |
Each Tesla module is 12" x 3" x 27" and weighs 55lbs. I'm installing 14 which will give me a range of ~370 miles.
Today the battery will be big and heavy if you want long range. However, the battery in the 2020 Tesla Roadster (here) will be half the size and (presumably) half the weight. In the future I will upgrade the batteries in the bus as the technology improves... this will simply involve replacing one battery box with another because they are designed to bolt in |
Posted: Sat Dec 23, 2017 7:24 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
Rapid AC/DC charging connector installed
Posted: Wed Jan 03, 2018 9:53 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
Lots of experiments with the battery boxes and I have decided to reduce the number of Tesla battery modules in the rear to four and save some weight.
In total the twelve Tesla modules will give me 63kWh (P85 modules) or 75kWh (P100 modules) which should be plenty when combined with rapid charging
Posted: Wed Jan 03, 2018 10:49 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
Back of the bus with IRS upgrade... almost ready to install the Tesla drive unit and rear battery box
Posted: Wed Jan 03, 2018 10:52 am Post subject: Re: ICE Breaker - converting a 1967 split to electric drive |
You've undercoated the bus I see. How will you protect the battery box from the elements and heat? |
