TheVintageVw Samba Member
Joined: July 19, 2004 Posts: 654 Location: Porter Ranch California
Posted: Tue Aug 29, 2017 12:54 pm Post subject: 1966 13 Window Deluxe OG paint build. |
Picked up this 13 window from a fellow samba member who picked it up from a fellow samba member
Don't know much about the history other than its a Texas bus. Bones are dry just has the typical rust on the body.
I think I've figured out what isn't original but I would like you guys to critique these photos and tell me what you guys see.
Basically the good the bad and the ugly. I will use this as my build thread as well.
I'd like to address some of the rust but will keep it as original as I can. Will not be painting the bus. Just some elbow grease to make it look better.
Engine number: H538857 I think this is the original 1500? Someone correct me.
IMG_5928 by Narbie, on Flickr
IMG_5929 by Narbie, on Flickr
IMG_5932 by Narbie, on Flickr
IMG_5934 by Narbie, on Flickr
IMG_5936 by Narbie, on Flickr
IMG_5937 by Narbie, on Flickr
IMG_5939 by Narbie, on Flickr
IMG_5940 by Narbie, on Flickr
IMG_5941 by Narbie, on Flickr
IMG_5942 by Narbie, on Flickr
IMG_5944 by Narbie, on Flickr
IMG_5945 by Narbie, on Flickr
IMG_5946 by Narbie, on Flickr
IMG_5947 by Narbie, on Flickr
IMG_5949 by Narbie, on Flickr
IMG_5950 by Narbie, on Flickr
Is this some type of electrical heater?
Untitled by Narbie, on Flickr
Last edited by TheVintageVw on Tue Aug 29, 2017 4:54 pm; edited 3 times in total |
Posted: Tue Aug 29, 2017 3:19 pm Post subject: Re: 1966 13 Window Deluxe OG color |
First things first. Get rid of those ugly tail lights
Untitled by Narbie, on Flickr |
Posted: Wed Aug 30, 2017 10:17 am Post subject: Re: 1966 13 Window Deluxe OG paint build. |
hi |
Pinetops Samba Member
Posted: Wed Aug 30, 2017 10:42 am Post subject: Re: 1966 13 Window Deluxe OG paint build. |
I see a good bus to start with, congratulations. _________________ "A rolling bus gathers no rust." |
Posted: Wed Aug 30, 2017 11:42 am Post subject: Re: 1966 13 Window Deluxe OG paint build. |
Pinetops wrote: |
The rear seats are from a bay window bus. |
what about the fronts? any idea if they are correct? |
Posted: Wed Aug 30, 2017 6:36 pm Post subject: Re: 1966 13 Window Deluxe OG paint build. |
Looks like original front seats, recovered of course. _________________ "A rolling bus gathers no rust." |
EverettB Administrator
Joined: April 11, 2000 Posts: 69807 Location: Phoenix Metro
Posted: Wed Aug 30, 2017 10:38 pm Post subject: Re: 1966 13 Window Deluxe OG paint build. |
Excuse the delay in answering, I saw you post and thought nice Bus but glossed over your question below.
halchka99 wrote: |
Do you mean H0538857?
Otherwise it appears you are missing a digit.
H0538857 looks like a 12/66 Beetle engine
If it's H538857X with X being another digit, that's a late 1968 Beetle engine _________________ How to Post Photos
Posted: Thu Aug 31, 2017 8:39 am Post subject: Re: 1966 13 Window Deluxe OG paint build. |
EverettB wrote: |
halchka99 wrote: |
If it's H538857X with X being another digit, that's a late 1968 Beetle engine |
Here is the engine. I cant see an 0?
Posted: Thu Aug 31, 2017 9:00 am Post subject: Re: 1966 13 Window Deluxe OG paint build. |
Yes, thanks for the pic.
The second part of my message above applies here because you forgot the digit at the end.
It's H5388573
EverettB wrote: |
Your fan belt looks like it has some wear in that pic? _________________ How to Post Photos
Posted: Thu Aug 31, 2017 9:07 am Post subject: Re: 1966 13 Window Deluxe OG paint build. |
EverettB wrote: |
It's H5388573
EverettB wrote: |
Your fan belt looks like it has some wear in that pic? |
Thanks Everett i think im going blind
Yeah i'll replace the fan belt along with that nasty muffler. Can i use a 1500cc bus muffler? Which would work with that engine?
Thanks as always for your help. |
Posted: Thu Aug 31, 2017 9:38 am Post subject: Re: 1966 13 Window Deluxe OG paint build. |
thank you!
Front seats look correct? i know the rears are from a bay. |
Posted: Thu Aug 31, 2017 2:45 pm Post subject: Re: 1966 13 Window Deluxe OG paint build. |
Missing pedal pan unless you removed it. Looks like your drag link may be worn out. You'll want to check shocks, tie rods,steering damper, steering wheel play and toe in. It never hurts to grease the front end if you don't know when it's been done last and check soft brake lines. Safety stuff. If you don't know when the fuel lines were last replaced I'd replace them. I replace mine every 2 years if they are the German braided type.
You'll want to get an original style air filter if possible or at least some kind of filter. I'm can' tell for sure but it looks like you need an engine seal, very important for cooling. Plug off any extra holes in tin. _________________ "A rolling bus gathers no rust." |
Posted: Thu Aug 31, 2017 4:29 pm Post subject: Re: 1966 13 Window Deluxe OG paint build. |
yeah the safety maintenance is top priority.
missing a battery strap as well. would make me nervous to drive it without one.
the pedal pan is missing. i will have to source one.
according to the previous owner, the master cyl, soft lines and wheel cyl have all been replaced but currently pedal goes to the floor and brakes are very weak.
i will try to bleed them out. either that or a bad master cyl. i assume its some cheapo Brazilian one on there at the moment. |
Posted: Sun Oct 01, 2017 11:12 am Post subject: Re: 1966 13 Window Deluxe OG paint build. |
is this suppose to glow?
quartermilecamel Samba Member
Posted: Sun Oct 01, 2017 2:35 pm Post subject: Re: 1966 13 Window Deluxe OG paint build. |
does it say 6 volt near the spade terminal for the choke? If yes and its hooked to 12 volts then yes its supposed to glow...........until it burns out _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Sun Oct 01, 2017 7:11 pm Post subject: Re: 1966 13 Window Deluxe OG paint build. |
Congrats on your bus!
Besides replacing the fan belt, you need to replace that crank pulley. It looks really rusty and pitted which will continue to eat up your belt (s) in the future.
_________________ Brandon |
