BusJunky Samba Member
Joined: February 27, 2009 Posts: 568 Location: Norwalk, ohio
Posted: Sun Oct 01, 2017 10:17 pm Post subject: Re: 1966 13 Window Deluxe OG paint build. |
This looks like a great start to a original bus! That exhaust does have to go. I have buses ive bought that came with the same one. Its kinda loud. The rear seats are definitely bay window seats. Which is ok, its better then no seats. The fronts are the correct 60/40. Wrong covers. All your hardboard door panels, theres a company called TMI that makes reproduction door panel sets. Or you could chase down a orignal set in the classifieds. I had a Titan Red deluxe a few years ago and ive got another one now that im working on. It was painted orange though. One of my favorite things to do when I get a new bus is to de-code the MPlate behind the passengers front seat. Then you know what all you need to get. My guess is that since its a non-walkthru, it probably had a full length middle seat? Looks like a great driver bus either way! Good luck! _________________ Leroux's Autowerks “like us on fb”
https://m.facebook.com/Lerouxs-Autowerks-942149562555768/?ref=bookmarks |
TheVintageVw Samba Member
Joined: July 19, 2004 Posts: 654 Location: Porter Ranch California
Posted: Mon Oct 02, 2017 10:41 am Post subject: Re: 1966 13 Window Deluxe OG paint build. |
oakman wrote: |
Congrats on your bus!
Besides replacing the fan belt, you need to replace that crank pulley. It looks really rusty and pitted which will continue to eat up your belt (s) in the future.
Thank you! Been looking for a replacement pulley but haven't been able to source one just yet. |
Posted: Sun Oct 15, 2017 8:11 pm Post subject: Re: 1966 13 Window Deluxe OG paint build. |
Other than trim what’s the difference between deluxe rear bumper and standard. Can I just install deluxe trim on a standard bumper? Considering its nearly impossible to find s deluxe rear I’m thinking of just adding trim to my standard? |
Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Sun Oct 15, 2017 8:47 pm Post subject: Re: 1966 13 Window Deluxe OG paint build. |
halchka99 wrote: |
Yup that's it. Just the trim. _________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Sat Nov 04, 2017 6:52 pm Post subject: Re: 1966 13 Window Deluxe OG paint build. |
Could be o-ring, spring came off the seal, spacer seal surface went bad, seal put in wrong, seal bad, bearing cap had nicks and the gasket leaked, loose axle nut, etc.
How long did it go before leaking? |
Posted: Sun Nov 05, 2017 8:52 am Post subject: Re: 1966 13 Window Deluxe OG paint build. |
It could also be the brake cyl though. I have the bus tilted a little more to that side in hopes of seeing where its coming from. Since removing the brake cyl yesterday there are no drips so far. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69813 Location: Phoenix Metro
Posted: Sun Nov 05, 2017 9:02 am Post subject: Re: 1966 13 Window Deluxe OG paint build. |
Usually brake fluid will eat the paint off the rim.
Was there fluid around the seals on the wheel cylinder?
This could indicate a leak there.
Does the fluid smell like tranny fluid? It has a particular smell...
Having it all apart might be an issue on checking for leaks.
Sometimes everything has to be assembled and torqued down for the axle seal to be totally sealed up. _________________ How to Post Photos
BarryL Samba Member
Posted: Sun Nov 05, 2017 9:56 am Post subject: Re: 1966 13 Window Deluxe OG paint build. |
Sometimes mechanics install the large o-ring by mistake which will goof up the sealing of the cover. |
Posted: Mon Nov 06, 2017 10:07 am Post subject: Re: 1966 13 Window Deluxe OG paint build. |
BarryL wrote: |
This could be it. I think the backing plate is installed incorrectly, so that might be a sign of more screw ups.
Not to mention the guy who i bought this bus from unfortunately is known for mickey mousing work just to flip for quick cash. Worst part of all he's a regular on the samba.
Ordering the seal kit today... |
Posted: Wed Nov 08, 2017 9:20 am Post subject: Re: 1966 13 Window Deluxe OG paint build. |
pulled off the seal cap and all 4 bolts holding it in place were completely loose.
o-ring was all screwed up. Previous owner really screwed up
Draining the box....
Untitled by Narbie, on Flickr
Taken out...
This will obviously leak.
Refilling the box....
I used a 1.5 inch PCV cap to press in the new seal. worked like a charm.
$1.14 at home depot. |
Posted: Mon Nov 13, 2017 11:54 am Post subject: Re: 1966 13 Window Deluxe OG paint build. |
Got the reduction box leak sorted out and now i need to tackle the steering box.
Ordered a seal, bearing puller and should have it done by mid week.
I'm also going to replace my drag link to reduce some play in the steering. Seems to be the culprit. Center pin looks okay for now.
Can someone tell me if im suppose to have two holes for the antenna?
Trying to figure out which one to buy.
Untitled by Narbie, on Flickr |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Mon Nov 13, 2017 1:07 pm Post subject: Re: 1966 13 Window Deluxe OG paint build. |
that is how they usually are, one big hole for the wire and a smaller one to keep it from turning.
http://www.jbugs.com/product/SC-175.html _________________ regards
Uli
Posted: Tue Nov 21, 2017 5:12 pm Post subject: Re: 1966 13 Window Deluxe OG paint build. |
Thank you very much! |
Posted: Tue Nov 21, 2017 5:13 pm Post subject: Re: 1966 13 Window Deluxe OG paint build. |
just want some confirmation on this. Looks to be a rear seal leak. leak increases with RPM. Tiny drops when car is off.
Posted: Wed Nov 22, 2017 2:01 pm Post subject: Re: 1966 13 Window Deluxe OG paint build. |
Went head and decided to pull the motor. Thanks to a lazy and " in it just to flip"po. I only had to remove 3 mounts to get the engine out. PO does this for a living to support his family otherwise i'd call him out here for a shitty rigged flip job. Totally mislead me during the purchase process (out of state)
First time putting the bus on this lift. Worked out well. I'll need to make some changes in the garage to allow more ceiling clearance.
Will need to figure out how much needs replacing while the engines out. Clutch will be changed. What are your thoughts on the flywheel?
Will replace gas tank and sender. Sender is 190mm in case anyone needs to know.
Posted: Sun Nov 26, 2017 6:01 pm Post subject: Re: 1966 13 Window Deluxe OG paint build. |
After 4 hours of scrubbing, degreasing and pressure washing. I can see my transmission. Took a nice bath in caked gunk.
Trying to revive some of the OG paint. Hit it with the glaze in the front. Nice results. You can see the difference between the front and the door.
Posted: Mon Nov 27, 2017 11:15 am Post subject: Re: 1966 13 Window Deluxe OG paint build. |
It was so messy, gave up after 4. I bet i could do another 4.
The pressure plate has a date stamp of 1979. I assume no one ever serviced this poor transmission. |
Posted: Mon Nov 27, 2017 7:58 pm Post subject: Re: 1966 13 Window Deluxe OG paint build. |
Took off the flywheel today. What is that black stuff between the case? RTV?
