1971-M74 Ignition Lock Cylinder Removal FAQ
Tcash
Tcash is offline
PostPosted: Wed Aug 30, 2017 12:21 pm    Post subject: 1971-M74 Ignition Lock Cylinder Removal FAQ Reply with quote
To link to this thread
Code:
[url=https://www.thesamba.com/vw/forum/viewtopic.php?t=685683&start=0&postdays=0&postorder=asc&highlight=]1971-M74 Ignition Lock Cylinder Removal FAQ[/url]
211 2800 001 > 214 2164 059
I thought I would update this thread to show the 1971 removal since it is just a bit different than the earlier bay bus years.
Here is the 1971 ignition assembly.
Step 1 – Loosen the 2 set screws indicated by the arrows. I had to grind a screwdriver to get the shaft narrow enough and the blade wide enough.
Step 2 – Make a removal tool out of a heavy coat hanger using the dimensions below as a guide.
Step 3 – The spring release hole on the 1971 ignition housing is on the back side (earlier years it is on the front, and much easier to get at). I struggled for 20 minutes before I got it, as I wasn’t sure just exactly where the hole was. Hopefully the photos below give you some idea where to feel for it. Once the coat hanger hits the hole, the ignition barrel pops right out…. I promise!
Here is a photo of the back side of the ignition housing showing the location of the release hole.
edited
Tcash
