DanHoug Samba Member
Joined: December 05, 2016 Posts: 4790 Location: Bemidji, MN
Posted: Wed Aug 30, 2017 2:05 pm Post subject: copper nuts aren't. |
a word on copper nuts... i've gotten them from two different vendors (shipped with Go Westy SS exhaust and Autohausaz) and they are merely copper coated steel nuts. the copper coating is thin and if you touch one to a grinder, you see ferrous sparks and reveals steel. they are strongly magnetic.
maybe 'copper nuts' were always this way but with as thin as the coating is, i wouldn't expect them to last very long.
-dan |
Posted: Wed Aug 30, 2017 2:09 pm Post subject: Re: copper nuts aren't. |
Copper nuts used for things like exhaust are, and always have been, copper plated, not solid copper. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
?Waldo? Samba Member
Posted: Wed Aug 30, 2017 2:13 pm Post subject: Re: copper nuts aren't. |
X2, always have been copper plated. |
ah. good to know. thought maybe some clever offshore bulk distributor flooded the US with fake nuts.
the thin coating bothered me when i did my exhaust install and so i used stainless nuts with high temp copper antiseize, which has worked well in the past on the exhaust port connections. used the copper nuts everywhere else.
-dan |
vwjetboat Samba Member
Posted: Wed Aug 30, 2017 2:15 pm Post subject: Re: copper nuts aren't. |
solid copper is to soft, they would strip.. |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6357 Location: Honolulu,Hawaii and France
Posted: Wed Aug 30, 2017 2:17 pm Post subject: Re: copper nuts aren't. |
DanHoug wrote: |
-dan |
Yeah, I have a bag of a 100 from Febi. Quite junk
I use real thick copper/brass alloy or something (it's in between copper and brass in color) stuff from old solar battery lugs
I crunch them a bit or I use the lock washers that are in the same material. Anytime I have enough thread, I cover them with an acorn nut, plus a good load of copper antiseize. Butter _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6832 Location: Fort Lauderdale, Fl.
Posted: Wed Aug 30, 2017 2:46 pm Post subject: Re: copper nuts aren't. |
vwjetboat wrote: |
yep!
Use the copper based Permatex Copper Anti-Seize on them. _________________ This free advice is worth exactly what you paid for it.
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Wed Aug 30, 2017 3:31 pm Post subject: Re: copper nuts aren't. |
DanHoug wrote: |
... i used stainless nuts with high temp copper antiseize ... |
With stainless you should use a zinc based antiseize. The problem with stainless is galling not corrosion.
https://www.permatex.com/products/lubricants/speci...lubricant/
Aloha
tp |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Wed Aug 30, 2017 4:00 pm Post subject: Re: copper nuts aren't. |
Brass nuts are commonly available for manifold applications. I have used them on many vehicles. |
newfisher Samba Member
Joined: January 05, 2012 Posts: 1764 Location: The wet spot--Oregon
Posted: Wed Aug 30, 2017 4:29 pm Post subject: Re: copper nuts aren't. |
Anyone try " Deez nuts"? |
Merian Samba Member
Posted: Wed Aug 30, 2017 5:33 pm Post subject: Re: copper nuts aren't. |
those are black oxide
good stuff _________________ .... |
Posted: Wed Aug 30, 2017 6:52 pm Post subject: Re: copper nuts aren't. |
in this case, galling isn't an issue with a stainless nut on steel stud, it's stainless on stainless where things gall easily. so a high temp, copper antiseize is the ticket for max removal in the future along with corrosion resistance. nickel and zinc based antiseize just don't have persistence at high temp like the copper does, at least in my experience.
-dan |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Thu Aug 31, 2017 8:04 am Post subject: Re: copper nuts aren't. |
newfisher wrote: |
I've tried DZ nuts, but I think that's a bit off topic.
https://www.dz-nuts.com/ |
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Thu Aug 31, 2017 8:13 am Post subject: Re: copper nuts aren't. |
An old trick I was shown to prevent galling on stainless-stainless connections was to let a bottle of Milk of Magnesia settle, pour off the liquid and use the dregs as the anti-seize. _________________ Jim Crowther
Vespa GTS 300 |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
Posted: Thu Aug 31, 2017 8:30 am Post subject: Re: copper nuts aren't. |
Pennies aren't real copper either.
Ah the good old days. _________________ Glenn
Member #1009
#BlueSquare |
Gizmoman Samba Member
Joined: September 10, 2011 Posts: 1554 Location: Nevada
Posted: Thu Aug 31, 2017 10:00 am Post subject: Re: copper nuts aren't. |
I'd check the torque spec on those SS nuts - good chance they can't handle the specs of the manifold torque. _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Oversize spare carrier - stock location (no longer for sale). |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Thu Aug 31, 2017 10:52 am Post subject: Re: copper nuts aren't. |
djkeev wrote: |
People love stainless but fail to grasp that stainless is a very weak fastener. Be real careful where you install a stainless nut, bolt or screw.
Dave |
Brittle and never over torque the spec for the particlular hardware component ie if a mild steel grade 5 allows for a component tq spec of say 15 ft lbs, using a stainless fastner may snap at 15 if the stainless bolt snaps at 11. I only use stainless for outdoor direct element exposure on decorative items with no specific torque. |
