Turn Signal Switch 5 wire T2 1973-M74 211 953 509 H FAQ
Tcash
Tcash is offline
PostPosted: Thu Aug 31, 2017 9:00 am    Post subject: Turn Signal Switch 5 wire T2 1973-M74 211 953 509 H FAQ Reply with quote
To link to this thread
Code:
[url=https://www.thesamba.com/vw/forum/viewtopic.php?t=685736&start=0&postdays=0&postorder=asc&highlight=]Turn Signal Switch T2 1973-M74 211 953 509 H FAQ[/url]
211 953 509 H 1973 to M74 >ch no. 164 059 Turn signal indicator switch 5 wire.
Production dates From August '72 to April '74.
The plastic piece is known to break.
Note crack in the center of the white plastic piece.
Wiring diagrams
https://www.thesamba.com/vw/archives/info/wiringt2.php
click on pic
Good luck
Tcash
Tcash
Tcash is offline
PostPosted: Thu Aug 31, 2017 3:22 pm    Post subject: Testing Turn Signal Switch 1973-74 211 953 509 H Reply with quote
Ohm Testing Turn Signal Switch 1973-74 211 953 509 H
thnx to Pete's vdubs posting.
Right turn
Left turn
alman72
alman72 is offline
PostPosted: Thu Aug 31, 2017 3:57 pm    Post subject: Re: Turn Signal Switch 1973-74 211 953 509 H FAQ Reply with quote
https://www.thesamba.com/vw/classifieds/detail.php?id=2055595
Why would this not work? This part number, not his part, as it is totally roached. found in a pick and pull on a 72, pre cut and plastic parts so pitted out.
