Paint Code for 1973 Thing 181
rickdn73
rickdn73 is offline
PostPosted: Fri Sep 01, 2017 4:29 pm    Post subject: Paint Code for 1973 Thing 181 Reply with quote
I have been trying to find the paint code for the Orange for a 1973 VW Thing (181). I have seen it called Pumpkin Orange, but I have not been able to find the Paint code. Can anyone help me out? or point in the right direction.
GMByers
GMByers is offline
PostPosted: Fri Sep 01, 2017 4:55 pm    Post subject: Re: Paint Code for 1973 Thing 181 Reply with quote
Pumpkin Orange OEM Code L30F
Down to three...and still downsizing...
93 Eurovan (sometime project)
83 Doka (The "Puts a smile on my face" vehicle)
74 Thing (Bound and determined to drive in 2017)
ldj1002
ldj1002 is offline
PostPosted: Fri Sep 01, 2017 8:19 pm    Post subject: Re: Paint Code for 1973 Thing 181 Reply with quote
I repainted mine white last year and came up with a lot of unanswered questions on the paint code. I understand all Things paint was semi gloss from factory and I wanted mine semi gloss not especially for originally but a semi gloss wouldn't show flaws in prep nearly as much. I took the paint code to paint shop and they said it would be gloss. I then took a body part and they scanned it and it came exactly which is gloss. That part clearly wasn't gloss. I was told I think on this forum that they could put a flatner in it but paint shop they couldn't. They said only way to get semi gloss would be base coat clear coat with the clear semi gloss. I didn't want to do base coat clear coat. I went to 2 paint shops and got exactly same info. I went single stage gloss and it is very nice. I am mentioning to you encase you want original you need to question paint store about if that paint they mix from that code will be gloss or not. I don't understand why they mix the factory code and it will be gloss when it was semi gloss from factory.
Ron Domeck
Ron Domeck is offline
PostPosted: Sat Sep 02, 2017 6:39 am    Post subject: Re: Paint Code for 1973 Thing 181 Reply with quote
A good paint shop can flatten any top coat, single stage or clear coat Had Thing green mixed from PPG that was semi gloss.
