Lesson learned
911pickup
911pickup is offline
PostPosted: Sat Sep 02, 2017 9:18 am    Post subject: Lesson learned Reply with quote
A couple of months ago I had the tranny out for a rebuild. Everything was fine until a couple of days ago.
While driving along I lost all my gears and the shifter just flopped around. I pulled over and had a good idea what the problem was. Sure enough, the shift couplier set screw had come lose and fallen into the tunnel.
Luckily, I was close to home and I called my wife to bring my tool kit and a bunch of screws, since I couldn't see the set screw in the tunnel.
I managed to limp home and was able to find the set screw.
The two lessons I learned were wire in the set screw, so if it does fall off again it will be easy to find, and keep a tool kit in the car.
These old cars tend to break down on a regular basis.
Captain Spalding
Captain Spalding is offline
PostPosted: Sat Sep 02, 2017 1:07 pm    Post subject: Re: Lesson learned Reply with quote
What do you carry for parts and spares?
911pickup
PostPosted: Sun Sep 03, 2017 2:18 pm    Post subject: Re: Lesson learned Reply with quote
Right now.....nothing, but I plan on changing that.
doublecanister
doublecanister is offline
PostPosted: Mon Sep 04, 2017 9:54 am    Post subject: Re: Lesson learned Reply with quote
glad you got it fixed fairly easy,
check that link out the Captain posted, it's about everything you can think of and the kitchen sink!
T
73'- Thing
66' -Mustang GT- Fastback
51'- Ford F1 pickup Flathead V8
cousineddy
cousineddy is offline
PostPosted: Mon Sep 04, 2017 10:33 am    Post subject: Re: Lesson learned Reply with quote
Those screws on the shift coupler should be safety wired.
65 bug blow thru 2276 turbo
73 Thing
911pickup
PostPosted: Tue Sep 05, 2017 5:12 pm    Post subject: Re: Lesson learned Reply with quote
Interestingly enough, the shifter couplier I ordered from Cip1 (ad states that it is OE quality) came with a set screw without the hole for a safety wire.
Hopefully, I'll be able to reuse the old set screw which has the hole.
sjbartnik
sjbartnik is offline
PostPosted: Wed Sep 06, 2017 7:29 am    Post subject: Re: Lesson learned Reply with quote
Not sure I agree with your final conclusion there...Whether or not that's true depends directly on the quality of the maintenance they receive and the quality of the replacement parts that are used in that maintenance.
For example, your recent breakdown was the direct result of you not performing a maintenance task correctly combined with poor quality replacement parts.
The set screw on the coupler is supposed to be safety wired to prevent this exact scenario. The safety wire's purpose is not to help you find the screw if it comes loose. If the safety wire is done correctly, it will keep the screw from coming unscrewed in the first place.
The other problem as you noted is that the replacement set screw was not drilled for safety wire. You will find that a lot of the aftermarket parts out there these days are of very poor quality compared to the original stuff. Just because something is advertised as "OE quality" doesn't make it so.
If you are one of those VW owners who's buying replacement parts solely based on lowest price, you can indeed expect to be breaking down on a regular basis.
Definitely a great idea to keep a tool kit in the car.
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
