ghia1969 Samba Member
Posted: Tue Sep 05, 2017 6:23 pm Post subject: Pedrini Tire Sizes |
I have a set of Pedrini rims I want to install on my 914, what size tires fit and look the best without any impact on drivability??? |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21510 Location: Oklahoma City
Posted: Tue Sep 05, 2017 8:04 pm Post subject: Re: Pedrini Tire Sizes |
ghia1969 wrote: |
What is the wheel size.?
Ray |
Posted: Wed Sep 06, 2017 5:18 pm Post subject: Re: Pedrini Tire Sizes |
I only have the rims, not sure of the tire size these rims take. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76889 Location: Sneaking up behind you
Posted: Wed Sep 06, 2017 5:45 pm Post subject: Re: Pedrini Tire Sizes |
Pedrini's are 5.5x15
I have 195/55-15 front and 205/60-15 rear but that's on a Beetle. Not sure what size fits a 914. I would imagine something like a 185/70-15 and maybe a 195/65-15. _________________ Glenn
Member #1009
#BlueSquare |
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1958 Location: FL Panhandle
Posted: Wed Sep 06, 2017 6:16 pm Post subject: Re: Pedrini Tire Sizes |
They were originally shod with 165/80x15. Those are still available but are costly and you'll probably have to order them. 185/65x15 is pretty close but will lower car 1/2" or so. A good tire size comparison i http://www.miatatirecalculator.org/ _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
Posted: Wed Sep 06, 2017 8:49 pm Post subject: Re: Pedrini Tire Sizes |
Glenn wrote: |
I have 195/55-15 front and 205/60-15 rear but that's on a Beetle. Not sure what size fits a 914. I would imagine something like a 185/70-15 and maybe a 195/65-15. |
Beat me to it.
That same rim diameter and width....I run 250-60-15s comfortably. Different car.
But I think I calculated a while back that 195-65-15 will give alkost identical speedometer speeds ...if you can,get them under your fender.
There are also some superb tires available in that size. Just put a set of those on my golf crom the tire rack. Ray |
BK911 Samba Member
Joined: May 11, 2005 Posts: 98 Location: Rocky Top, TN
Posted: Thu Sep 21, 2017 5:17 pm Post subject: Re: Pedrini Tire Sizes |
195.65 will be closest to stock diameter.
I run 195.60s on my '72 914 with pedrini wheels.
Look pretty good imho, plus provide a little more acceleration. _________________ '72 914 1.7
'74 Standard Bug 1600 |
Joined: December 28, 2016 Posts: 279 Location: atlanta ga
Posted: Wed Oct 25, 2017 7:45 am Post subject: Re: Pedrini Tire Sizes |
165x15 was factory fitted stock for all 914-4 with no factory option
185/70x15 factory option for 914-6 but will fit pedrini 15 x 5.5 inch wheel
195/65x15 is the modern tire size for the wheel
205/60x15 will fit but would need to have a very stiff sidewall or the jello effect will happen when you go into a tight curve as the sidewall bulges out from the narrow wheel and flexes |
johncocke356 Samba Member
Posted: Fri Oct 04, 2019 11:14 pm Post subject: Re: Pedrini Tire Sizes |
BK911 wrote: |
Look pretty good imho, plus provide a little more acceleration. |
These are 195/60’s
I lowered the car to remove empty space above the tire, ride and handling just fine |
arne2 Samba Member
Posted: Fri Apr 10, 2020 9:51 pm Post subject: Re: Pedrini Tire Sizes |
I had 195/65-15 on Fuchs on my 914, the Fuchs are the same size and offset as the Pedrinis. Fit fine, no issues.
