Rockbound Samba Member
Joined: September 06, 2017 Posts: 303 Location: Pennsylvania
Posted: Thu Jun 27, 2019 9:17 am Post subject: Re: Out for 17 years, now back in it! Building a Berrien Genesis |
so after looking and finding stuff that may or may not work, at a pretty steep price, i decided to make my own intake elbow.
I didn't want to cut the body because i will eventually be changing this motor to most likely a built dual port dual carb motor.
so i needed to find away to make a filter work without cutting the body...
I used a 1 1/2" abs street 90 sanded a section out that hit the body, used epoxy to glue an acrylic piece in. sanded, painted, now i have to wait till i get home to see if it fits.
I will also be using a regular 1 1/2" abs 22 and an 1 1/2" street 22 with a
k&n RC-2330 filter. it should tuck up under nicely.. i hope..
Bkhansen93 Samba Member
Joined: July 14, 2018 Posts: 207 Location: Coal City, Il USA
Posted: Thu Jun 27, 2019 9:58 am Post subject: Re: Out for 17 years, now back in it! Building a Berrien Genesis |
Haha. Sorry to keep blowing up your thread but I had that same exact issue. I couldn't figure it out so I reluctantly cut the body. Also, I don't know about yours but mine looks like dual carbs might not fit either. Not without some major cutting of the body. |
Posted: Thu Jun 27, 2019 10:21 am Post subject: Re: Out for 17 years, now back in it! Building a Berrien Genesis |
Bkhansen93 wrote: |
lol no worries man, yeah i have not even looking at that yet, but i was worried there wasn't room at first glance, but i will have no problem cutting when that happens if need be cause that motor will be the last motor i will be using.. or that type of configuration of motor anyway. |
Posted: Thu Jun 27, 2019 12:52 pm Post subject: Re: Out for 17 years, now back in it! Building a Berrien Genesis |
Success!
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 852 Location: South Florida
Posted: Thu Jun 27, 2019 1:39 pm Post subject: Re: Out for 17 years, now back in it! Building a Berrien Genesis |
Most unique and custom-fitted velocity stack ever. |
Posted: Thu Jun 27, 2019 2:34 pm Post subject: Re: Out for 17 years, now back in it! Building a Berrien Genesis |
MrGoodtunes wrote: |
Posted: Fri Jul 19, 2019 6:14 am Post subject: Re: Out for 17 years, now back in it! Building a Berrien Genesis |
welp it finally arrived!!
4" narrowed and adjustable ball joint beam from Sam @ autowerks! this thing is very nicely made! Very happy customer. great communication throughout the process, quick responses. made exactly what i wanted!
got this baby mocked up, took some wheel and tire measurements, and then pulled it off to paint.
ordered front shocks and tires. soon i will be full assembly mode!! woot woot
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Fri Jul 19, 2019 10:53 am Post subject: Re: Out for 17 years, now back in it! Building a Berrien Genesis |
Rockbound wrote: |
Success!
This would likely have cleared the body -
http://www.thethingshop.com/SINGLE-ELBOW-FOR-AIR-CLEANER/productinfo/211129615E/
bryan _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
Posted: Fri Jul 19, 2019 10:57 am Post subject: Re: Out for 17 years, now back in it! Building a Berrien Genesis |
Rockbound wrote: |
... the Air Intake clearance problem, brought to you courtesy of the transmission risers.
Posted: Fri Jul 19, 2019 12:20 pm Post subject: Re: Out for 17 years, now back in it! Building a Berrien Genesis |
Yeah. Not really an issue. Just didnt want to cut the body just yet.. I saw that and thought it could work. But it would have been a pricey test. |
Posted: Mon Jul 22, 2019 11:03 am Post subject: Re: Out for 17 years, now back in it! Building a Berrien Genesis |
Rockbound wrote: |
A Samba member might've loan you one for cost of shipping only to use as a test fit... and most suppliers would accept a Return.
Posted: Mon Jul 22, 2019 3:02 pm Post subject: Re: Out for 17 years, now back in it! Building a Berrien Genesis |
didget69 wrote: |
Rockbound wrote: |
bryan |
I had that same issue. I tried using that part as well. Since it is made of rubber, it flops around. Unless you have a good way to secure it I wouldn't do it. I ended up just cutting the body |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8699 Location: Sunset, Louisiana
Posted: Mon Jul 22, 2019 5:12 pm Post subject: Re: Out for 17 years, now back in it! Building a Berrien Genesis |
I wanted to use this, but it hits the back of my tail lights. Steel, with a bracket that holds up the end. Comes from a VW bus. I'll try again some day when I do some freshening up of the car.
_________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Tue Jul 23, 2019 9:13 am Post subject: Re: Out for 17 years, now back in it! Building a Berrien Genesis |
Q-Dog wrote: |
my thoughts where to use one of those, cut it somewhere on the arm, see pic i inserted yellow line and find a filter to fit the arm here are some k&n sizes i was looking at below.
Posted: Tue Jul 23, 2019 4:11 pm Post subject: Re: Out for 17 years, now back in it! Building a Berrien Genesis |
All painted up assembled and ready to go in!
EVfun Samba Member
Posted: Tue Jul 23, 2019 4:28 pm Post subject: Re: Out for 17 years, now back in it! Building a Berrien Genesis |
Are there any good buggy specific air filter threads? I didn't find much in a search. We have somewhat unique fit issues. I've only got about 2" above the top of a 36 horse fan shroud and have been looking at the options for a stock carb too. _________________
Wildthings wrote: |
Q-Dog Samba Member
Posted: Tue Jul 23, 2019 4:51 pm Post subject: Re: Out for 17 years, now back in it! Building a Berrien Genesis |
This is the direction I was headed. It still hits the back of my tail lights so I didn't modify it.
'69 Dune Buggy
'70 Beetle |
Posted: Wed Jul 24, 2019 7:15 am Post subject: Re: Out for 17 years, now back in it! Building a Berrien Genesis |
Q-Dog wrote: |
you can def make the work with some easy mods. |
Posted: Fri Jul 26, 2019 7:08 am Post subject: Re: Out for 17 years, now back in it! Building a Berrien Genesis |
SEATS!!
custom PRP roadsters came out perfect.
Posted: Fri Jul 26, 2019 7:10 am Post subject: Re: Out for 17 years, now back in it! Building a Berrien Genesis |
also go the front beam installed
