left side dash grill insert for tach?
Dr.Adam
Dr.Adam is offline
PostPosted: Wed Sep 06, 2017 1:40 pm    Post subject: left side dash grill insert for tach? Reply with quote
wanting to install a tach on my 67 and want to locate it to the left of the speedo (speaker location) I have seen pic's on this forum of grill plates that have a hole in them but still retain the grill appearance, really don't want to cut mine and I don't like the brushed alum or plastic ones.
Any help locating them would be great.
Thanks
Adam
pwmcguire
pwmcguire is offline
PostPosted: Wed Sep 06, 2017 2:43 pm    Post subject: Re: left side dash grill insert for tach? Reply with quote
This is mine but when I did it I had access to a welder, I picked up a grill and the metal mesh at a swap meet, cut the hole using wire cutters. I took a 1/8 inch SS welding rod and bent it around my tach. than I bent another one around the outside of it. I had a friend weld them together and to the grill, basically melt the grill to the circle using a tig welder. I used body filler around the circle and filed it down with small round files. Then I picked up paint at a store that they can color match. It certainly was not cheap, but worth it.
Dr.Adam
Dr.Adam is offline
PostPosted: Wed Sep 06, 2017 3:41 pm    Post subject: Re: left side dash grill insert for tach? Reply with quote
this guy has one and I want one!
pwmcguire
PostPosted: Wed Sep 06, 2017 3:43 pm    Post subject: Re: left side dash grill insert for tach? Reply with quote
Seems like you have to make them.
57BLITZ
57BLITZ is offline
PostPosted: Wed Sep 06, 2017 3:45 pm    Post subject: Re: left side dash grill insert for tach? Reply with quote
Maybe you can use one of these . . . https://grumpysmetal.com/bug/bug-1961-63/gauge-bezel-single-3-385-hole-lhd-57.html
Hang in there Dr.Adam . . . it will sometimes seem as though you get the wrong information around here, but I assure you that there a few folks on The Samba that are able to answer yer questions!
Jesucristo es mi Seņor y Salvador!
pwmcguire
PostPosted: Wed Sep 06, 2017 3:57 pm    Post subject: Re: left side dash grill insert for tach? Reply with quote
Well, there you go! I had no choice my tach is 90 mm. I think that's why it was so cheap.
pwmcguire
PostPosted: Wed Sep 06, 2017 4:06 pm    Post subject: Re: left side dash grill insert for tach? Reply with quote
There are a few smart people around here, but some not to bright.
Dr.Adam
Dr.Adam is offline
PostPosted: Wed Sep 06, 2017 4:08 pm    Post subject: Re: left side dash grill insert for tach? Reply with quote
be nice now guys!
heimlich Premium Member
VWNOS.com
heimlich is online now
PostPosted: Wed Sep 06, 2017 6:09 pm    Post subject: Re: left side dash grill insert for tach? Reply with quote
That actually looks original.
www.vwnos.com
New NOS OEM Parts. Classic Brands. Classic Quality
Aluminum and Cast Iron Restored Distributors Available (<--Click here)
DaveOBrien
DaveOBrien is offline
PostPosted: Wed Sep 06, 2017 7:32 pm    Post subject: Re: left side dash grill insert for tach? Reply with quote
Yes Grumpys. Good to see he still makes them.
My Tach is 52 mm but not to hard to see.
Frederik
Frederik is offline
PostPosted: Thu Sep 07, 2017 7:20 am    Post subject: Re: left side dash grill insert for tach? Reply with quote
I did it cheap and easy, bought a color matched spare grill with crome trim (didn't want to cut in the existing grill). Used a "dremel" to cut a hole for tach and grind the trim to fit the vdo bezel. Works fine.
doc73
doc73 is offline
PostPosted: Thu Sep 07, 2017 11:53 am    Post subject: Re: left side dash grill insert for tach? Reply with quote
@ Frederik - where did you get that Tach?
Speed Leaving Without Warning . . .
66 Bug
Cusser
Cusser is offline
PostPosted: Thu Sep 07, 2017 4:04 pm    Post subject: Re: left side dash grill insert for tach? Reply with quote
I did similar for my later model:
1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2005 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
Rome
Rome is offline
PostPosted: Thu Sep 07, 2017 4:22 pm    Post subject: Re: left side dash grill insert for tach? Reply with quote
Adam, you'll see when you remove the grill from the trunk that there is a horizontal metal bar going right across the dash opening. You'll need to cut that out so that the tach fits there.
For the tachs that are 52-55mm, in 2001 I saw a vendor of these dash grills in Germany (Maikaefer Treffen in Hanover) use a thick Type 1 engine flywheel endplay shim as the metal surround. The shim has an ID of 55mm. You could silver-solder such a shim onto the round-cut opening, then spray paint the grill to match the dash. Was a clever idea.
Frederik
Frederik is offline
PostPosted: Fri Sep 08, 2017 4:49 am    Post subject: Re: left side dash grill insert for tach? Reply with quote
I bought it on a auction site here in Sweden. They do come up from time to time. At first I thought of using one of the following, but liked the more vintage look of the one I installed.
Now I'm trying to get a set of matched VDO "small gauges". I'm still missing oil pressure and volt. I'm thinking of converting the tank meter to a pressure meter (new guts) or get a later vw fuel level gauge and grill and convert it to oil pressure. Some of the collected gauges:
Corney13
Corney13 is offline
PostPosted: Fri Sep 08, 2017 10:16 am    Post subject: Re: left side dash grill insert for tach? Reply with quote
I cut my grill as well. I am planning on modifying the trim, but have not got around to it yet.
Frederik
Frederik is offline
PostPosted: Fri Sep 08, 2017 11:32 am    Post subject: Re: left side dash grill insert for tach? Reply with quote
I really like the gauges in radio slot. The trim, is it a modified radio faceplate, assesory or self made? I have to consider dumping my blaupunkt..
Todd66
Todd66 is offline
PostPosted: Fri Sep 08, 2017 11:49 am    Post subject: Re: left side dash grill insert for tach? Reply with quote
The radio gauge pod is made by fast fab. I did the same as others and cut my speaker grill. The only issue I have is that when its hot out the gauge with squeak in the grill opening.
Cali_Army_Guy
Cali_Army_Guy is offline
PostPosted: Sat Sep 09, 2017 10:25 pm    Post subject: Re: left side dash grill insert for tach? Reply with quote
Just to throw out another option, Speedhut makes a drop in GPS speedo/tach combo if you don't want to cut your dash to put a tach in the speaker location.
2015 VW Passat Wolfsburg Edition
1966 VW Beetle - Sold
boxkiteflyer
boxkiteflyer is offline
PostPosted: Sun Sep 10, 2017 7:09 pm    Post subject: Re: left side dash grill insert for tach? Reply with quote
ISP West carries nice gauges. I bought one of their 52mm ones to match the original speedo in my '59. I'll mate it to a left side grill from Grumpy's Metals.
