Gendronf Samba Member
Joined: September 07, 2017 Posts: 3 Location: Matapédia Québec
Posted: Thu Sep 07, 2017 5:04 pm Post subject: Back Rattling noise each wheel turn ...? |
Help please. Vanagon Westfalia 1986 automatic transmission gaz. Brand new tires, brakes, bearing wheel, and CV. There is a noise like a click, seem to be at every turn of wheel but only if I give gaz even a little. (the motor got to be on load). if I release the gaz pedal, it's ok, the click stop. I look by the differential cover and everything is OK.
I jack the both side of the rear axles, and put it on drive while pressing the brakes, but I let the wheel turn it's OK. What else should I do? |
E1 Samba Member
Joined: January 21, 2013 Posts: 6556 Location: Westfalia, Earth
Posted: Thu Sep 07, 2017 5:15 pm Post subject: Re: Back Rattteling noise each wheel turn ...? |
First guess be the CVs are short of grease. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Posted: Thu Sep 07, 2017 5:22 pm Post subject: Re: Back Rattteling noise each wheel turn ...? |
Both CV are brand new. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Thu Sep 07, 2017 5:29 pm Post subject: Re: Back Rattteling noise each wheel turn ...? |
^^^ Who did the work? How much grease was used?
Common practice these days to use at least DOUBLE the "recommended" amount of grease as supplied in most
CV joint kits. You can add more without removing the axles by using a needle adapter with any standard grease gun.
Definitely try to match the same type, if not actual brand of grease that's already in there. Good luck!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Gauche1968 Samba Member
Posted: Fri Sep 08, 2017 8:38 am Post subject: Re: Back Rattteling noise each wheel turn ...? |
Brake backing plate? _________________ 1984 Vanagon GL
1984 Vanagon Westy |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
newfisher Samba Member
Joined: January 05, 2012 Posts: 1764 Location: The wet spot--Oregon
Posted: Fri Sep 08, 2017 9:14 am Post subject: Re: Back Rattteling noise each wheel turn ...? |
Rear hub bearing or axle nut not tight enough? |
E1 Samba Member
Posted: Fri Sep 08, 2017 9:22 am Post subject: Re: Back Rattteling noise each wheel turn ...? |
dobryan wrote: |
Drive it slowly in a circle in a parking lot. If the clicking occurs in one direction but not in the other then you likely have a dry or bad CV. Cheap CV's can go bad right out of the box..... |
Thanks Dave, knowing simple tests like this is invaluable! _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Posted: Fri Sep 08, 2017 9:31 am Post subject: Re: Back Rattteling noise each wheel turn ...? |
E1 wrote: |
dobryan wrote: |
Thanks Dave, knowing simple tests like this is invaluable! |
It helps but is not a fail proof way to tell. _________________ Dave O
The Western Syncro build
E1 Samba Member
Posted: Fri Sep 08, 2017 9:34 am Post subject: Re: Back Rattteling noise each wheel turn ...? |
Mine always just did an obvious "Click-click-click" under load, mostly up big hills.
Still a good test you got there, Thanks. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Posted: Sun Sep 10, 2017 4:52 pm Post subject: Re: Back Rattling noise each wheel turn ...? |
Thanks guys. I did what you told me. I went in a parking lot and turn. I re-pack the left CV and now it's OK. My mechanic did'nt say a word. He could,t beleive what,s appening.
Thanks again |
E1 Samba Member
Posted: Sun Sep 10, 2017 5:12 pm Post subject: Re: Back Rattling noise each wheel turn ...? |
Awesome. Thanks for letting us know!
Mechanic owes you a steak. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Posted: Sun Sep 10, 2017 5:53 pm Post subject: Re: Back Rattling noise each wheel turn ...? |
^^^ Indeed. Grease is your friend.
"The WonderVan"
E1 Samba Member
Posted: Sun Sep 10, 2017 6:12 pm Post subject: Re: Back Rattling noise each wheel turn ...? |
Do you guys pack them to the max, or??? _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Posted: Sun Sep 10, 2017 6:40 pm Post subject: Re: Back Rattling noise each wheel turn ...? |
I sure do.
"The WonderVan"
Posted: Sun Sep 10, 2017 7:42 pm Post subject: Re: Back Rattling noise each wheel turn ...? |
Unfortunately there are some inferior CV joints being sold. The 'complete' axle sets are notorious for poor quality. Packing extra grease can help but they likely will not last as long as the original CV's. Lobro CV's are still supposed to be high quality but only available as individual units. So.... if your mechanic installed one of those complete axle sets you should not expect a long life from the CV's. YMMV. _________________ Dave O
E1 Samba Member
Posted: Sun Sep 10, 2017 7:51 pm Post subject: Re: Back Rattling noise each wheel turn ...? |
Thanks agents, appreciated.
We had one clicking up a symphony, so went ahead and had all four done about 30K ago. One clicked a little 10K ago so more grease went in but all's been spotless.
Yes on Lobros.
Yes on having a spare.
— Colin Chapman |
Jquinn24 Samba Member
Joined: September 23, 2017 Posts: 1 Location: Pennsylvania
Posted: Sat Sep 23, 2017 7:05 pm Post subject: Re: Back Rattling noise each wheel turn ...? |
If I could jump in on this thread, I just bought an 86’ and drove it about 100 miles then on the way home from Farm Aid a clanging sound started in the rear drivers side wheel area. The next day I popped the hubcap off and 3 lug nuts were loose. I thought this might be the case since the previous owner said he just rotated the tires. I then drove it another 100 miles then on my way camping this weekend the noise came back but the lug nuts are not loose. Any suggestions? |
