djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Wed Feb 17, 2021 6:09 am Post subject: Re: Official lazy person's stupid question thread |
NorthOf50 wrote: |
here's my lazy question:
why can you not take a pop-top off a donor van and just cut the rough opening into the top of a tin-top to make the tin-top pop-top? Is there something about the Westy roof that requires the transplant, etc? I know I "must" be missing something but is it not just this simple. |
The tin top has cross braces in the roof and curved convex tin on top.
The camper has the cross brace and no curved tin. There is a flat plywood board that spans the space from the cross brace to the rear.
I can only guess (I'm not certain) that the cross brace probably has a flat design as well.
People transplant pop tops on to tintops and use the curved roof but they loose head space and the hinge mount areas need some reinforcement installed.
Ghia
Vanagon
Beetle
jAndrew Samba Member
Joined: October 11, 2020 Posts: 306 Location: Atlanta, Georgia
Posted: Wed Feb 17, 2021 8:33 am Post subject: Re: Official lazy person's stupid question thread |
I'll jump in here since I have many stupid questions. I've read all the climate control threads, or a lot of them anyway. What's this control without a knob for? It's on my 89 German Syncro Doka. Edited to add I know it's labeled as Secondary Heat Exchanger in the Bentley.
Abd here are the levers. I know how they work. Perhaps someone interested in seeing 3 levers and not 4.
_________________ '89 Syncro Doka |
4Gears4Tires Samba Member
Posted: Wed Feb 17, 2021 8:40 am Post subject: Re: Official lazy person's stupid question thread |
Do Dokas have a rear heater under the rear bench? Pull the knob straight out of the other one and put it in the missing one and see what it turns on. _________________ '87 Syncro
Posted: Wed Feb 17, 2021 8:42 am Post subject: Re: Official lazy person's stupid question thread |
4Gears4Tires wrote: |
Do Dokas have a rear heater under the rear bench? Pull the knob straight out of the other one and put it in the missing one and see what it turns on. |
Dooh! That would be logical, wouldn't it. Seeing the condition of the dash wiring I have doubts. The dash is coming off next week to do some work and I wanted to see what is actually should do.I'll give it a shot. Nothing under the rear bench. _________________ '89 Syncro Doka |
holdthewind2 Samba Member
Joined: October 17, 2015 Posts: 86 Location: The Gorge
Posted: Wed Feb 17, 2021 3:06 pm Post subject: Re: Official lazy person's stupid question thread |
4gears is correct, it controls the rear cabin heater. _________________ 65 deluxe
89 Syncro Westfalia
90 Tristar Syncro |
Posted: Wed Feb 17, 2021 3:21 pm Post subject: Re: Official lazy person's stupid question thread |
holdthewind2 wrote: |
4gears is correct, it controls the rear cabin heater. |
Nothing to control in the rear of this Doka. Strange. Perhaps they just use the same dash for everything. _________________ '89 Syncro Doka |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2796 Location: North Carolina
Posted: Wed Feb 17, 2021 3:25 pm Post subject: Re: Official lazy person's stupid question thread |
jAndrew wrote: |
Nothing to control in the rear of this Doka. Strange. Perhaps they just use the same dash for everything. |
Or the rear heater was removed when it started leaking coolant as in many if not most vans. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
Posted: Wed Feb 17, 2021 5:42 pm Post subject: Re: Official lazy person's stupid question thread |
May it has been removed... or just the same dash for all dokas... I'm unsure... it controls the rear heater in my doka, my dog loves having a fully heated bench seat in the winter _________________ 65 deluxe
89 Syncro Westfalia
90 Tristar Syncro |
WillRB Samba Member
Posted: Wed Feb 17, 2021 7:13 pm Post subject: Re: Official lazy person's stupid question thread |
Stupid question. Are vanagon CV axle directional? Does it matter what side is towards wheel or transmission? 2WD Manual transmission. Thanks.. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22665 Location: NYC/Upstate/ROW
Posted: Wed Feb 17, 2021 7:23 pm Post subject: Re: Official lazy person's stupid question thread |
WillRB wrote: |
No, and they are identical on a manual transmission
If you want to try to evenly wear them, swap the entire axle plus cv joints side to side, driver side to passenger side. _________________ .ssS! |
jimf909 Samba Member
Posted: Wed Feb 17, 2021 8:00 pm Post subject: Re: Official lazy person's stupid question thread |
jAndrew wrote: |
I'll jump in with a stupid question: does this mean that VW eliminated the bottom (fourth) lever but did not delete the (blue) graphic for the bottom lever in dokas? Or did someone just remove the bottom lever handle from this particular doka? _________________ - Jim
Abscate wrote: |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6832 Location: Fort Lauderdale, Fl.
Posted: Wed Feb 17, 2021 9:05 pm Post subject: Re: Official lazy person's stupid question thread |
Picture of my 3 Lever Air Control Panel
VW # on back is: 251 919 383 L
_________________ This free advice is worth exactly what you paid for it.
Posted: Wed Feb 17, 2021 9:20 pm Post subject: Re: Official lazy person's stupid question thread |
Steve M. wrote: |
Okay. All is right with the world again. I understand mfrs. building cars from the parts bins but a three lever control with a four lever dash panel disrupted my peaceful evening. _________________ - Jim
Abscate wrote: |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2331 Location: Southeast Kentucky
Posted: Thu Feb 18, 2021 7:59 pm Post subject: Re: Official lazy person's stupid question thread |
Oil capacity of the DK transmission is 3.5 Liters (3.7 Quarts).
So, with the transmission mounted and the Van on a level surface, where is the level of the oil in the transmission in relation to the fill hole? _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
Zeitgeist 13 Samba Member
Posted: Thu Feb 18, 2021 8:22 pm Post subject: Re: Official lazy person's stupid question thread |
Just below the fill hole--finger test. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Thu Feb 18, 2021 10:10 pm Post subject: Re: Official lazy person's stupid question thread |
jimf909 wrote: |
Okay. All is right with the world again. I understand mfrs. building cars from the parts bins but a three lever control with a four lever dash panel disrupted my peaceful evening. |
I know it really messes with the mind! _________________ This free advice is worth exactly what you paid for it.
Posted: Thu Feb 18, 2021 10:53 pm Post subject: Re: Official lazy person's stupid question thread |
Steve M. wrote: |
jimf909 wrote: |
I know it really messes with the mind! |
I have owned my '91 for almost 30 years now and still have to put mental effort into figuring what I need to do to make the various heater functions work correctly. |
Posted: Thu Feb 18, 2021 11:13 pm Post subject: Re: Official lazy person's stupid question thread |
Wildthings wrote: |
Steve M. wrote: |
jimf909 wrote: |
At least VW provides a cheat sheet for defrost: all the levers to the right, fan on 2 (shown just above the fan speed switch). It's off to the owners manual after that.
Abscate wrote: |
Posted: Fri Feb 19, 2021 6:20 am Post subject: Re: Official lazy person's stupid question thread |
jimf909 wrote: |
Oh... is that how that barcode works.
Cudos to you, not many people realize what that is! _________________ This free advice is worth exactly what you paid for it.
