Blakesinclair Samba Member
Joined: January 22, 2021 Posts: 60 Location: Santa Ana, California
Posted: Thu Mar 25, 2021 10:25 am Post subject: Re: Official lazy person's stupid question thread |
Should I shmear some anti-seize on the gear oil plugs? Still trying to figure out when and when not to use that stuff. _________________
1985 Weekender Vanagon 1.9L - Manual |
Posted: Thu Mar 25, 2021 10:36 am Post subject: Re: Official lazy person's stupid question thread |
Blakesinclair wrote: |
Should I shmear some anti-seize on the gear oil plugs? Still trying to figure out when and when not to use that stuff. |
The gear oil will typically prevent corrosion so I have never used anti seize here. What you don't want to do is over tighten the plug, as in use an 18" breaker bar and apply all the force you can to tighten the plug. |
Posted: Thu Mar 25, 2021 1:19 pm Post subject: Re: Official lazy person's stupid question thread |
Cool thanks. Kinda what I figured, but since they weren't the easiest to get off I wasn't sure if I should do anything special to avoid that in the future. I guess they just don't get worked on as often as an oil drain plug. _________________
DuncanS Samba Member
Posted: Thu Mar 25, 2021 4:07 pm Post subject: Re: Official lazy person's stupid question thread |
Actually, two questions. Capturing the space over the tranny in a 2WD '91 tin top.
Need to reroute some stuff which will yield a great deal more space.
First---If I tip the coolant collection tower about 45Ί to the PS, (left in the photo) pivoting it on the bottom this will vastly help. Does anyone see a problem doing this? Top hose will be lengthened and have an appropriate molded curve section.
Second---Is there any reason why the clutch slave cylinder can't be rotated counterclockwise 90Ί? Steel line will be reformed to accommodate.
Duncan |
jimf909 Samba Member
Posted: Thu Mar 25, 2021 10:55 pm Post subject: Re: Official lazy person's stupid question thread |
Wildthings wrote: |
Agreed!
At most, I use a 9" ratchet to gently tighten those plugs to about 14 ft lbs. I prefer drips to strips.
I just bought an 18" breaker bar to fasten/remove 83 ft lb lug nuts. It'd strip these plugs in a sparrow's heartbeat. _________________ - Jim
Abscate wrote: |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6360 Location: Honolulu,Hawaii and France
Posted: Thu Mar 25, 2021 10:58 pm Post subject: Re: Official lazy person's stupid question thread |
I put a couple wraps of teflon tape, not for leak prevention but for seize prevention. Your case can corrode to pieces, it will still come off.... _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Fri Mar 26, 2021 7:45 am Post subject: Re: Official lazy person's stupid question thread |
Use the yellow fuel resistsnt teflon tape if you can find it. _________________ This free advice is worth exactly what you paid for it.
bobhill8 Samba Member
Posted: Mon Mar 29, 2021 11:32 am Post subject: Re: Official lazy person's stupid question thread |
Need to change the upper oil pressure sensor (between push rods) on my 2.1 L Can I do it without draining oil if I jack up the driver's side go up on blocks on that side? Classic Lazy question. Thanks. _________________ 1986 Westy
1971 Squareback |
Posted: Mon Mar 29, 2021 11:48 am Post subject: Re: Official lazy person's stupid question thread |
bobhill8 wrote: |
Need to change the upper oil pressure sensor (between push rods) on my 2.1 L Can I do it without draining oil if I jack up the driver's side go up on blocks on that side? Classic Lazy question. Thanks. |
The switch between the pushrods is the low pressure switch. Either switch can be changed without draining the oil. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Posted: Mon Mar 29, 2021 12:08 pm Post subject: Re: Official lazy person's stupid question thread |
Thanks fellas - luckily have a deep 15/16" that used to belong to my Dad that works as well _________________ 1986 Westy
1971 Squareback |
Brentpd Samba Member
Posted: Mon Mar 29, 2021 6:48 pm Post subject: Re: Official lazy person's stupid question thread |
Heres a stupid question (thanks for creating this forum). I just had my engine rebuilt (1.9 85 riviera) and the coolant is this dark brown color. I noticed the coolant is getting somewhat low so Id like to top it off but I dont know exactly what type of coolant it is. Anyone know if its okay to mix the gas station shit with this other, thicker looking coolant or should I call the guy That rebuilt it for me and find out what he put in it?
Thanks for the help! |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Mon Mar 29, 2021 7:17 pm Post subject: Re: Official lazy person's stupid question thread |
Hi, to begin with your coolant shouldn't be dark brown... Take some out of the coolant tank to look at its color, it always looks darker in the tank than it actually is.
Also, do ask your rebuilder what he put in there. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Mon Mar 29, 2021 10:28 pm Post subject: Re: Official lazy person's stupid question thread |
You should also be concerned if you have a recently rebuilt motor and you're losing coolant. It doesn't necessarily mean the engine is bad but it may mean that your new engine's life support system (the cooling system) has a leak which can get worse and take your engine out in short order.
- coolant shouldn't be brown
- coolant should not disappear
It could simply be a hose clamp that needs to be tightened which is 100% normal after a rebuild. _________________ - Jim
Abscate wrote: |
revolution337 Samba Member
Joined: May 23, 2009 Posts: 372 Location: Pennsylvania
Posted: Tue Mar 30, 2021 4:13 am Post subject: Re: Official lazy person's stupid question thread |
How does one remove the rear ash tray in the panel just behind the slider door?
_________________ 1982 Westfalia AEB 1.8t
2017 VW Golf Sportwagen
2001 Audi A4 4.2 V8 swapped
2000 BMW Z3 roadster
-Mark |
Jim Bear Samba Member
Joined: March 25, 2006 Posts: 670 Location: Watkinsville, GA
Posted: Wed Mar 31, 2021 5:18 am Post subject: Re: Official lazy person's stupid question thread |
Double post... _________________ "You're either on the bus, or you're off the bus." ~kk
'85 Vanagon Westy - George In the Stable 2020-?/'74 Weekender - Ophelia In the Stable 2007- ?/'69 Beetle Convertible - SOLD 2017-2020/'67 Beetle - September SOLD 2013-2016 /'67 SO42 Westy - Sage SOLD 1996-2001 /'69 Transporter - Baby Blue SOLD 1995-1995/'72 Westy - Nelly - SOLD 1990-1995--STOP FRACKING
Posted: Wed Mar 31, 2021 5:32 am Post subject: Re: Official lazy person's stupid question thread |
In a pinch, if the cap to the plastic expansion tank decides it does not want to stay tight and keeps loosening up while on the road, would an acceptable temporary fix be to wrap one or two large zip ties or even duct tape around the tank to keep it secure? Something like this(ish):
'85 Vanagon Westy - George In the Stable 2020-?/'74 Weekender - Ophelia In the Stable 2007- ?/'69 Beetle Convertible - SOLD 2017-2020/'67 Beetle - September SOLD 2013-2016 /'67 SO42 Westy - Sage SOLD 1996-2001 /'69 Transporter - Baby Blue SOLD 1995-1995/'72 Westy - Nelly - SOLD 1990-1995--STOP FRACKING |
