BCE56 Samba Member
Posted: Wed Aug 18, 2021 5:27 pm Post subject: Re: Official lazy person's stupid question thread |
Drove the Syncro to work this morning.
At lunchtime it cranked but no start.
Checked fuses- OK.
Listened to fuel pump- inop.
Whacked the pump (to encourage it.) Nope.
Checked terminals- OK.
Checked current to pump- none.
Stymied.
Fuel pump relay? _________________ =BCE56=
'86 Syncro tintop
EJ22, OBD II early SC adapter plate conversion
Side project: '69 Frankenbug "It's alive!" |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Wed Aug 18, 2021 9:26 pm Post subject: Re: Official lazy person's stupid question thread |
^^^ Yes, could be.
Try swapping it with the other one in the same relay box & report back.
Could also be the dedicated pump ground near the fuel tank...feel free to add a solid new ground anywhere on the frame.
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
BCE56 Samba Member
Posted: Fri Aug 20, 2021 9:36 am Post subject: Re: Official lazy person's stupid question thread |
^^^ Yes, could be.
Relay box factory location was on driver side of engine well I believe. It was apparently relocated (deleted) by P.O. during Subie conversion to make room for air filter box.
Current location is unknown.
I will see if SmallCar can help.
LATER: Mao at SC says "fuel pump relay is on the Subie ECU board. There are two relays- the round, silver is fuel; the rectangular, brown one is "everything else." They should both click when ignition is switched on."
LATER ER: Bought a relay from FLAPS (JIC I got lucky.)
Checked the relay, it clicked when ignition switched to RUN.
Now what?
Wiring fault between relay and pump?
It would have been a relatively painless fix.
EVEN LATER:
Double checked, both relays (fuel pump and main) click when key on.
No CEL.
But OBD II scanner does not come on, with or without key on... _________________ =BCE56=
'86 Syncro tintop
smeeegheeead Samba Member
Joined: February 19, 2021 Posts: 48 Location: Portland, OR
Posted: Sat Aug 28, 2021 10:14 am Post subject: Re: Official lazy person's stupid question thread |
86' 2.0 with an automatic transmission.
New high torque cool guy starter has one spade connection whereas the prior starter has two. Do you only run the black/red connector and the other is negated now or? Seems weird. |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4536 Location: Arizona Highways
Posted: Sat Aug 28, 2021 12:48 pm Post subject: Re: Official lazy person's stupid question thread |
just attach both the wires to the single spade _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Sat Aug 28, 2021 7:08 pm Post subject: Re: Official lazy person's stupid question thread |
borninabus wrote: |
just attach both the wires to the single spade |
See, I was thinking that.. then thought "It's a, VW it's never that easy." But here we are. |
Posted: Sat Aug 28, 2021 8:36 pm Post subject: Re: Official lazy person's stupid question thread |
I think the second wire just tells the ECU that the starter is engaged, so the current flow is nil. The extra terminal-circuit comes in handy when the loads on the second wire are higher as they are in some applications. |
ProspectiveOwnergon Samba Member
Posted: Sun Aug 29, 2021 10:03 pm Post subject: Re: Official lazy person's stupid question thread |
Why doesn't my 1990 dash have an OXS label? I've only got 4 logos/labels/stickers |
DuncanS Samba Member
Posted: Mon Aug 30, 2021 6:08 am Post subject: Re: Official lazy person's stupid question thread |
Bentley 97.211--What do the initials NSL on the headlight switch stand for? Is there a switch terminal for this connection and what would it do? I understand it would be routed through the ignition switch and not be active during starter cranking. Perhaps trigger an additional load reduction relay? |
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
Posted: Mon Aug 30, 2021 6:19 am Post subject: Re: Official lazy person's stupid question thread |
Nebelschlussleuchte = rear fog lamp
The light switch triggers an optional relay to enable power to the optional fog light switch. _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
Posted: Mon Aug 30, 2021 8:14 am Post subject: Re: Official lazy person's stupid question thread |
Tnx T3 Pilot. I'll use that When I rework the ignition/start circuit. Haven't checked the switch yet, but will look for that marking. I could use that lead for when I get around to reworking the ignition/start switch. In the meantime this is the light switch I'm going to use. Check out the beefiness of the dash light dimmer. This shouldn't experience the failures the OG dimmer is subject to.
kamzcab86 Samba Moderator
Posted: Mon Aug 30, 2021 8:44 am Post subject: Re: Official lazy person's stupid question thread |
ProspectiveOwnergon wrote: |
Because VW eliminated the OXS mileage counter box in late 1987, after equipping their vehicles with a 3-wire O2 sensor, which also increased the change interval from 30,000 miles to 60,000 miles. _________________ ~Kamz
2016 Golf GTI S
Posted: Mon Aug 30, 2021 9:26 am Post subject: Re: Official lazy person's stupid question thread |
kamzcab86 wrote: |
Because VW eliminated the OXS mileage counter box in late 1987, after equipping their vehicles with a 3-wire O2 sensor, which also increased the change interval from 30,000 miles to 60,000 miles. |
My 91 had the counter box. After the light came on while I was changing lanes on a dark rainy night on an interstate bridge during rush hour, the counter (a true IDIOT BOX) got disabled. |
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Mon Aug 30, 2021 11:50 am Post subject: Re: Official lazy person's stupid question thread |
The "idiot box" as you called it was required by federal regulation not the whim of VW. Its' elimination was triggered when emission components were first required to be warrantied for 100k miles thus moving the cost for replacement of the 0² sensor to VW. All of a sudden they lasted longer, read between the lines 🤑. _________________ Schau in das Buch |
Posted: Tue Aug 31, 2021 6:09 am Post subject: Re: Official lazy person's stupid question thread |
Replaced my windshield wiper switch as my 30 year old hi/lo beam component had failed after repair. $75 plus shipping. Came a week later from Rock Auto. Very flimsy compared with the OEM part. My guess is RA price would have been less than half. First time ever BD has let me down. Very disappointed
But never the less, when looking at the OG part I noticed these contacts. There are two fixed ones on either side of the center contact. Bottom one doesn't show. No matter how I articulate the lever, I can't get the the center to contact either of the fixed portions.
What does this do? What is the intent and how does it ever make contact?
Posted: Tue Aug 31, 2021 10:18 am Post subject: Re: Official lazy person's stupid question thread |
Washer motor contact. Also turn winpers on for 2 strokes or so. _________________ Schau in das Buch |
Posted: Tue Aug 31, 2021 11:22 am Post subject: Re: Official lazy person's stupid question thread |
Thnx |
turbotype1 Samba Member
Posted: Tue Aug 31, 2021 11:24 am Post subject: Re: Official lazy person's stupid question thread |
DuncanS wrote: |
Just FYI ... The quality of those chinese switches are JUNK !! you better order a spare _________________
117harv wrote: |
This new fad of get it the lowest, or run it with the worst looks, (patina) isn't cool, it's for the hey everyone look at me crowd, i'm driving a beat down ratty, unsafe, VW, how cool am I ???...your not....
Pissing off the purists since 1997
Wanted: Boyd Motors plate frame
57 Turbo Oval Sliding rag
67 13 window delux walk-thru- now 21
64 all original for the misses
83 Sinka m-TDI diesel |
Robsmaze Samba Member
Posted: Sat Sep 04, 2021 5:52 am Post subject: Re: Official lazy person's stupid question thread |
So…
I’ve been stuck waiting for parts for a couple of weeks from GoWesty. I got my little beauty of a restoration project from a neighbor - where it sat for 16 years. I got the engine to start (after changing all the ignition components, fuel lines, fuel pump, etc…). Could only run it for 30 seconds because I have no coolant. But I have decent compression and when it does run it sounds great!
Now I’m waiting on gowesty for a radiator and associated other suspect coolant hoses, a new pop top, an ATF cooler kit, front and rear wheel bearings (so I can’t work on the brakes past where I have gone), oil sensors, coolant sensors, wheels and a slew of other stuff.
WHAT ELSE CAN I WORK ON whole I wait? It’s been a couple weeks since my order so I’m sure they will ship soon. But..
There must be something I can tear apart and clean without any parts in hand that would be a great idea. I thought about trying to tear apart the propane system and see if the tank is worth saving. Any other ideas? I’ve literally cleaned and painted every component I’ve removed with the intention of putting back on. Even my new front brake calipers are RED!! Any ideas?? _________________ ‘87 2WD 2.1L Westy
‘87 2WD 1.7L Diesel Doka (euro spec) |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32592 Location: Reading Pennsylvania
