jimf909 Samba Member
Posted: Thu Dec 28, 2017 10:12 pm Post subject: Re: Official lazy person's stupid question thread |
danfromsyr wrote: |
yes it is a 17mm socket..
make sure you can open the fill plug before you touch the drain plug.
Since this is the LPSQT, why not just flip the van over if you can’t get the fill plug out? _________________ - Jim
Abscate wrote: |
Paulbeard Samba Member
Posted: Thu Dec 28, 2017 10:21 pm Post subject: Re: Official lazy person's stupid question thread |
jimf909 wrote: |
Since this is the LPSQT, why not just flip the van over if you can’t get the fill plug out? |
I considered it but I could have used some help and I didn't have your number… _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2426 Location: Der Vaterland
Posted: Thu Dec 28, 2017 10:47 pm Post subject: Re: Official lazy person's stupid question thread |
Zeitgeist 13 wrote: |
The size is nice, but it's just the tips that make the first impression. |
_________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
kamzcab86 Samba Moderator
llilibel03 wrote: |
Ok another stupid question- if I deflate tires to navigate washboard roads, how long would it take to reinflate them with a bicycle pump? |
It took a guy on YouTube 5 minutes to inflate a flat 16" Ford Taurus tire to 30psi with a floor hand pump. YMMV. _________________ ~Kamz
2016 Golf GTI S
Posted: Thu Dec 28, 2017 10:52 pm Post subject: Re: Official lazy person's stupid question thread |
Paulbeard wrote: |
jimf909 wrote: |
I considered it but I could have used some help and I didn't have your number… |
Oil changes are easy with a rotisserie...
https://www.thesamba.com/vw/forum/viewtopic.php?t=175412
Abscate wrote: |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4353 Location: United States, Iowa
Posted: Sun Jan 07, 2018 8:55 am Post subject: Re: Official lazy person's stupid question thread |
I have my fridge out. Figured I would test it on LP, since that was the reason I took it out and went to town taking it apart and cleaning it all out.
Stupid question:
Can the LP function work without any of the electrical bits hooked up? I.E. outside the van with a 20# tank // grill regulator only?
And the Lazy part: how long do I have to hold the override button in to get the air purged from the LP line? Is there a lazy solution to hold it down for that long? I get bored, and my finger gets sore after a while.
PS. Mine is the manual push to ignite, not the auto that requires 12V
EDIT: I see Dave Vickery did something, but I can't quite tell if he has power feed somewhere else, but there looks to be jumper in one connector.
_________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
DometicLover Samba Member
Posted: Sun Jan 07, 2018 12:54 pm Post subject: Re: Official lazy person's stupid question thread |
bobbyblack wrote: |
Stupid question:
No electricity needed, but you need the thermocouple installed.
I hold the button for 10sec after the flame is on. This is long enough to heat the thermocouple that creates tiny bit of electricity that hold the valve open. |
Posted: Sun Jan 07, 2018 4:14 pm Post subject: Re: Official lazy person's stupid question thread |
Ok, being convinced enough that 12V not necessary, again tried. Held button in for stupid long (like 3 minutes) and no joy.
So, I took the feed line off of at the joint that connects to the jet. Gas on at tank, gas valve on on fridge, flame to full, thermocouple defeat button depressed for stupid long again. No LP coming out of feed tube... Stupid, boring, and I'm STILL Lazy AF. Must be another lazy trick I need to engage. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
designer Samba Member
Joined: November 05, 2009 Posts: 484 Location: Idaho-but just the tip
Posted: Mon Jan 08, 2018 5:10 pm Post subject: Re: Official lazy person's stupid question thread |
I can't find anything in the search for "air compressor" that relates even half way to what i'm asking.
Where do people mount their "air compressor" to re-inflate tires / blow up paddle boards, etc?
Thinking of the middle model ARB one.
Thanks! _________________ __________
87 Syncro Westy : 2.5l
"It is that annoying, accelerating downhill so I can make it up the next hill in the same gear. Foot to floor hoping I can get out of the way of other cars getting onto the highway." - somebody on here around 2013. |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3803 Location: VA/TN
Posted: Mon Jan 08, 2018 6:49 pm Post subject: Re: Official lazy person's stupid question thread |
A guy that lives near recently installed his in the rear engine compartment. He has a Subaru conversion.
It's really cool he pulls back his license plate to access a switch. He has a quick release mounted on the outside near his license plate.
He is a member here on the samba but his Instagram tag is ntaramorris _________________ Brandon
Instagram @joannthevan |
Posted: Mon Jan 08, 2018 7:30 pm Post subject: Re: Official lazy person's stupid question thread |
bobbyblack wrote: |
So, I took the feed line off of at the joint that connects to the jet. Gas on at tank, gas valve on on fridge, flame to full, thermocouple defeat button depressed for stupid long again. No LP coming out of feed tube... Stupid, boring, and I'm STILL Lazy AF. Must be another lazy trick I need to engage. |
You got it all good, assuming there's gas in the bottle. One of my plastic knob cracked. It felt like I was opening and closing the valve, but it wasn't. Maybe worth removing the plastic knob and make sure the valve are really ON. |
Posted: Mon Jan 08, 2018 11:40 pm Post subject: Re: Official lazy person's stupid question thread |
designer wrote: |
Thanks! |
Are you using the google search window in the upper right?
Not the useless “search this forum...” search window in the upper left. That search is useless.
When typing in “air compressor vanagon” in the google search window (upper right) I found this from the always awesome kourt (and a few other threads):
https://www.thesamba.com/vw/forum/viewtopic.php?p=7873683 _________________ - Jim
Abscate wrote: |
katzenjammer Samba Member
Joined: September 22, 2005 Posts: 113 Location: Santa Cruz
Posted: Fri Jan 19, 2018 4:28 pm Post subject: Re: Official lazy person's stupid question thread |
I'm stupid & lazy, so this must be where I belong.
I'm installing a powered antenna (goes up and down with the radio switch) and trying to decide where to get the 12v positive "always on" supply. Poking around behind my fuse panel (a total rats nest), I find several red wires that test positive with the ignition off, but I have no idea what any of them is. Is there any reason I shouldn't just tap one and hope for the best? The antenna has it's own 5amp in line fuse on the red wire.
Thanks. _________________ 1990 Westy Multivan, Auto (3.08 R&P) 1.8T by SAH |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Fri Jan 19, 2018 5:08 pm Post subject: Re: Official lazy person's stupid question thread |
designer wrote: |
Thanks! |
Viair 400p. Half the price of ARB, quiet, powerful, comes in a cool canvas bag (with plenty of room for your tire repair kit and two cans of fix-a-flat if you need it,) fits perfectly under the bench seat, and pumps up our SUPs in well under five minutes.
https://www.amazon.com/gp/product/B000X9AXR8/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
SUP valve stem adapter, works for us on two different types of SUPs:
https://www.amazon.com/gp/product/B017HTD8BO/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Sooo much better than using a backbreaker manual pump. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
elizer Samba Member
Joined: May 02, 2016 Posts: 1469 Location: Northern Virginia
Posted: Fri Jan 19, 2018 7:05 pm Post subject: Re: Official lazy person's stupid question thread |
I have the Viair 400p. It really is nice. The canvas bag keeps everything organized. One thing don't touch the body after you used it for a while or you will get a nice burn. I did it without thinking. |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2332 Location: Southeast Kentucky
Posted: Fri Jan 19, 2018 7:49 pm Post subject: Re: Official lazy person's stupid question thread |
Clutch Master Cylinder (1984 Vanagon)
Does anyone know what the Inside Diameter of the hose is from the Clutch Master Cylinder up to the fluid reservoir?
I need to install a new Clutch MC and believe the hose should be replaced as well. _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
Posted: Wed Jan 24, 2018 9:54 am Post subject: Re: Official lazy person's stupid question thread |
AndyBees wrote: |
I need to install a new Clutch MC and believe the hose should be replaced as well. |
7mm ...... inside diameter! Overall outside diameter is 13mm.
Thanks! _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
Posted: Fri Jan 26, 2018 1:07 pm Post subject: Re: Official lazy person's stupid question thread |
My e-brake cable takes like 4-5 clicks before it's 'active'.
I understand it could be tightened - but I figure I'd go ahead and replace the cables and rebuild the rear brakes.
I bought new:
-rear brake shoes
- drum brake brake hardware kit
-2 cylinders
-both ebrakes cables
4x Rubber Plug for Rear Brake Backing Plate
I am keeping the same drum. The van has 120k miles and it seems to be stopping alright. Is this alright or should I replace the drums while I am at it. Or is there anything I am missing? _________________ Brandon
E1 Samba Member
Joined: January 21, 2013 Posts: 6583 Location: Westfalia, Earth
Posted: Fri Jan 26, 2018 1:14 pm Post subject: Re: Official lazy person's stupid question thread |
Mine takes four clicks and it's fine.
But if anyone doesn't know, hearing the clicks means unnecessary wear-and-tear. Pushing the button in when engaging eliminates the wear.
Signed,
Super Stupid _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
llilibel03 Samba Member
Joined: February 03, 2008 Posts: 767 Location: Redondo Beach California
Posted: Fri Jan 26, 2018 1:45 pm Post subject: Re: Official lazy person's stupid question thread |
Here's a stupid one- I have a tiico. What exactly does tiico stand for? _________________ 87 syncro tintop
90 gl tin top
85 westy 2.0 tiico automatic (present) |
