CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Sat Sep 09, 2017 5:27 am Post subject: Help - Brake Line Connector Need part # or where to find source |
Looking for the part number or where I can find this part. It is the connector between the rubber brake line and the hard metal brake lines. I have tried to loosen this part with no luck. I applied heat, penetrating oil, and brute strength. I would like to just cut it away and get a new one. Can anyone point me in the right direction ?
Thanks |
bhartwell59 Samba Member
Joined: December 28, 2014 Posts: 788 Location: dallas, tx
Posted: Sat Sep 09, 2017 6:02 am Post subject: Re: Help - Brake Line Connector Need part # or where to find source |
you mean that springy u-shaped clip? _________________ '74 Zambezi green Ghia vert, autostick, 101k
'87 Jeep Wrangler, 4.2, 330k |
allenw Samba Member
Joined: September 20, 2016 Posts: 221 Location: Dalton, GA
Posted: Sat Sep 09, 2017 6:10 am Post subject: Re: Help - Brake Line Connector Need part # or where to find source |
That is part of the rubber brake hose, just order new hoses. |
Posted: Sat Sep 09, 2017 6:32 am Post subject: Re: Help - Brake Line Connector Need part # or where to find source |
Nope, I cut the rubber brake line to get a better grip on the connector. The rubber lines are being replaced with stainless steel lines. In fact everything down to the wheel bearing is being replaced.
bhartwell59 wrote: |
you mean that springy u-shaped clip? |
No it's the connector that passes through the "springy u-shaped clip" _________________ ----------------------
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3907 Location: In Molinya Orbit
Posted: Sat Sep 09, 2017 6:53 am Post subject: Re: Help - Brake Line Connector Need part # or where to find source |
sputnick60 wrote: |
Can I presume You've placed a spanner on the hard line and turned it counter clockwise while a Vyse Grip is holding the connector where it's showing numerous scratches?
Nicholas |
Yes I tried that even put a pipe on the other wench. Used heat and oil. Borrowed the guy across the street, no luck. It's fused together. _________________ ----------------------
Posted: Sat Sep 09, 2017 7:02 am Post subject: Re: Help - Brake Line Connector Need part # or where to find source |
I have not tried the hard-line side. But everything doing with anything concerning the brakes is being replaced. The connector doesn't seem to be able to pull through the clip _________________ ----------------------
Posted: Sat Sep 09, 2017 7:09 am Post subject: Re: Help - Brake Line Connector Need part # or where to find source |
As soon as I get home I will try that thank you. I still need the connector it is mangled from the vice grip, wrench and whatever. _________________ ----------------------
Posted: Sat Sep 09, 2017 7:26 am Post subject: Re: Help - Brake Line Connector Need part # or where to find source |
I had a hard time with that part too... a 50/50 mix of ATF+acetone helped me. _________________ '74 Zambezi green Ghia vert, autostick, 101k
Posted: Sat Sep 09, 2017 7:46 am Post subject: Re: Help - Brake Line Connector Need part # or where to find source |
I had a hard time with that part too... a 50/50 mix of ATF+acetone helped me. |
Unfortunately, I managed the part so I need to find a replacement.
Nicholas, I fully understand where everything goes, I just need the replacement connector. I can cut the piece off in 5 seconds.
I am doing a body off restoration of a 1970 convertible. I have replaced the pans, strengthen the Napoleon hat with some small angle, even welded closed a small hole I found in the front beam. I have purchased every part for the brakes, including a duel reservoir master cylinder, but that damn connector _________________ ----------------------
Posted: Sat Sep 09, 2017 7:58 am Post subject: Re: Help - Brake Line Connector Need part # or where to find source |
I don't mean to sound insulting, sorry if it came accross that way. I'm probably confused about what you mean by the connector. I added photos to help make the problem clearer. The bit held by the clip in the support is swaged to the flexible hose. This is equivalent to the bit you've mangled. It won't come off the hose.
So sorry this isn't a help
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Era Vulgaris Samba Member
Joined: August 22, 2012 Posts: 1662 Location: Raleigh, NC
Posted: Sat Sep 09, 2017 8:32 am Post subject: Re: Help - Brake Line Connector Need part # or where to find source |
There is no "connector". That's the end of the flex hose that's screwed onto the hard line.
Remove the u-shaped clip from the body mounting tab. The end of the hose doesn't pull through the tab, it slides out after you remove the u shaped clip. That clip holds the end of the flex hose in place.
_________________ Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue
Posted: Sat Sep 09, 2017 8:49 am Post subject: Re: Help - Brake Line Connector Need part # or where to find source |
I'm currently amassing parts for a brake overhaul myself. I just snapped this pic of the end of the flex hose. This is your connector.
That little 2mm slot at the head is what the U shaped clip slides into. I think you've been trying to unscrew the end of the flex hose from itself!
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Sat Sep 09, 2017 9:03 am Post subject: Re: Help - Brake Line Connector Need part # or where to find source |
CiderGuy wrote: |
The rubber lines are being replaced with stainless steel lines. |
I think this is causing the confusion because the stainless braided hoses have different fittings to the original hoses. I was going to install stainless hoses on my bus but decided not to use them because the fittings were different and I wasn't convinced they fit properly. Also after some research I found that stainless hoses weren't any good (there is a thread on here somewhere which explains why) so I used rubber hoses and I suggest you do the same. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
Posted: Sat Sep 09, 2017 9:10 am Post subject: Re: Help - Brake Line Connector Need part # or where to find source |
Era Vulgaris wrote: |
I'll try that as soon as I get home. I do hope you're correct about no connector, but even so nothing is coming apart. _________________ ----------------------
Posted: Sat Sep 09, 2017 9:12 am Post subject: Re: Help - Brake Line Connector Need part # or where to find source |
Mellow Yellow 74 wrote: |
CiderGuy wrote: |
I think this is causing the confusion because the stainless braided hoses have different fittings to the original hoses. I was going to install stainless hoses on my bus but decided not to use them because the fittings were different and I wasn't convinced they fit properly. Also after some research I found that stainless hoses weren't any good (there is a thread on here somewhere which explains why) so I used rubber hoses and I suggest you do the same. |
I have the stainless hoses already, I'll check if that is true. I hope you're wrong about this ...... _________________ ----------------------
Posted: Sat Sep 09, 2017 9:16 am Post subject: Re: Help - Brake Line Connector Need part # or where to find source |
CiderGuy wrote: |
I'll try that as soon as I get home. I do hope you're correct about no connector, but even so nothing is coming apart. |
It's not turning because that u shaped clip holds everything tightly in place (and they can be a bitch to remove if they start to rust onto the body mounting tab!). You need to remove the clip and pull the end of those out of the tab before you try to unscrew it from the hard line. There's no way your going to get it loose until you remove the u shaped clip. _________________ Currently own:
Previously owned:
