Choke Cable woes - 1949 Standard.
Terra45
Terra45 is offline
PostPosted: Sat Sep 09, 2017 9:35 am    Post subject: Choke Cable woes - 1949 Standard. Reply with quote
Hi,
Wondered if anyone knew the cable length of the standard 'L' Choke cable? I've had a new cable fitted to my existing original handle as pictured and no matter what I do it does not appear at the exit point of the chassis where the accelerator and clutch cable come out of.
I thought it might be going into the space in the chassis through a rusted tube, but have put a camera in the chassis tunnel and have not seen any evidence of this.
Could it be going back on itself in the tube?
The cable is 100 inches long / 2540 mm approx, which looks long enogh.
I've spent several hours I'll never get back on trying to get it sorted Sad
Any help / advise would be most appreciated.
*Cheers*
Leon.
October 1949 Standard.
nlorntson
Crazy VW Lady
nlorntson is offline
PostPosted: Tue Sep 12, 2017 4:31 am    Post subject: Re: Choke Cable woes - 1949 Standard. Reply with quote
Run it in from the back forward to see if it some out where you expect.
