Tcash Samba Member
Posted: Sat Sep 09, 2017 11:29 am Post subject: Turn Signal Switch 1968-71 T2 ID FAQ |
To link to this thread copy and paste
Code: |
[url=https://www.thesamba.com/vw/forum/viewtopic.php?t=686232&start=0&postdays=0&postorder=asc&highlight=]Turn Signal Switch 1968-71 T2 ID FAQ[/url] |
211 953 513 G 8 wire Turn Signal Switch USA/Canada
211 953 513 F > 513 H > 211 953 513 G = SWF HLS 66 - SAE Q 67
? 211 953 531 C 8 wire turn signal switch?
Wiring diagrams
https://www.thesamba.com/vw/archives/info/wiringt2.php
Click on pics or Right click and open in another tab
1970 Turn signal Highlight
1971 Turn signal Highlight
Early bay turn signal switch wiring
Aftermarket switch wiring. So you got a new switch. But the colors don't match.
Turn signal switch clearance
Headlight Dip (dimmer) switch contact points.
When you pull up on the lever, this set of contact points close and switch the headlight Dip relay from Low<-->High beam and vise versa with each pull of the lever.
211 953 531 C 8 wire: This switch has showed up in 68-71s. But I was unable to find any information in the parts manuals or internet at the time of writing
Special Models 211 953 531 D 5 wire: This switch was used on Special models.
https://www.thesamba.com/vw/gallery/pix/1405620.jpg
5 wire Special model wiring diagram
https://www.thesamba.com/vw/archives/info/wiring/8_67_bus_special_models_key.jpg |
