driverdave Samba Member
Joined: October 15, 2014 Posts: 66 Location: Denver, CO
Posted: Thu Sep 07, 2017 1:49 pm Post subject: Vanagon Evasive Maneuvering |
Was really surprised how well the van handled during some recent evasive maneuvering. Van was fulled loaded with camping gear, full tank of gas, full water tank, toddler in the car seat, etc... The only non stock item in the mix were the Bilstein HD shocks up front.
I was going around 45 when someone pulled out in front of me from a side street making a left. I hit the horn and he ended up flooring it, which was probably the best decision for where he was, no way I could have stopped in time. I hit the brakes and veered right. Locked up the front a little. The van handled quite well, didn't do anything unexpected. Luckily for all we avoided each other.
If the road had been wet and not dry, this would have ended much worse. My big takeaway is to go a little slower in traffic, and expect long stopping times when fully loaded. _________________ 1984 Vanagon Westy with a 91 EJ22 KEP Conversion |
bobbyblack  Samba Member
Joined: May 21, 2015 Posts: 4694 Location: United States, Iowa
Posted: Thu Sep 07, 2017 2:04 pm Post subject: Re: Vanagon Evasive Maneuvering |
One of my biggest fears is that somehow people don't either:
1: see me
2: believe I can be going fast enough that they need to wait for me to go past.
On the Highway, I have a real issue with drivers who think that because I have a 2 second gap in front of my rig and the next car ahead, that they need to pass me. Then, they are stuck behind the wagon train of cars I was being careful to avoid with a proper following distance.. AND, I have to fall back another second or two.
Since I saw Sanchius' T-Bone, I've added a strip of LED's along the roof gutter rail, and use them and the headlights ON while running. MAYBE it will help me not get smashed.
I took my idea from Abel Longoria, but did this:
_________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
E1 Samba Member
Joined: January 21, 2013 Posts: 8748 Location: Westfalia, Earth
Posted: Thu Sep 07, 2017 2:17 pm Post subject: Re: Vanagon Evasive Maneuvering |
Good job!
Sounds like you didn't panic and that's Uge.
Being we're driving a tank and I have a lifetime of racing behind me, I tend to envision scenarios more than most. I've long pictured a situation like yours but at more speed, and would hope for a wet road if a T-bone was inevitable — so I could pull the e-brake and whip a 180 to hit rear-end first. No way I'd ever want to rely on my front end, protection-wise, if going over maybe 40. I'd do it in the dry if forced to, but more delicately to avoid a barrel roll (another reason to avoid soft tires, people!).
We had a deal going up Kenosha Pass, Colorado in 1997. Pouring rain, right-hand bend under a cliff, going maybe 50, then an oncoming car blazes full brights on me. Maybe a half a second went by while I shielded my eyes, when clear the F-Bomb whipped out as I realized a three-foot-high boulder was directly in our path. Oncoming lane was full, head-on inevitable, so pitched the car about 30 degrees right in the hopes of riding atop the boulder to a parking spot barely wide enough for a car under the cliff. Impossible, and barely a tenth of a second to strategize the move.
But it worked perfectly, the car was a foot off the ground up front and parked parallel to the road plus or minus a foot of perfect — 200 feet after impact. And the only reason was I'd made hundreds of split-second moves while racing, and watched others make hundreds more trackside. Point being, there's only one way to gather these skills, and that's with speed and/or experience. While I don't recommend such "training" on the highway, but for most that's the only option.
I told my move to the cop and he assumed I was really out there. A friend riding shotgun found the point of impact and a straight-line road gouge that was pointing out the 30-degree angle change and leading to our car. We'd saved lives most likely, and our insurance went DOWN for it. The cop shook my hand and thanked me.
While the cars drug the rock under it, the Missus awoke in the back seat and asked "WHAT'S THAT NOISE???!!!"
Ten minutes on, a guy showed up and asked if I'd seen the boulder. I said, "NO, some idiot blinded me!!!" He looked stunned, it meant little to me then, then he said "Oh…." and walked away. I think it was Mr. Highbeams.
The car was totaled, a 1992 Nissan Stanza SE (next year re-badged as an Infiniti when the Altima came on). We loved that car, but were glad to lose it instead of us three.
Point of all this, find a way to up the game so you have options when things go wrong. This is but one of several times my racing saved our bacon. Our country sucks at driver training, thinking speed in of itself as reckless when in fact it's the best safety trainer.
I've driven way over a million miles and went 39.5 years without ever contacting another car — until last January at Buses by the Bridge. A story two here know about, including me.  _________________ If ever twice as rich, we’re gettin’ a double-wide
’84 “Westfailure”/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
The caveman’s first question to the headhunter: “Hey, you got any coffee?” |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32988 Location: Reading Pennsylvania
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3461 Location: OR & CA (Oregon/California)
Posted: Thu Sep 07, 2017 3:11 pm Post subject: Re: Vanagon Evasive Maneuvering |
same here...
I see them OK but the question is: Do They See me...?
btw, I heard that in Japan, if someone involved in an accident and the driver says that he/she didn't see the other party... then it's jail time... |
E1 Samba Member
Posted: Thu Sep 07, 2017 3:18 pm Post subject: Re: Vanagon Evasive Maneuvering |
That's a huge issue with tan and silver cars.
The same reason that red or yellow cars get tickets make them safer in being seen. I think car color is more important than lights, but both are awesome.
Looks like 0to60 and IdahoDoug may outlive us all.  _________________ If ever twice as rich, we’re gettin’ a double-wide
RainierSyncro Samba Member
Joined: February 26, 2013 Posts: 816 Location: Seattle
Posted: Thu Sep 07, 2017 3:53 pm Post subject: Re: Vanagon Evasive Maneuvering |
On my old van, I used 1/4" reflective tape. I put 5" strips on all 4 corners. The thin size is not noticeable during daylight, but at night it reflects a ton of light.
Here's a strip of it on top of the back window during my Denver trip.
E1 Samba Member
Posted: Thu Sep 07, 2017 4:16 pm Post subject: Re: Vanagon Evasive Maneuvering |
I'm a firm believer that too much of a good thing becomes a distraction when following behind for miles. Witness "rear end full of tail lights" on some cars out there, it's all I can do to not be lulled into reliving bits of my life.
I'm putting a reflective Kokopelli or perhaps a comic shape atop the rear of my cargo box. Greatest point of worry for me is someone racing up over a hilltop and the highest point wins. _________________ If ever twice as rich, we’re gettin’ a double-wide
E1 Samba Member
Posted: Thu Sep 07, 2017 4:24 pm Post subject: Re: Vanagon Evasive Maneuvering |
campism Samba Member
Joined: September 07, 2007 Posts: 4711 Location: Richmond VA
Posted: Thu Sep 07, 2017 5:19 pm Post subject: Re: Vanagon Evasive Maneuvering |
Coming back from the Finger Lakes on I-81 in Pennsylvania we were tooling along in the slow lane in moderate traffic when a white SUV fell from the sky into our lane. It did not really fall from the sky but looked like it when the vehicle that had been on the road adjacent to the highway lost control and plunged off the hillside. Could not go left due to other cars so stood on the brakes, then let off and dodged right into the breakdown lane where I hit some loose Murano parts, then stopped a little farther on and ran back to render assistance. I was very pleased with the van's handling under duress.
_________________ '87 Westy in Wolfram Grey Metallic, tragically crushed by a falling hickory tree in my own driveway and now gone, leaving me Vanagonless and with no plans to replace it, alas. |
hdenter Samba Member
Joined: October 14, 2008 Posts: 2961 Location: San Luis Obispo, CA
Posted: Thu Sep 07, 2017 6:04 pm Post subject: Re: Vanagon Evasive Maneuvering |
Just a few months ago a guy started to turn left in front of me and then just stopped half way across my lane. I brakes hard for as long as I could, then steered around his front end. The van handled great. I helps that I have a rear sway bar and BMW 4 pot front calipers. But man, that's the closest I've come to creaming someone in a while. The next day when I drove past the same spot, I could see that my brakes locked up evenly at first stomp and the van went perfectly straight until I eased off and made the move to go around him. I couldn't of done it better in a sports car...
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6933 Location: Fort Lauderdale, Fl.
Posted: Thu Sep 07, 2017 10:58 pm Post subject: Re: Vanagon Evasive Maneuvering |
| RainierSyncro wrote: |
I use SOLAS reflective tape,(Safety of Life at Sea) It has a different pattern to it which I think is better at reflecting light then the reflective tape found in most stores. A marine chandler such as West Marine would carry it.
It looks like this, never mind the outrageous price as you can usually find it in cut strip lengths.
https://www.westmarine.com/buy/3m--scotchlite-solas-reflective-material--3761871
https://www.westmarine.com/buy/taylor-made--scotch..._-PDP-Test _________________ This free advice is worth exactly what you paid for it.
Bills85Westy Samba Member
Posted: Thu Sep 07, 2017 11:13 pm Post subject: Re: Vanagon Evasive Maneuvering |
Re: Evasive Maneuvers.
Whenever I see the hippies start going for my van, I either run like hell or beat them off with my yoga mat....
 _________________ 89 Tristar Syncro Doka - White
85 Westfalia Syncro (conversion)
SAH 1.8T Conversion - 2005 AWP
Engine Conversion Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=612144&highlight=
85 Doka L345 Grey - 1.9L |
E1 Samba Member
Posted: Thu Sep 07, 2017 11:22 pm Post subject: Re: Vanagon Evasive Maneuvering |
Ouch.
(if I read this right) _________________ If ever twice as rich, we’re gettin’ a double-wide
calfredson Samba Member
Joined: January 21, 2015 Posts: 70 Location: Vancouver, BC
Posted: Fri Sep 08, 2017 4:53 am Post subject: Re: Vanagon Evasive Maneuvering |
This is my biggest pet peeve:
| bobbyblack wrote: |
Posted: Fri Sep 08, 2017 5:10 am Post subject: Re: Vanagon Evasive Maneuvering |
some would think I am "parano" when I put reflective tape on the rear bumper of my van...
but when I think that out there some people drive with half their eyes on the road and the other half on their cell phone awaiting incoming texting messages...
now that's scary...  |
