capoz43 Samba Member
Posted: Tue Sep 12, 2017 9:22 am Post subject: Propex Heater without body mounted tank? |
I have an 86 weekender and am planning to install a Propex heater. The weekender doesn't have the propane tank on it and I really don't need to have the propane tank on the body of the vehicle. I would like to set up the heater to plug directly into a 1 gallon aux tank. The standard tanks are way cheaper and I'll only be using the heat when I'm set up at camp. I'd have the tank outside the vehicle of course and probably just set it on the ground at camp...maybe on a bumper mount.
Is there a way to set up the gas line for the Propex heater so I can just screw in a hose to connect to a standard tank without having the body mounted tank as well?
Thanks!
- matt |
calfredson Samba Member
Joined: January 21, 2015 Posts: 70 Location: Vancouver, BC
Posted: Tue Sep 12, 2017 10:08 am Post subject: Re: Propex Heater without body mounted tank? |
My propex is connected to a 20lb BBQ style propane tank. The crux of the operation is figuring out how to plumb the propane lines from the bumper to the Propex. I purchased all the necessary tools and parts at a local propane supply store. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16508 Location: Brookeville, MD
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Tue Sep 12, 2017 10:39 am Post subject: Re: Propex Heater without body mounted tank? |
One thing to think about is coming up with some way that it is impossible to drive off with the tank just dangling there! I know I'm ADHD and forgetful enough that I've decided to move the Bus while camping or something like that and forgotten to unhook or move things a time or two.
A couple ideas to get the creative juices flowing:
Set it up so that the tank is secure just in case you do drive off. So maybe some kind of strap that holds it up to the underside of the Van? If it was a positive, secure connection you could potentially have the option of deciding to use the heater when driving if you ever wanted to.
Set up the connection inside a cabinet in the Van. I altered my Bus's stove connections to use 1 lb cans inside the cabinet. This would be a simiilar setup and again would allow the option of using the heater if ever needed.
You'd probably want to protect the propane connection at the heater. So if it was a cap or something you had to take off, you could just make sure that you remove the cap, strap it on to the steering wheel or over the ignition switch before even connecting the propane tank. Then it would be difficult to move the Van without seeing the cap. You'd have to be self-controlled enough to stay in the habit of putting the cap on the wheel or whatever. I know I'd probably be tempted to hook up the propane, then would set the cap down and forget all about it.
I sometimes use the stock jack to level my Bus when camping, so I always drape it's carrying bag over the steering wheel so I don't forget and try to move the bus or something. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22671 Location: NYC/Upstate/ROW
Posted: Tue Sep 12, 2017 10:50 am Post subject: Re: Propex Heater without body mounted tank? |
Quote: |
Set it up so that the tank is secure just in case you do drive off. So maybe some kind of strap that holds it up to the underside of the Van? If it was a positive, secure connection you could potentially have the option of deciding to use the heater when driving if you ever wanted to. |
Engineered cheap safety solution. You clip your car key to the tank when it goes into use so that you have to find the can in order to drive off. Its amazing how many tricks like this make you six sigma safe on airlines _________________ .ssS! |
danfromsyr Samba Member
Posted: Tue Sep 12, 2017 11:14 am Post subject: Re: Propex Heater without body mounted tank? |
there are RV propane quick disconnects available for the tent trailer market, they use them for external BBQs. make sure there's a protective cap to keep the fitting clean..
https://www.google.com/search?rlz=1C1GGRV_enUS754U...GAgz0RY2Q8
Abscate wrote: |
Alaskaberrys Samba Member
Joined: June 19, 2016 Posts: 1001 Location: SE Alaska
Posted: Tue Sep 12, 2017 1:10 pm Post subject: Re: Propex Heater without body mounted tank? |
I'd say doable. Rules would be;
1) No highpressure lines/connections/regulator inside the van - i.e. no lines through the door/window/hole.
2) properly sized regulator (like a stock Westy) fixed in place with an add-a-tank type fitting attached to the high pressure (inlet) side.
3) Some afore mentioned "drive away protection" device. Flag to attach to steering/keys/etc. (or a reeeaalllly long hose so the "boom" happens far behind you when you-or someone-eventually forgets it )
That said, if you use the heater much you may want more capacity. If the heater puts out 6,500 btu per hour of run time and 1 gal of propane contains somewhere around 90,000 btu's, that gives you somewhere around 14 hours of continuous run time. Is that enough? _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
Posted: Tue Sep 12, 2017 8:00 pm Post subject: Re: Propex Heater without body mounted tank? |
One reason to reconsider a tank mounted under your weekender is... safety. In the event of an accident an unsecured propane tank (even a 1 gal) carried in your van becomes a deadly projectile. Of course, you can secure it in the van or store it in your Thule/Yak box, but that becomes "one more thing" and takes up valuable real estate.
Mount a tank under your van and forget about it.
http://www.gowesty.com/product-details.php?v=&id=2447 or the larger capacity version which hangs 3" lower than the original: http://www.gowesty.com/product-details.php?v=&id=23916
PS - After you mount a tank underneath, you can add a quick connect fitting to operate other accessories (grill, stove, shower, etc). _________________ 1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD |
raoul mitgong Samba Member
Joined: July 05, 2009 Posts: 1338 Location: Denver, CO
Posted: Wed Sep 13, 2017 10:12 am Post subject: Re: Propex Heater without body mounted tank? |
That larger GoWesty tank has a gauge. I'd say that alone is worth the extra $$.
-d _________________ 84 Westy with a 2.1 (Groover)
86 Tintop Syncro (Crow)
86 Tintop Syncro to Westy project (Tom Servo)
91 Westy (Only the top 12 inches of this van (a burn victim)) |
Posted: Thu Sep 14, 2017 4:08 pm Post subject: Re: Propex Heater without body mounted tank? |
Thanks for all of the feedback and ideas. I may just save up to install the tank on the vehicle. Safety first!! |
herbie555 Samba Member
Joined: August 25, 2009 Posts: 13 Location: San Diego, CA
Posted: Fri Sep 15, 2017 1:46 pm Post subject: Re: Propex Heater without body mounted tank? |
I think this can be safely done without mounting a tank. (It's how I plan to do it.)
I've previously spoken to Karl at Westyventures about this and he was pretty sure he could find and sell me the appropriate adapters needed for a quick-disconnect propane connection to an otherwise hard-mounted Propex (I was looking at the external-mount HS2211)
After that, safety just means finding a safe way to transport the propane bottle. I use a 5lb tank (~9" diameter), mounted on an exterior rack on my van. It's secure, but outside (and even lockable), and is much easier to find a place for than a massive 20lb tank.
I use an aluminum tank bracket from Adventure Trailers:
[img]https://lh3.googleusercontent.com/BCh8Pd_j-ugpM-_zsCqVaJimMMqqSG6YCVfIxz0HCP_LuVquK-1o_dpsGHQytftZQD01FRLh7bQJpbxntHYbGb_GOq-MWEoZVxZ0H-GHcusEam-F9oZZJgbPVnMTuoPbieG-erHq0T5xKIL33HP631nvqxSNyrPVUZnCleSWdp8ilAiwSygfOqoIYyZS-lxAK02fkPAmucBvqqVLflC1a2JZoni7-XmyGYd5g4AD8YMZbv4Lj76rT9zRMph6XWJZQjGETc9cH5cMq_hKhtMYXxaZOIK5OhpEkmt2izRgbaauq8cTYccZRFgF0-74ZHzP4Glpsys7ibNYy5OsSSjI7zd-jZgO_MEcXz_-73IXIOjufp8OOVd7SE-mTNJfn0F5swBRTlxFDMQrhK2KBn2DF72soveCOuaUtrg_kDN9pYcODCY8bvYFUOfRjOG74gsZNj6CnZkVBa0Wk0S4cpTBYNZtRC7HELmHzVf2gz01aAl5hG25AcLLuNSJvn-5z9GDQhCRvgxWDbYiytwPvXKMIMMHwquiLo2eG234a1pkDNdo2LaT-DRUOLlTBDwO9872piQ8YoonNT7F6K6u0NNyw_iiQLRS3anAe3qyzOMfsJS4V-R7zMIMxXCJPoqJXf_Zi3Hst9wpuHw0YE4bvs7g8-YMcoyqzOZGpUPq=w600?.jpg[/img]
EDIT: Looks like I'm having some trouble w/ image posts. Copypasta the url if you're curious.
I think driving away with the tank attached is rather unlikely. Depending on where you mount the Propex, you'll either be stepping over the tank on the driver's side, or on the passenger's side... _________________ http://chooseadventure.net/ |
Posted: Fri Sep 15, 2017 7:41 pm Post subject: Re: Propex Heater without body mounted tank? |
Depending on the climate you plan to camp in, a 5lb tank may or may not serve your needs. Here in Northern California (read: average low temps 45-55F) my Propex set to about 65F with a standard OEM LP Westy tank lasts about 5-7 nights. _________________ 1990 Multivan - "Ohana"
westyventures Samba Member
Joined: December 29, 2004 Posts: 2306 Location: Oregon Outback
Posted: Fri Sep 15, 2017 8:37 pm Post subject: Re: Propex Heater without body mounted tank? |
FWIW, a stock Westy tank will run the HS2000 or HS2211 approximately 40 hours continuous. |
Posted: Fri Sep 15, 2017 9:48 pm Post subject: Re: Propex Heater without body mounted tank? |
herbie555 wrote: |
I think driving away with the tank attached is rather unlikely. Depending on where you mount the Propex, you'll either be stepping over the tank on the driver's side, or on the passenger's side... |
Thats probably true, I think most folks would pay better attention than I seem too...made it 4 miles - all the way to the freeway - with the pop-up up
westyventures wrote: |
Our main reasoning for our second tank, a couple of weeks between fill-ups with both LP refer and Propex running. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
Sodo Samba Member
Joined: July 06, 2007 Posts: 9620 Location: Western WA
Posted: Sat Sep 16, 2017 2:49 am Post subject: Re: Propex Heater without body mounted tank? |
If you camp a lot, every bit of inertia added to camp setup and departure will be regretted. If you rarely camp, added rituals are often savored. For all the effort it takes to install a propex (well) I think "opening the propane valve" should be the only barrier between you and heat. _________________
....KTMs, GasGas, SPOT mtb |
