New bus, 75 walk thru
Oilspot11
Oilspot11 is offline
PostPosted: Tue Sep 12, 2017 6:50 pm    Post subject: New bus, 75 walk thru Reply with quote
Still at German in OCC waiting to get running. Has a later FI engine I need to learn. Since driving a 71 for 11 years as my DD ten years ago, I've had two bugs. My soul is ready to be in a bus again. It's my eighth ACVW. Four bugs, four busses.
I did the M code thing, imported to Boston, seven seater, original paint. Many folks in the Colorado Springs area know this bus. I plan to make it a day camper.
I feel whole again with a bus. Anyone want to buy a 65 bug?
busdaddy
busdaddy is offline
PostPosted: Tue Sep 12, 2017 7:05 pm    Post subject: Re: New bus, 75 walk thru Reply with quote
Nice!, don't let them talk you out of the FI and install a carb, once the initial pain is done it's good for another 40 years of neglect.
Oilspot11
PostPosted: Tue Sep 12, 2017 7:13 pm    Post subject: Re: New bus, 75 walk thru Reply with quote
Thanks, Busdaddy. I did buy a set of Weber 44's But After reading here, I'm sticking with the FI. Maybe put them in the 65
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Tue Sep 12, 2017 7:37 pm    Post subject: Re: New bus, 75 walk thru Reply with quote
Welcome back to the bus madness! Wink
Another strong vote to not remove the fuel injection. Busdaddy and others on this site can help you get er figured out.
Bill
My 1970 bus refresh thread- http://www.thesamba.com/vw/forum/viewtopic.php?t=598191
1970 Westfalia Bus
1969 Convertible Bug
1967 Standard Bug
Oilspot11
PostPosted: Tue Sep 12, 2017 7:38 pm    Post subject: Re: New bus, 75 walk thru Reply with quote
Now this was a pain in the ass. New rubber from WCM. We'll see how it goes into the bus.
But not before surface window channel rust repair.
Next will be the new (old) jalousie window with WCM seal. Got an inner seal on eBay from England. I'll post how that goes.
This isn't going to be a show vehicle but I've got the time to do things well.
Oilspot11
PostPosted: Tue Sep 12, 2017 7:41 pm    Post subject: Re: New bus, 75 walk thru Reply with quote
Thanks, wcfvw69. From all the thoughtful input from Samba members, the FI is staying.
No doubt you'll be hearing from me in the future about it!
Tcash
Tcash is offline
PostPosted: Tue Sep 12, 2017 8:28 pm    Post subject: Re: New bus, 75 walk thru Reply with quote
Jalousie Seal Tutorial
Jalousie pop rivet replacement & New Cranks
Jalousie (louvered) Window Restoration
How to: VW Type 2 Campmobile Jalousie Louvered window rebuild.
Jalousie seal tutorial pt 1
Jalousie seal tutorial pt2
Jalousie seal tutorial pt3
Jalousie seal tutorial pt4
Jalousie seal tutorial pt5
Jalousie seal tutorial pt6
Jalousie seal tutorial pt7
Jalousie seal tutorial pt8
Jalousie seal tutorial pt9
Jalousie seal tutorial pt10
Jalousie seal tutorial pt11
Jalousie seal tutorial pt12
Jalousie seal tutorial pt13
Jalousie seal tutorial pt14
Jalousie seal tutorial pt15
Jalousie seal tutorial pt16
Jalousie seal tutorial pt17
Jalousie seal tutorial pt18
Jalousie seal tutorial pt19
Oilspot11
PostPosted: Tue Sep 12, 2017 8:34 pm    Post subject: Re: New bus, 75 walk thru Reply with quote
Thanks, Tcash, I follow your advice like a moth to a flame. I'm not rebuilding the window, just installing it. I did it on my 71, but there I just used self tappers to secure it. Doing it better this time.
I expected the oil drain bolt post from you first. Shocked But please, keep advise coming.
Tcash
Tcash is offline
PostPosted: Tue Sep 12, 2017 8:43 pm    Post subject: Re: New bus, 75 walk thru Reply with quote
Here you go.
Welcome Back, to the Bay Window Bus Forum!
73-79
Tcash wrote:
Every Type IV engine owner should know this!!!
If you over tighten the Oil Strainer bolt, you will brake the engine case!
There is a Oil strainer in there.
TORQUE THE STRAINER BOLT TO NO MORE THAN 9 FT. LBS.
Tcash wrote:
Here is a little information. Good Luck
Pictures would be cool.
How to post photos/How to post a photo in the Forums
Pronunciation (Samba) English
I am thinking of buying a VW van
Cleaning+Rodents+Hantavirus
Up in smoke... Bus fires... don't let it happen to you!
M-Plate Location
Type 2 M-Plate decoder
M-Plate Decoder Volkswagen Type 2 Bus
Bus VIN / Chassis Numbers
Type 2/Bus Owner's Manuals
Bus repair manuals
Bus parts manuals
Early Baywindow Bus Parts Book
Late Baywindow Bus Parts Fiche
Type 2 Wiring Diagrams
Model and Year Variations
Type 4: Secrets Revealed
Distributor Parts & Specifications
PARTS INTERCHANGE MANUAL
Youtube Videos
There is a ton of information located at the top of the Forum section.
Tcash
Tcash is offline
PostPosted: Tue Sep 12, 2017 8:44 pm    Post subject: Re: New bus, 75 walk thru Reply with quote
Oilspot11
PostPosted: Tue Sep 12, 2017 8:47 pm    Post subject: Re: New bus, 75 walk thru Reply with quote
Holy F, 100% love it.
You are the man.
I'll be smiling for week from that post
Oilspot11
PostPosted: Tue Sep 12, 2017 8:58 pm    Post subject: Re: New bus, 75 walk thru Reply with quote
OOh, OOh, Tcash, Tcash
Anyway, thanks, man, you're a valuable resource. Thanks.
I continue to look forward to your replies to mine and others questions.
