airschooled Air-Schooled
Posted: Thu Sep 14, 2017 1:08 am Post subject: Re: 1971 bus not stopping after full brake job |
Abscate wrote: |
Don't think DOT 5 will save you, it won't. |
What about DOT 5.1? _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Thu Sep 14, 2017 4:54 am Post subject: Re: 1971 bus not stopping after full brake job |
Ok....seeing you did replace everything here is a theory....
How is the brake pushrod adjustement IN the booster? Aftermarket boosters are junk...and even OE. Ones may have been fooled with. If the adjustment is too long it will compress the mc piston somewhat and you won't get a "full shot" or stroke in the bore....that may be your whole problem.
Sounds like you have run enough fluid thru it. I never bench bleed masters....pressure bleed here or pump n hold....
Neve had any issues vaccum bleeding either. In fact it works well. I suspect the pushrod or a bum master.
If your pedal is rock hard with the engine off chances are there is no air, and its the master or pushrod adjustment.
Did the mc go on the booster easily? Or did you have to "draw it in"? If you did, that is a sign the pushrod is too long _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Thu Sep 14, 2017 5:51 am Post subject: Re: 1971 bus not stopping after full brake job |
Vacuum bleeding becomes problematic to me when we use negative pressure to bleed a system that spends its life at 10psi and above. What part of the vacuum bleeding process gets the residual pressure back to operating pressure? (The wheel cylinder/shoe springs of drum brakes and residual valves in the MC keep about 10psi in the lines at all times. Vacuum bleeders can't contribute to this.)
If your brake system is retaining pressure,then you have a problem,the pressure applied to the wheel cylinders by the brake shoe return springs forces the fluid back into the reservoir.If there was 10 psi in the system and you were to remove one set of shoes the pressure would push the pistons out of the wheel cylinder,it would also cause the brakes to drag.
The front disc brake caliber piston has about 6 square inches of area,10 psi would apply 60 pounds pressure on the brake pad,and that would cause the m to drag. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
Abscate Samba Member
Posted: Thu Sep 14, 2017 8:18 am Post subject: Re: 1971 bus not stopping after full brake job |
asiab3 wrote: |
Abscate wrote: |
What about DOT 5.1? |
I haven't tried it with popcorn - let me know.
_________________ .ssS! |
SGKent Samba Member
Posted: Thu Sep 14, 2017 8:41 am Post subject: Re: 1971 bus not stopping after full brake job |
Quote: |
Replaced master cylinder, servo |
probably as Skills said the front piston in the MC is partially compressed when released. There is a procedure in Bentley to make the brake booster rod is correctly adjusted. When it is partially compressed all sorts of things happen - including seized calipers because the front compensating port is blocked too
works well with salts of arsenic. First you turn white then you grab your chest, then if you are unlucky your heirs inherit your bus while you watch them from Heaven say what a nice guy you were - but then you realize you might not be in Heaven because you are also having to watch them giggle while they grind gears trying to shift your new trans. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
timvw7476 Samba Member
Posted: Thu Sep 14, 2017 10:15 am Post subject: Re: 1971 bus not stopping after full brake job |
said bus could've been gravity bled 23 times since I posted...
yaaaaaaayyyy........ gravity. |
Tcash Samba Member
Posted: Thu Sep 14, 2017 11:04 am Post subject: Re: 1971 bus not stopping after full brake job |
Brake booster pushrod adjustment
Brake Booster
It doesn't, the first application of the brake pedal restores the residual pressure.
Once a master cylinder is bench-bled, there is no functional difference between pedal bleeding and pressure bleeding.
There has to be. Because some vehicles you can't get the air out without pressure bleeding.
Residual valves are used on drum brakes not disc brakes.
http://ratropa.com/mc.jpg
Gravity bleeding is a good way to exchange the fluid, before pressure/vaccum bleeding. But it does not move all the air bubbles.
This can be demonstrated by observing an air bubble in a clear liquid tube. The fluid will drain past the air bubble but the air bubble will maintain its position or move up the tube. |
Posted: Thu Sep 14, 2017 1:11 pm Post subject: Re: 1971 bus not stopping after full brake job |
My mistake- the drum brake buses have residual (10psi) valves on all wheels and the 71+ buses don't even have residual valves on the rear wheels. I wonder what they were thinking, considering most cars have 10psi residual valves for drums and 2psi residual valves for discs.
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Thu Sep 14, 2017 1:47 pm Post subject: Re: 1971 bus not stopping after full brake job |
WTF is a residual valve? If you're talking about wheel cylinders, I've rebuilt several and they consist of a bore, piston, and cup seal. Return springs on the shoes might keep some pressure in the brake lines but I surely wouldn't call a wheel cylinder a residual valve. There doesn't seem to be any difference to speak of between a 1971+ wheel cylinder and an early cylinder. At least not that I've ever noticed.
To the OP,
Did you buy a NEW booster? Did you follow the directions and adjust the rod end on the aftermarket booster per the instructions? Can I have your original booster? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Tcash Samba Member
Posted: Thu Sep 14, 2017 3:17 pm Post subject: Re: 1971 bus not stopping after full brake job |
aeromech wrote: |
WTF is a residual valve? |
Posted: Thu Sep 14, 2017 5:02 pm Post subject: Re: 1971 bus not stopping after full brake job |
Me too. Thanks Robbie _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Thu Sep 14, 2017 5:04 pm Post subject: Re: 1971 bus not stopping after full brake job |
his 71 doesn't have these....... _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Thu Sep 14, 2017 5:05 pm Post subject: Re: 1971 bus not stopping after full brake job |
skills@eurocarsplus wrote: |
his 71 doesn't have these....... |
Right; I was blabbering on because I assumed the rear drum circuit did. _________________ Learn how your vintage VW works. And why it doesn't!
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Thu Sep 14, 2017 9:33 pm Post subject: Re: 1971 bus not stopping after full brake job |
I just replaced my MC and Servo in my '71 in July maybe. Used the new Airtec servo which has worked quite well. I just adjusted the push rod to protrude from the body of the servo the same length as the push rod protruded from the old servo. I used the Brasilian MC on Aeromechs recommendation. I tried to vacuum bleed it and that literally and figuratively sucked. Went to the old school pump the pedal method and it worked fine. The idea is to get a bubble free stream of fluid that extends all the way from the reservoir through the MC out to to the bleeders and then close the bleeders. Gravity, pressure, pump, doesn't really matter unless you are in a time is money situation. Then probably a pressure bleeder would be good. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Fri Sep 15, 2017 3:35 am Post subject: Re: 1971 bus not stopping after full brake job |
I think hell is a continuous loop of brake bleeding threads....where Is TK when you need him? _________________ .ssS! |
