fasty68 Samba Member
Joined: March 08, 2009 Posts: 4 Location: spring valley ca
Posted: Tue Sep 12, 2017 8:08 pm Post subject: 1971 bus not stopping after full brake job |
My buddy and I just finished a full brake job on his 1971 vw bay window. But now after bleeding the whole system we have no real break power. Also we got really good pressure when bleeding the rear but not on the front. All new hoses, calipers and brake pads on the front. All new hoses, cylinders and shoes and adjusted on the rear. We also tried with a new master cylinder but no luck. |
Danwvw Samba Member
Posted: Tue Sep 12, 2017 8:11 pm Post subject: Re: 1971 bus not stopping after full brake job |
Must not be bleed well enough yet. Did you bleed it where the fittings connect to the MC? That should help. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Oilspot11 Samba Member
Joined: July 31, 2014 Posts: 135 Location: Green Mountain Falls, Colorado
Posted: Tue Sep 12, 2017 8:23 pm Post subject: Re: 1971 bus not stopping after full brake job |
What was your bleed method? |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Tue Sep 12, 2017 10:13 pm Post subject: Re: 1971 bus not stopping after full brake job |
fasty68 wrote: |
....Also we got really good pressure when bleeding the rear but not on the front. All new hoses, calipers and brake pads on the front. All new hoses, cylinders and shoes and adjusted on the rear. We also tried with a new master cylinder but no luck. |
There is an outside possibility that your Brake Regulator is fouled with muck and the steel ball inside is stuck. This will prevent correct flow to balance front and rear brakes. Its supposed to equalize pressure between front and rear brakes.
Brake Regulator might be inboard of outside frame rail on Driver's side. Just follow the brake lines from Master Cylinder if you are having trouble locating it.
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Tue Sep 12, 2017 11:32 pm Post subject: Re: 1971 bus not stopping after full brake job |
bottom dollar says you didn't bleed it right. I don't care what anyone else says, the Bentley manual backs me on this, you need to PRESSURE BLEED your brakes at this point. Not pumping the brakes and holding, not gravity bleeding, not vacuum bleeding.
Look up DIY brake pressure bleeder, you can make one for under $20 with a garden sprayer and a brake fluid cap. You don't need much pressure to bleed them right, maybe 5 PSI. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Wed Sep 13, 2017 12:35 am Post subject: Re: 1971 bus not stopping after full brake job |
Pumping the pedal IS pressure bleeding. Bentley 9.2 and 9.3 please. The cool thing about science, is that it's true weather or not you believe in it.
Some front calipers on '71+ buses have two bleed ports; one is on top the other is lower. Which did you use?
www.airschooled.com |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Wed Sep 13, 2017 3:44 am Post subject: Re: 1971 bus not stopping after full brake job |
asiab3 wrote: |
Robbie |
Semantics aside, pedal pumping is not the same as using a pressure pot. Pressure pot bleeding forces air bubbles out of the master when they would otherwise be trapped.
What about this guy's situation when he has lines full of air? There is no hydraulic pressure generated using pedal pumping on a system that can't get a 'prime' in the master cylinder. _________________ Robert in Memphis
Davydomes Samba Member
Joined: August 28, 2013 Posts: 110 Location: North West England (Savoury Pie Country)
Posted: Wed Sep 13, 2017 4:57 am Post subject: Re: 1971 bus not stopping after full brake job |
Wasted youth wrote: |
fasty68 wrote: |
We had a problem with the rears staying on. After much bleeding attempts we discovered the master cylinder had bits of perished seals in the bottle which must have passed into the system. After cleaning it and flushing out the whole system the problem remained. The only thing we had not split (because we were a bit nervous to be honest) was the pressure regulator. When we did it also had bits of perished seal blocking the holes. Once cleaned out and recharged the problem disappeared. Do you use any kit to help you bleed? Either a suction device or pump? We only used the tried and tested method and it worked. _________________ I only went to look at it!
"Mum, Dad ………. I'm Bay"
Patience is bitter, but its fruit is sweet. Jean-Jaques Rousseau |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Wed Sep 13, 2017 6:49 am Post subject: Re: 1971 bus not stopping after full brake job |
fasty68 wrote: |
Does the servo function properly? _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Joined: August 31, 2013 Posts: 12848 Location: North Carolina
Posted: Wed Sep 13, 2017 7:05 am Post subject: Re: 1971 bus not stopping after full brake job |
One of the reasons for pressure or vacuum bleeding is to avoid depressing the plunger in the master cylinder beyond the normal operating range of motion. Going beyond this introduces the seals to the unused rusted areas of the bore which tears & damages the seals & will cause the master cylinder to fail. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Tcash Samba Member
Posted: Wed Sep 13, 2017 9:12 am Post subject: Re: 1971 bus not stopping after full brake job |
Did you bleed them per the service manual as far as in the correct order RF, LF, RR, LR?
If you replaced the Master cylinder you need to bleed that first.
Because the Master cylinder sits so low in the vehicle it is best to Pressure or Vacuum bleed the brakes.
Pressure bleed start Farthest from master cylinder.
Vacuum bleed start Closest from master cylinder.
Another thing to consider. Is the brake shoes Arc. Sometimes the shoe Arc does not fit the brake drum Arc and it takes awhile and a few brake adjustment to bed them in. So the brake surface contact area increases as the shoes wear into the drums and braking improves.
The Brake Pressure Regulators, function is to reduce the pressure to the rear brake to prevent rear wheel skid in a hard application.
Brake Pressure Regulator t2 211 612 501
TDCTDI wrote: |
One of the reasons for pressure or vacuum bleeding is to avoid depressing the plunger in the master cylinder beyond the normal operating range of motion. Going beyond this introduces the seals to the unused rusted areas of the bore which tears & damages the seals & will cause the master cylinder to fail. |
Agreed, I can't tell you how many times people have reported bleeding their brakes followed by, now the master cylinder is leaking.
Not an issue in this case because the master has been replaced.
Good luck
Tcash |
SGKent Samba Member
Posted: Wed Sep 13, 2017 9:22 am Post subject: Re: 1971 bus not stopping after full brake job |
the bus has to be level to properly bleed it. If the nose is low the rear brakes are cut off. If you don't have a hard pedal then there is air in the lines. If you have a hard pedal and it still doesn't work the front calipers could be frozen. Spin each tire, hit the brake and see if you can feel good resistance. Then lift your foot off the brake and be sure the tire spins freely. If not then the calipers are frozen. Front must be bled from the top bleeder, not the bottom if it has two.
Regulator cuts off the rear brakes, not the front. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
timvw7476 Samba Member
Posted: Wed Sep 13, 2017 11:30 am Post subject: Re: 1971 bus not stopping after full brake job |
Keep it level!
Always best to bench bleed the master cylinder, just dunk it in fluid & pump
Always use the upper bleed screws on the calipers, lowers do NOTHING.
Gravity bleeding is acceptable, open the reservoir cap, crack the bleeder,
wait 10 -15 minutes if you want to be sure, 2-3 ounces per wheel should
come out, top off reservoir & on to the next cylinder or caliper.
Sequence: RR,LR,RF,LF
There are times when this fails, teflon tape on your bleeder screws may be
required along with a Mity Vac to get the brake fluid 'drawing' to your
container-the teflon plumbing tape helps seal the bleeder screw threads. |
Posted: Wed Sep 13, 2017 3:39 pm Post subject: Re: 1971 bus not stopping after full brake job |
Sorry for the late response guys (grave yard shift) ok so we just bled the system the old pump and hold way, RR LR FR FL. Like 4 or 5 times already, however we did not bench bled the master cylinder we have already replaced everything but the proportioning valve but that isn't the issue since we have really strong pressure coming out the back but on the front we have fluid coming out but with no pressure. Also the pedal stops half way I'm guessing that's when the rear brakes come in. Help! |
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Wed Sep 13, 2017 4:22 pm Post subject: Re: 1971 bus not stopping after full brake job |
I want a list of what you replaced before I reply. your "full brake job" and mine may (and probably will) vary wildly
the brake regulator/proportioning valve does absolutely NOTHING static...when working properly, it takes inertia and a huge nose dive for it to activate (providing it works) otherwise, it's just in line to the rears. if you have good flow out of it to the wheel cylinders it isn't a problem.
now, about that list..... _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Wed Sep 13, 2017 10:32 pm Post subject: Re: 1971 bus not stopping after full brake job |
Replaced master cylinder, servo, hard lines and rubber hoses front and rear, rotors and drums, calipers and rear wheel cylinders, shoes and pads and put new fluid in it. Everything was working fine prior to replacing all of the above, it was just worn out and old. Like I said good pressure on the rear (both breeders) but very little almost no pressure put of the calipers (single bleeder). |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22641 Location: NYC/Upstate/ROW
Posted: Thu Sep 14, 2017 12:49 am Post subject: Re: 1971 bus not stopping after full brake job |
As a diagnostic cap off the front lines and see if you develop brake pressure then. Remove one at a time to see if you can identify the offending caliper or replace master cylinder if you can't get pressure capped off.
I know you did.
Cheap parts suck. _________________ .ssS! |
Posted: Thu Sep 14, 2017 12:55 am Post subject: Re: 1971 bus not stopping after full brake job |
TDCTDI wrote: |
I honestly think this is a myth perpetuated by those with water-saturated brake fluid and rusty master cylinders that need replacing anyway. Bentley tells us to push to the floor. There should be NO rust in a good brake system, no matter the cheapness of owners.
Vacuum bleeding becomes problematic to me when we use negative pressure to bleed a system that spends its life at 10psi and above. What part of the vacuum bleeding process gets the residual pressure back to operating pressure? (The wheel cylinder/shoe springs of drum brakes and residual valves in the MC keep about 10psi in the lines at all times. Vacuum bleeders can't contribute to this.)
Once a master cylinder is bench-bled, (in the bus works for this, ironically, that's just an industry term,) there is no functional difference between pedal bleeding and pressure bleeding. The hydraulic lines and cylinders do not care if the pressure is coming from a Volkswagen pressure tool, a garden sprayer, or the pedal. The system can't tell anyway.
Posted: Thu Sep 14, 2017 1:05 am Post subject: Re: 1971 bus not stopping after full brake job |
The number of people who change brake fluid on two year intervals is pretty low. Not a bad Job to give an inspection station every other year to:
Keep your driveway clean
Remember to do to it
Keep your indie shop alive on a no profit inspection
If you don't want to do it yourself.
Don't think DOT 5 will save you, it won't. _________________ .ssS! |
