Valve adjustment question/problem solving
cocopuffsman
cocopuffsman is offline
PostPosted: Wed Sep 13, 2017 3:27 pm    Post subject: Valve adjustment question/problem solving Reply with quote
just adjusted my valves using the fallowing method (below)... with the exception that my valve #3 exhaust and my cylinder #4 intake valve seem to have no clearance for adjusting? what could be some causes for this and is my method incorrect?
Method used:
Valves (110 cam) 004 clearance with feeler gauge
1) put the motor at top dead center. You will know by slightly twisting the pulley and you will see the #2 exhaust valve moving.
2) adjust the #1 intake and exhaust and #2 intake.
3) adjust the #4 exhaust valve.
4) turn the motor over 360 degrees.
5) adjust the #2 exhaust valve
6) adjust the #3 intake and exhaust and the #4 intake.
7) you are done.
Basically you are setting it at TDC, adjusting 3 valves on one side and 1 on the other side. Turn the motor 360 degrees and adjust all the valves you haven't adjusted yet. Boom, done.
https://www.youtube.com/watch?v=z5HSYpTKrUg
https://youtu.be/z5yDe0MKzYw
https://youtu.be/MpJoZYZNLLI
https://youtu.be/m8-rsKIvbos
https://youtu.be/bfYDA3-N0fg
[email protected]
roy@mofoco.com is offline
PostPosted: Wed Sep 13, 2017 3:32 pm    Post subject: Re: Valve adjustment question/problem solving Reply with quote
Method used:
7) you are done.
That is the only method for adjusting valves I have ever used. Been doing it for 25+ years now. As for the other problem, can you post a picture? Are they cut to length push rods? Swivel feet?
Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet
cocopuffsman
PostPosted: Wed Sep 13, 2017 3:58 pm    Post subject: Re: Valve adjustment question/problem solving Reply with quote
[email protected] wrote:
Method used:
7) you are done.
oldschool5er
oldschool5er is offline
PostPosted: Wed Sep 13, 2017 6:45 pm    Post subject: Re: Valve adjustment question/problem solving Reply with quote
You have swivel feet and chrome moly pushrods so I use loose zero not .004 for that setup. There are threads here on how to do loose zero adjustments. You would use the same sequence that you did. The valve is set by adjusting the swivel from snug to where the pushrod just turns with your two fingers. I noticed the center lower studs are digging into the rocker spacer, if that is the case I would double check they are not hitting and holding the rocker shaft stands from sitting fully on the head or are causing lack of running clearance for the rockers also.
Pruneman99
Pruneman99 is offline
PostPosted: Wed Sep 13, 2017 7:45 pm    Post subject: Re: Valve adjustment question/problem solving Reply with quote
With the stock rockers and swivel feet, the rockers sometimes need to be cut back to allow for proper adjustment.
Did you build this engine and verify rocker geometry?
fivelugshortaxle
fivelugshortaxle is offline
PostPosted: Wed Sep 13, 2017 8:09 pm    Post subject: Re: Valve adjustment question/problem solving Reply with quote
This
Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc
cocopuffsman
PostPosted: Wed Sep 13, 2017 8:37 pm    Post subject: Re: Valve adjustment question/problem solving Reply with quote
great observation, I will check tomorrow Smile
FreeBug
FreeBug is offline
PostPosted: Wed Sep 13, 2017 10:39 pm    Post subject: Re: Valve adjustment question/problem solving Reply with quote
This. In my experience, rockers ALWAYS needed grinding down for the swivels.
cocopuffsman
PostPosted: Thu Sep 14, 2017 8:52 am    Post subject: Re: Valve adjustment question/problem solving Reply with quote
but they were fine before I put new pistons/cylinders
Pruneman99
PostPosted: Thu Sep 14, 2017 11:22 am    Post subject: Re: Valve adjustment question/problem solving Reply with quote
The cylinders may be different length than the ones removed altering your rocker geometry. Adding/removing cylinder shims, decking the case etc will move the heads closer/further from the case as well.
Rocker geometry always needs checked when something on the long block is changed.
With the stock rockers and swivel feet, the rockers really need to be back cut for proper geometry, but sometimes you can get away without it with less than perfect geometry or rocker block shims. Not saying it's right, but sometimes it works ok.
Obviously yours are bottomed out so you need to get different rockers, have yours cut back, or *correct* the rocker geometry so there is some adjustment available.
Are you using stock length pushrods, or cut to length?
cocopuffsman
PostPosted: Thu Sep 14, 2017 7:11 pm    Post subject: Re: Valve adjustment question/problem solving Reply with quote
Are you using stock length push rods, or cut to length?
hmm I added a hardened washer between the heads and the rocker arms as shims and bolted them on, that has solved the issue could that cause any problems?
Pruneman99
PostPosted: Thu Sep 14, 2017 8:54 pm    Post subject: Re: Valve adjustment question/problem solving Reply with quote
Well it could solve the issue, could compund it. You.need to work out your rocker geometry.
Tons of threads on that here, pick your poison. Different strokes for different folks for setting that up.
Like I said before, usually the stock rockers need to be back cut to make it work right.
When you move the rockers further from the heads, you might need longer pushrods. It has to be measured. If you just start tossing shims in there to fix the problem of no adjustment on the swivel feet, you can really mess other things up.
I tore down a mostly stock engine that had just a few hours on it and the exhaust valve guides we're nearly eaten through because the geometry was so bad. But the engine ate some other pieces first. I don't think the builder measured anything.
Dale M.
Dale M. is offline
PostPosted: Fri Sep 15, 2017 5:27 am    Post subject: Re: Valve adjustment question/problem solving Reply with quote
Anybody notice threads on rocker arm studs...
And note the coupler nut used to secure valve covers....
Little bit of "cringe factor" there for me....
Dale
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
FeelthySanchez
Location: Now is that a real poncho, or a Sears poncho?
FeelthySanchez is online now
PostPosted: Fri Sep 15, 2017 6:35 am    Post subject: Re: Valve adjustment question/problem solving Reply with quote
Dale nailed it on the stripped rocker stud. Good eye & those clear pics helped a bunch.
I'll add: Make sure the #4 plug hole is not cracked (appears a bit so).
The motor oil will be "glittery" from that chafed blue aluminum rocker arm spacer. Hope that a FFF was employed here. If not, time to add one.
You've a bunch of work ahead of ya ..... R&R the stripped rocker arm stud(s), shorten (or screw-in deeper) the head studs, retorque the heads, clearance the rockers, then re-set rocker geometry.
p.s: It's nice to see a 32 NDIX again!
modok wrote:
I would like if you had enough clue to communicate what you are doing.
Ryan Tucker wrote:
Enough clue..Whats that mean?
OldIronSpine wrote:
I'm not sure how compression works.
Turbos don't produce torque, they produce HP. Instead of torque.
The real problem with NA engines is you don't hear the nice whine of the turbo as it spools up.
Before I commit, I'm going to do more research because I don't really know what piston rings are.
mark tucker
mark tucker is offline
PostPosted: Fri Sep 15, 2017 9:51 am    Post subject: Re: Valve adjustment question/problem solving Reply with quote
and adjust the valves properly Shocked in 45 years Ive never had to look at the dist or dampner/pully or find tdc rotate backwards and pick a bail of cotton to properly adjust valves.
nsracing
nsracing is offline
PostPosted: Fri Sep 15, 2017 11:09 am    Post subject: Re: Valve adjustment question/problem solving Reply with quote
If the cam is not stock, do NOT adjust intake and exhaust at the same time.
Any cam w/ more duration and more overlap, adjust each by itself. So..if you are going to do the intake, just do the intake until you are happy. Then move on to the exhaust so on.
Otherwise, you will come back here later and say that there is some unusual noises coming out of the case and the engine runs like crap. Laughing
This is getting old. How many times are we going to have threads on valve adjustments?
