aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Wed Sep 13, 2017 8:29 pm Post subject: Tire Dolly's for Old Dudes |
Guys,
I did a brake job for a friend today and now I'm paying the price. My shoulder hurts from removing and replacing four wheel assemblies. I'm 60 and realize I just can't do it like before so I'm wondering if there's a tool I might use to make this easier on my old bones. When I worked for the airlines we used hydraulic tire dollys to do this because those wheel assemblies weighed 200 pounds or so. Got any ideas? TIA. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Wed Sep 13, 2017 10:50 pm Post subject: Re: Tire Dolly's for Old Dudes |
Membership at the "Y", maybe? If you find a good answer, let me know. I'm 68, and due to some stressful life situations, gained quite a few pounds over the last 6 years. Can you say "beached whale"?
So, I was able to buy a nice 2 post Rotary brand lift. The bad: My ceilings are a foot too short. Hopefully I will come up with a workaround for that.
And my weight is going down. 30 lb so far. And regular exercise.
But basically you use it or lose it.
Right now working on my 1956 single cab. That brings smiles quite often and makes the pain worthwhile.
Getting old and having pain from working on old car projects is better than the alternative.... not being able to.
Al _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3853 Location: San Jose, CA
Posted: Wed Sep 13, 2017 11:02 pm Post subject: Re: Tire Dolly's for Old Dudes |
Same problem for me, but lower back, and it's holding the wheels up to the drum on my '65 Beetle to start a lug bolt that has my 52 year old back whinin' (especially after pulling an engine). I was thinking about some home-brewed dolly of some sort, not sure about adjustable height, but even something that gets it close would help. I guess I could pick a particular setting on my jack stands to match heights, or just position it and then use the jack to zero in on the tire dolly height. Heck, now that I think about it, my $15 furniture dolly from HF would be a good start
And by the way, Al, I hope I'm still going at 68, I got a LOT of unfinished projects! (The '64 Bus in my avatar being one of them.) |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Wed Sep 13, 2017 11:25 pm Post subject: Re: Tire Dolly's for Old Dudes |
Juan |
Posted: Wed Sep 13, 2017 11:26 pm Post subject: Re: Tire Dolly's for Old Dudes |
Busstom wrote: |
For that task of mounting wheels, I try to position the car so the tires will only be about 2" off the floor. Then squat? (can't remember) then get the tires on both toes or insteps of my feet. Only slight motion of my feet will line up the holes.
BTW, someone makes ALIGNMENT PINS to make this easier. But I have never used them.
Unfinished projects? Yes, I have to thin the herd sometime. But want to complete the single cab and the Porsche 912 Targa.
Vanagons:
airschooled Air-Schooled
Posted: Thu Sep 14, 2017 12:37 am Post subject: Re: Tire Dolly's for Old Dudes |
My foam mat has worked with me on over a hundred buses now, in more states that I can remember. I'm a young dude, but I can't stand kneeling on concrete for more than a few minutes. I like these when I have the chance to use them:
I'll lay on my back on concrete, but I'm going to be a picky peckerhead about working for someone else on my knees.
Robbie
EDIT: I'm going to leave my response there, because I think taking care of our bodies is important, but now I'm realizing that you wanted a dolly for the tire, not for you!
I've used these. They're a part because you have to jack up the car 4" off the ground to get the tire into the carrier.
If I were to buy one, it would be this, assuming I had the space:
_________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Abscate Samba Member
Posted: Thu Sep 14, 2017 12:59 am Post subject: Re: Tire Dolly's for Old Dudes |
I'm not at the lift problem yet but I use a ratchet extension bar to hold the wheel up while I start the lugs, through the wheel and round part into the hub. Position the hub with hole at 12 o'clock
I'll think about a simple way to elevate the wheel , must be a solution here Gary. The langoliers come for all of us, take care of that Temple _________________ .ssS! |
my59 Samba Member
Joined: August 13, 2003 Posts: 3793 Location: connecting the dots
Posted: Thu Sep 14, 2017 2:36 am Post subject: Re: Tire Dolly's for Old Dudes |
Harbor Freight MC jack for the tire on occasion.
Have been known to get one of my kids to put wheels back on.
I use the alignment pin that came in a Benz tool roll for those cars, and it does make life just a bit simpler. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Thu Sep 14, 2017 7:12 am Post subject: Re: Tire Dolly's for Old Dudes |
That looks like it would solve the problem really well. The other options so far have not eliminated the need to get the tire onto the carrier, where as this you can use it to get the tire off. As long as you have the car high enough in the air. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Thu Sep 14, 2017 7:55 am Post subject: Re: Tire Dolly's for Old Dudes |
This is what I'm considering. It's not made for what I have in mind but might work
One issue might be the need to keep the tire vertical on the fixture. At the airline ours used a chain for that.
Besides supporting the tire there's a need to be able to rotate it on rollers to line up the lugs. I'm not sure how well these Gojak rollers would work. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Thu Sep 14, 2017 8:05 am Post subject: Re: Tire Dolly's for Old Dudes |
aeromech wrote: |
Besides supporting the tire there's a need to be able to rotate it on rollers to line up the lugs. I'm not sure how well these Gojak rollers would work. |
Rotate the hub instead? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1086 Location: wherever my baywindow takes me.
Posted: Thu Sep 14, 2017 8:38 am Post subject: Re: Tire Dolly's for Old Dudes |
Posted: Thu Sep 14, 2017 10:23 am Post subject: Re: Tire Dolly's for Old Dudes |
Here's my decision. I'll be buying the Gojak 4520 on Amazon. Here's a customer review from Amazon.
Makes Tire Changing Easy
ByKeith460on April 10, 2016
I bought one of these and only needed one for my tire changing needs. I have a truck and Jeep with heavy tires that are cumbersome to take off and on for routine maintenance and tire rotation so I needed something to help me make the work easier. Mounting large heavy tires and rims is a workout and when the Go-Jack arrived, I put it to use immediately. Wow, what a difference it made! A job of rotating tires that use to take about an hour for me to do has just turned into a 15min. job and my arms aren't sore anymore. Bravo for a well made in USA product!. The cheaper version from Harbor Freight, Tractor Supply and others do not have the rollers with bearings that make it easy to turn the wheel for alignment onto the axle hubs. Its easy now and I don't need the extra effort to get wheels back on. See photos.
His pics from the review
So there you go. Maybe I'll come back here and give you guys my thoughts once I've used it a few times.
EDIT:
I actually bought it on eBay from Summit Racing. Free shipping and no tax it came to $227.97 _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Thu Sep 14, 2017 10:51 am Post subject: Re: Tire Dolly's for Old Dudes |
aeromech wrote: |
Guys, ... I'm 60 and realize I just can't do it like before ... |
Dagnab kids these days whining about car repairs.
Just wait till you're 80 and repairing brake lines. I have a daughter that helps me out and I keep three Hawaiian girls at the house.
Aloha
tp |
oscarsnapkin Samba Member
Joined: October 22, 2013 Posts: 558 Location: Bucks County, PA
Posted: Thu Sep 14, 2017 11:49 am Post subject: Re: Tire Dolly's for Old Dudes |
We have this dolly at work for removing dual wheel assemblies off of trailers with open rims. However, this is what I do instead, and it would actually be a cheap solution to what Gary is looking for. Simply raise the vehicle, place a metal plate (lubed with some motor/gear oil) under the tire, raise lower vehicle until the tire is just barely off of the ground and slide the wheel on or off. This works great on trailers where you have the weight of two tires and wheels, the hub, and a gigantic brake drum, combined weighing a few hundred pounds, so it should work easily for a Bus wheel. _________________ - 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
"It’s so easy to laugh, it’s so easy to hate, it takes strength to be gentle and kind." |
Tcash Samba Member
Posted: Thu Sep 14, 2017 11:53 am Post subject: Re: Tire Dolly's for Old Dudes |
lil-jinx wrote: |
A shovel also works,put the tip of the shovel under the tire and push down on the handle. |
That gives me an idea. Mount a skateboard truck and wheels on a ditch
shovel.
I used to use a tool that was made out of a 1/2" pipe about 3.5" long, with a spooned shaped piece of metal on the end, at the bend between the pipe and spoon where wheels.
So you would lift the vehicle slightly, put the spoon under the tire, pry up on the tire and with your other hand on top of the tire, wheel the tire out from under the vehicle.
This thing was great. Worked on everything. Cars, Small trucks, Big trucks and Equiptment.
I can't tell you how many guys I've met over the years that had bad backs from hoofing tire.
Tcash |
Posted: Thu Sep 14, 2017 12:30 pm Post subject: Re: Tire Dolly's for Old Dudes |
Tim,
That's a two man operation. We used something similar at USAir. Works good for raising the tire high enough to slide onto the axle. The dolly is one man. Adjust it to the correct height and it takes the weight of the wheel at which point one guy can easily slide a very heavy wheel off by himself and roll it to the side.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
