Santaji Samba Member
Joined: December 29, 2007 Posts: 105 Location: Mumbai, India
Posted: Sun Sep 17, 2017 8:19 am Post subject: FI Bus idle speed and timing fluctuates |
The engine was overhauled about 1500km ago. The Bus ran very well after the rebuild until one day we couldn't get it to start.
There was no spark so we assumed that the Petronix electronic ignition had failed so we put in a set of points instead, after which the Bus would run but not very well. We were unable to set the timing as per the specification for the dual vacuum distributor as the engine refused to run at 4.5 degrees retard.
We swapped the old DVDA for a remanufactured SVDA (from BusDepot). Now the Bus is drivable again but the idling is irregular. The mark on the pulley is not very stable when a timing light is connected and we also found that sometimes the timing is going off by about 4-5 degrees after taking a test drive. So we if set it to 7.5 degrees advanced and go for drive, it would be at 12 or 4 when we got back...
I suspected a vacuum leak but after going through all the hoses thoroughly we were still not able to find the issue...
Any ideas on what else we can check!? _________________ '78 Westfalia '63 RHD Beetle '62 Fiat 1100 |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51150 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Sep 17, 2017 9:28 am Post subject: Re: FI Bus idle speed and timing fluctuates |
Hmmmm,,,,, at first glance it sounds like a bad distributor, how freely does the rotor spring back when you give it a little twist?
Large vacuum leaks do require more advance to stay running so a smoke test may be helpful: https://www.thesamba.com/vw/forum/viewtopic.php?t=620083
Another tiny possibility is the builder left out the key on the fan hub so the timing mark is moving, but that won't make it run bad suddenly, it only effects setting the timing. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Sun Sep 17, 2017 9:56 am Post subject: Re: FI Bus idle speed and timing fluctuates |
A vacuum leak cannot/will not affect the timing.
If your timing is jumping around it is most likely a problem with the distributor or distributor drive gear.
Changes in idle speed also don't affect the timing UNLESS the idle speed goes so high that the advance within the distributor starts to kick in.
I suspect that the idle is irregular because the timing is jumping around, not the other way around. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
SGKent Samba Member
Posted: Sun Sep 17, 2017 11:57 am Post subject: Re: FI Bus idle speed and timing fluctuates |
Quote: |
I suspect that the idle is irregular because the timing is jumping around, not the other way around. |
x2. Sounds like you have a bad distributor. That said, replace the condenser and see if that makes any changes. One of the best tests would be to check the dwell and see where it is set, and if it is stable. Also I hope you put the spring back in the drive gear when you swapped distributors. If it isn't there the drive gear can walk up and down. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun Sep 17, 2017 12:37 pm Post subject: Re: FI Bus idle speed and timing fluctuates |
SGKent wrote: |
Also I hope you put the spring back in the drive gear when you swapped distributors. If it isn't there the drive gear can walk up and down. |
This would be my guess as the problem has happened on more than one distributor. He likely also needs to lube the distributor he is using according to the manual.
The timing for all VW aircooled engines is 28° BTDC @3500+ rpms, hoses off and plugged. Forget the book timing unless you can find a brand new factory grate engine. |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Sun Sep 17, 2017 1:02 pm Post subject: Re: FI Bus idle speed and timing fluctuates |
Just out of curiosity...
With the engine off, reach in there and try to twist or turn Distributor by hand.
Does it move? |
airschooled Air-Schooled
Posted: Sun Sep 17, 2017 2:28 pm Post subject: Re: FI Bus idle speed and timing fluctuates |
I've dealt with the BusDepot rebuilt SVDA distributors twice, and both times they were very tight when new, but loosened up after a few thousand miles. Both distributors would "hang" above their proper idle timing until they fully broke in.
Timing scatter can be in the distributor, but it could also be excessive drive pinion play, excessive crankshaft end play, or a missing distributor sprig.
www.airschooled.com |
Tcash Samba Member
Posted: Wed Sep 20, 2017 12:34 am Post subject: Re: FI Bus idle speed and timing fluctuates |
SGKent wrote: |
I think this spring has always been missing as we don't remember noticing any spring anytime while removing/installing the distributor. Will try sourcing the spring and putting it back in.
busdaddy wrote: |
Hmmmm,,,,, at first glance it sounds like a bad distributor, how freely does the rotor spring back when you give it a little twist? |
Checked both the distributors and lubricated them. On both the cam springs back correctly when twisted and the plate also moves when applying vacuum...
Now with the DVDA it ran but very roughly so we put the SVDA back again. The idle still changes occasionally but it's much better than the other distributor. After a test-drive the timing had advanced 4-5 degrees but returned to normal after restarting the engine....
asiab3 wrote: |
Robbie |
Hopefully it's just a combination of the spring being missing and the distributor needing to break in... Will report back after getting the spring! _________________ '78 Westfalia '63 RHD Beetle '62 Fiat 1100 |
tommu Samba Member
Posted: Wed Sep 20, 2017 10:58 pm Post subject: Re: FI Bus idle speed and timing fluctuates |
Santaji wrote: |
SGKent wrote: |
I think this spring has always been missing as we don't remember noticing any spring anytime while removing/installing the distributor. Will try sourcing the spring and putting it back in. |
Take a torch and look down the hole for the spring. You don't normally handle it when swapping distributors. I'm curious to know your idle speed. Maybe it's a little high and the mechanical advance weights are just starting to spin out causing the advance and idle speed to hang up there a little. _________________ |
SlowLane Samba Member
Joined: July 11, 2005 Posts: 1044 Location: Livermore, CA
Posted: Thu Sep 21, 2017 8:33 am Post subject: Re: FI Bus idle speed and timing fluctuates |
tommu wrote: |
Take a torch and ... |
Just to clarify for you 'mericans: "torch" is Brit-speak for flashlight, not your oxy-acetylene setup... _________________ Present:
'81 Westfalia: 2L, manual. Originally Canadian, now Californiated
Back in the day:
'72 Super Beetle
'69 Camper Van - Corvair powered
'71 Window Van - Transferred Corvair from '69
"With sufficient thrust, pigs fly just fine." - Internet RFC 1925
"They say a little knowledge is a dangerous thing, but it is not one half so bad as a lot of ignorance." - Sir Terry Pratchett |
tommu Samba Member
Posted: Thu Sep 21, 2017 4:03 pm Post subject: Re: FI Bus idle speed and timing fluctuates |
SlowLane wrote: |
tommu wrote: |
Just to clarify for you 'mericans: "torch" is Brit-speak for flashlight, not your oxy-acetylene setup... |
OP is in India and will know the proper word.
EDIT: re-read your comment and it really never crossed my mind that you lot only have one, very dangerous, kind of torch. _________________ |
