DougClink Samba Member
Joined: August 14, 2006 Posts: 93 Location: Fremont, Michigan
Posted: Sun Sep 17, 2017 6:31 pm Post subject: End play and paper or metal gasket? |
I have done a number of things to my motor with help from the good people of the Samba such as yourselves. I successfully un-stuck some rings and my engine is running actually quite good. Now the problem is endplay. I am concerned that I have too much endplay. I know that 3 to 5 thousands is preferred/recommended.
I am concerned that I have quite a bit more than that. I will borrow a dial indicator tomorrow to doublecheck. The question is what my 1970 1600 single port motor have had a paper or metal flywheel gasket? It seems that a metal gasket would take some of the slop out.
If I have too much, what are my options? A complete rebuild? _________________ Air-cooled Preservation Society
Join us on Facebook!
1957 Sunroof Beetle 1964 Beetle 1958 Westfalia Subhatch 1955 Baja Bus 1970 Sportsmobile |
Tcash Samba Member
Posted: Sun Sep 17, 2017 6:57 pm Post subject: Re: End play and paper or metal gasket? |
No gasket. Flywheel has o-ring to seal between the crank and flywheel.
Your choice is to pull the engine and inspect and reset your end play.
Good luck
Tcash
PS for an example a human hair is .003" to .004" |
Posted: Sun Sep 17, 2017 7:12 pm Post subject: Re: End play and paper or metal gasket? |
Thanks for your reply tcash, fortunately I have the motor on a test stand. So all I have to do is get it on the floor. I did put the o'ring in the flywheel. I am talking about the gasket on the dowel pins. If I can't get the endplay right, doesn't the case need to be line board? Something else? I have a beetle case I can rebuild. I wonder how well the mustache bar adapter works. _________________ Air-cooled Preservation Society
SGKent Samba Member
Posted: Sun Sep 17, 2017 7:37 pm Post subject: Re: End play and paper or metal gasket? |
what thicknesses are the three shims you are using and how much end play do you have. Normally you take the measurement with 2 shims then calculate the 3rd and measure again after all three are in. _________________ Most people dont know what theyre doing, and a lot of them are really good at it. - George Carlin |
vwjetboat Samba Member
Posted: Sun Sep 17, 2017 7:44 pm Post subject: Re: End play and paper or metal gasket? |
when you pull the flywheel off.. push the crank back and forth from the crank pulley end.. look at the thrust bearing were it sits in back of case.. is it moving back and forth with crank? |
Tcash Samba Member
Posted: Sun Sep 17, 2017 8:32 pm Post subject: Re: End play and paper or metal gasket? |
I know. If you have and oring flywheel you do not use a gasket on the dowel pins.
Besides adding a gasket would add to your end play not make it less.
As posted, see if the bearing is loose in the case.
Inspect the end of the bearing, there should be spooned reliefs for the oil to get to the shims. If they are gone, the bearing is gone.
Loose bearing
setting end play
https://www.youtube.com/watch?v=XYS2jng1gNc
Good luck
Tcash |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3853 Location: San Jose, CA
Posted: Sun Sep 17, 2017 10:39 pm Post subject: Re: End play and paper or metal gasket? |
Yes, like Tcash said, a metal gasket over the pins would increase your end play, making it worse...don't do that.
As was suggested, before putting effort into the end play, first determine if the thrust bearing (#1 main) is shuffling fore and aft in the case. The way to do this is, use that same dial indicator you'd be using to check the end play; set it up so that you're indicating off the flange of the main bearing (all shims removed, looking at the spooned notches that Tcash describes); take a thin block of wood, and tap the main bearing towards the pulley-end of the case, tapping firmly but carefully around the perimeter of the bearing flange (don't hit your indicator!). Then, without touching anything else on the engine, zero your dial face, then take a mallet and slap the crank pulley bolt on the other end of the engine. This will give it a good shove, and if the thrust cut (the #1 main bearing saddle/shoulders) is going bad, you'll see the needle move/change on your dial indicator. There shouldn't be ANY movement in a perfect scenario.
Here's a pic of me doing the exact same job on a type 1 engine.
Posted: Mon Sep 18, 2017 3:06 am Post subject: Re: End play and paper or metal gasket? |
Your excessive end play is probably caused by the thrust bearing moving around in the case. This can not be corrected by reshimming. If you try to do so you will lock the bearing to the flywheel-crank assembly and will likely destroy your engine in very short order as a result. You will just need to tolerate the excessive endplay until rebuild time. |
Posted: Mon Sep 18, 2017 4:09 am Post subject: Re: End play and paper or metal gasket? |
Thanks everyone, I will check that out tonight. _________________ Air-cooled Preservation Society
Posted: Mon Sep 18, 2017 5:51 am Post subject: Re: End play and paper or metal gasket? |
Wildthings wrote: |
This^^^
So that three thousandths you see on my indicator pictured above? I have to add that to the 0.003 end play I'm shooting for when I put it back together, so overall end play detected will be 0.006" even though only three of that will be from the flywheel...the other three will be from that loose main bearing, I'm not doing anything about right now (I have another project on the burner). |
Posted: Fri Sep 22, 2017 4:14 am Post subject: Re: End play and paper or metal gasket? |
I am thinking this is pretty bad. What are my options? Note, this is without any shims. I have a beetle case I could build over the winter, keeping the old engine together so I can't back it in and out of the garage, put it on the lift, etc. not to run more than a few minutes. I know that if you want to use the beetle engine/case, you must have an adapter. Some on the formum have said this is not optimal.
Tcash Samba Member
Posted: Fri Sep 22, 2017 9:21 am Post subject: Re: End play and paper or metal gasket? |
DougClink wrote: |
I am thinking this is pretty bad. What are my options? Note, this is without any shims. I have a beetle case I could build over the winter, keeping the old engine together so I can't back it in and out of the garage, put it on the lift, etc. not to run more than a few minutes. I know that if you want to use the beetle engine/case, you must have an adapter. Some on the forum have said this is not optimal. |
In your first picture. After you pushed the crankshaft and main bearing toward the fan pulley. Then pushed the crankshaft back toward the flywheel. The bearing moved .033"?
What is your second picture all about. You have to have the flywheel and shims in place to measure crankshaft end play. But if your Main bearing is moving .033" it does not matter.
Throw the shims, seal and flywheel back on it and build the bug engine, or pull this one and build it.
Good luck
Tcash |
airschooled Air-Schooled
Posted: Fri Sep 22, 2017 11:30 am Post subject: Re: End play and paper or metal gasket? |
All that mumbling about with a dial indicator on a bearing seems funky to me. There are other ways to ensure the bearing is not moving. I'm too lazy to retype it, so here is what I said to the last guy:
http://itinerant-air-cooled.com/viewtopic.php?f=46&t=12721&p=216430
www.airschooled.com |
Posted: Fri Sep 22, 2017 2:16 pm Post subject: Re: End play and paper or metal gasket? |
It's not about seeing IF the thrust bearing is moving: it's about how MUCH, and if you're gonna roll it as is till the next rebuild, and knowing how much end play is thrust, and how much is flywheel shimming, so that we can set proper flywheel spacing from the thrust bearing.
For the OP, I'd consider 0.033" a finished case...time to tear down.
In my case, 0.003 movement isn't worth me tearing down a POS 1600, that's going in the trash pretty soon. But I still want to put it back together so it's mobile until I can get around to building its replacement. It's pretty hard to set decent end play if the thrust movement is mucking up the numbers.
0.033 is too much, that plus the flywheel setting, and pretty soon the flywheel is damn near leaving the seal and letting oil out, at some point anyway.
(Edited to fix all my damn typos.)
Posted: Fri Sep 22, 2017 2:40 pm Post subject: Re: End play and paper or metal gasket? |
Thank you all again for your import. I was trying to do what busstom said to do from memory.
The second picture is from the second attempt of shroving the crankshaft towards the rear of the engine, i.e. rear of the car, and then hitting the pulley bolt with a rubber mallet. So it looks like theres an awful lot of movement. Do they make a bearing that can take up the space and save the case? I did look at the video provided that shows a shim, but it appears you would have to send your engine to California to have that done. _________________ Air-cooled Preservation Society
Posted: Fri Sep 22, 2017 2:50 pm Post subject: Re: End play and paper or metal gasket? |
Yes, they make thrust bearings with oversize, thicker shoulders (flanges), but you must have the case machined to match it.
By the way, Doug, sorry, I didn't read your post clearly. If you're putting it back together for temporary motation, it's probably gonna move you around the driveway and stuff alright. But keep in mind, that fore-aft movement of your crank is inducing a heavy lateral load on your connecting rods and piston pins, basically putting a bending moment on the rods and cocking the pistons in the cylinders every time you push the clutch in. Back in my stupid years, I ran one to the Pleasanton Bug Bash with sloppy end play, and spun the rod bearings on two rods...seized me up on the freeway. So just beware of the risks. |
Just us buses Samba Member
Joined: April 27, 2004 Posts: 195 Location: Where the nuthatch winters
Posted: Fri Sep 22, 2017 3:39 pm Post subject: Re: End play and paper or metal gasket? |
Just for the record, if you've not removed the oil seal, your shims are still in there. They go between the flywheel and bearing, around the crank. _________________ It doesn't matter where you start, it all comes together; it all falls apart. |
Posted: Fri Sep 22, 2017 11:30 pm Post subject: Re: End play and paper or metal gasket? |
I'd like to interrupt this thread to remind everyone that end play MUST be measured with the flywheel ON. There is no way to do it otherwise.
Posted: Sat Sep 23, 2017 10:58 am Post subject: Re: End play and paper or metal gasket? |
asiab3 wrote: |
Robbie |
Yeah, pretty sure EVERYONE understands that....that cogent point escapes NOBODY here. It's in every thread and book about this topic. What's NOT in every thread and book is how to measure the end play of a sloppy thrust cut so that the two numbers can be summed. YES, someone MAY have to TEMPORARILY reassemble a sloppy engine for one reason or another...and in that case, it'd be nice to know what number to set the flywheel shimming at, and just disregard the other number until the case can be properly repaired. Mumble on. |
Posted: Sat Sep 23, 2017 11:20 am Post subject: Re: End play and paper or metal gasket? |
Busstom wrote: |
asiab3 wrote: |
Robbie |
I'm not sure who peed in your cornflakes, but please look at the OP's second picture. There is no logical reason to have a dial indicator reading the crank snout without the flywheel when dealing with end play. BUT if you did read the crank end play without the flywheel, you might get something around .033 on an assembled engine.
I know YOU know to put the flywheel on, but it seems like the OP was measuring without the flywheel, which tells us nothing.
