Max Boost Samba Member
Joined: October 14, 2007 Posts: 38 Location: Los Angeles
Posted: Mon Sep 18, 2017 8:30 pm Post subject: Empi 40 carbs wont let my engine lid close |
Hello everyone,
I need some help!... so i have a 67 fastback and i just installed the some empi 40 carbs on my car but now it seems the linkage is sitting to high where i cant close my engine lid. Also i never notice but the right side of the motor is sitting slightly higher than the left.. any suggestion would be greatly appreciated.
I'll have some pics up tomorrow morning. |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22727 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Mon Sep 18, 2017 8:39 pm Post subject: Re: Empi 40 carbs wont let my engine lid close |
Sounds like the rear engine mount isn't shimmed properly. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Mon Sep 18, 2017 8:51 pm Post subject: Re: Empi 40 carbs wont let my engine lid close |
Tram wrote: |
Sounds like the rear engine mount isn't shimmed properly. |
Thats what I'm guessing too but its almost looks like it needs to drop about half inch down. |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Tue Sep 19, 2017 2:02 pm Post subject: Re: Empi 40 carbs wont let my engine lid close |
I had to slot the holes in my engine/trans mount and change the spacer in the rear to get enough space for mine to clear _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Posted: Tue Sep 19, 2017 5:27 pm Post subject: Re: Empi 40 carbs wont let my engine lid close |
W1K1 wrote: |
I had to slot the holes in my engine/trans mount and change the spacer in the rear to get enough space for mine to clear |
I'm going try and put a spacer on the rear mount hopefully it will bring down the motor enough. if not this would be another solution. |
Posted: Tue Sep 19, 2017 5:54 pm Post subject: Re: Empi 40 carbs wont let my engine lid close |
Heres some pics
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Posted: Wed Sep 20, 2017 5:23 pm Post subject: Re: Empi 40 carbs wont let my engine lid close |
Multi69s wrote: |
That's just way too close. It may be a pipe dream, but it should be more like this.
Depending on your fab skills, you should be able to get it close. |
yeah thats how it should look like. So i tried putting more shims and it brought it down slightly and took the heat protection on lid but its still rubbing on right side. more is still sitting higher on the right side. maybe a mount on the trans or body is making it sag? not sure... |
W1K1 Samba Member
Posted: Thu Sep 21, 2017 9:57 am Post subject: Re: Empi 40 carbs wont let my engine lid close |
you have to slot the trans mount holes (blue arrow, mine is a non stock trans mount) to drop the whole assembly down, otherwise you are working against the front trans mount like a see saw. I think I only went about 1/4" but that translates to about 1/2" at the rear hanger. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
Retrovan Samba Member
Joined: July 15, 2011 Posts: 524 Location: Port Elisabeth - RSA
Posted: Thu Sep 21, 2017 10:02 am Post subject: Re: Empi 40 carbs wont let my engine lid close |
Have you used the short manifolds, ??
The photo not clear but looks like the long manifold was used.
Herman _________________ 1968 Fastback Type 4 2 Lt. twin 34 ICT's (Red)
1952 Split Beetle 1835cc. twin 34 ICT's (Azur blue)
1975 Split Bus Type 4 1914cc. twin 34 ICT's (wh/aqua)
1972 Bay Panel-van with type 4 2 Lt. twin 34 ICT's (white)
2019 Beetle Flatbed Truck called MeFusco
1973 FT Hahn SP - Project 1776cc |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Thu Sep 21, 2017 10:27 am Post subject: Re: Empi 40 carbs wont let my engine lid close |
Mill the right manifold down 1/4" to match the left. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
OhHerrooo Samba Member
Joined: September 12, 2010 Posts: 1291 Location: Costa Mesa, CA
Posted: Thu Sep 21, 2017 10:39 am Post subject: Re: Empi 40 carbs wont let my engine lid close |
Retrovan wrote: |
Herman |
Agreed. I fit 40 IDFs under the decklid of my 68 with the CB Performance short manifolds. _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
OCT3 - Orange County Type 3's
www.evenkeelsurfshapes.com |
Posted: Mon Sep 25, 2017 5:01 pm Post subject: Re: Empi 40 carbs wont let my engine lid close |
Retrovan wrote: |
Herman |
I have the short manifolds. Its the Empi kit |
Posted: Mon Sep 25, 2017 5:04 pm Post subject: Re: Empi 40 carbs wont let my engine lid close |
W1K1 wrote: |
you have to slot the trans mount holes (blue arrow, mine is a non stock trans mount) to drop the whole assembly down, otherwise you are working against the front trans mount like a see saw. I think I only went about 1/4" but that translates to about 1/2" at the rear hanger. |
That's what happing now im working against the rear mount. Do you think maybe a push and pull linkage will work since that's whats holding me up now. |
Posted: Mon Sep 25, 2017 5:20 pm Post subject: Re: Empi 40 carbs wont let my engine lid close |
this is the kit I bought for the car
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Tue Sep 26, 2017 3:48 am Post subject: Re: Empi 40 carbs wont let my engine lid close |
It says right in the ad that it doesn't fit under the lid - not sure why you're surprised. |
Posted: Tue Sep 26, 2017 9:35 am Post subject: Re: Empi 40 carbs wont let my engine lid close |
RamFlo are the best for fitting under the deck, but you might have to modity them to fit EMPI HPMX?
https://www.lynxauto.com.au/ramflo-air-filters/ram...ttors.html _________________ https://imgur.com/user/FisherSquareback/posts
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22422 Location: Kimball, Mi
Posted: Tue Sep 26, 2017 10:45 am Post subject: Re: Empi 40 carbs wont let my engine lid close |
ataraxia wrote: |
I was just thinking that myself.
The OP could measure the height of his manifolds, and contact CB Performance and ask them to give him a measurement of theirs, so he'd known how much too tall the ones he has are. At least that's what I'd do. If they happen to be the same length, then I'd look at dropping the engine down methods. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
chizucc Samba Member
Joined: August 16, 2012 Posts: 281 Location: Los Angeles
Posted: Tue Sep 26, 2017 11:35 pm Post subject: Re: Empi 40 carbs wont let my engine lid close |
That's odd. I had the HPMX 40 set up and mine fit under the deck lid....shit carbs compared to my dells, but they fit. _________________ 1964 Notchback
http://www.thesamba.com/vw/forum/viewtopic.php?t=543579 |
Posted: Thu Sep 28, 2017 6:57 pm Post subject: Re: Empi 40 carbs wont let my engine lid close |
ataraxia wrote: |
The velocity stacks are not included because it wont fit under the decklid.. not the kit it self |
