Alaskaberrys Samba Member
Joined: June 19, 2016 Posts: 1001 Location: SE Alaska
Posted: Mon Oct 23, 2017 10:39 pm Post subject: Re: Another syncro Doka arrives!... or "WTF did I just do!?!" |
Well, next up was to restore the drivers side window to operational status. It had rolled down and refuse to come up for Busman at the docks in Belgium - all he could do was hastily throw up some self sticking plastic.
Plus I wanted to see what might be feeding this scary little pustule in the middle of the door. Pretty sure I knew....
So, once in the shop and window regulator removed and cleaned and awaiting a new little plastic bit that had disintegrated I did some exploring. The Doka received a new paint job some years back and looks like a fairly extensive rust remediation job was done - lots of Por-15 on the chassis, rubber undercoating over that on the rockers with paint on top of that (opposite the GoWesty look). Good paint job - windows out, new rubber, don’t think they had the dash out, but doors were off too. Attention paid to inside cavities and such.
But they missed some spots.....
Dead center of the door, hardest spot to reach. Right behind the bleb.
Well, treating the inside of the door cavity was relatively easy, brushed, blew, scrapped and cleaned and treated with POR-15, but now it looks like I’ll be detailing the outside too.
Might be a good spot for my business logo _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3416 Location: OR & CA (Oregon/California)
Posted: Mon Oct 23, 2017 11:26 pm Post subject: Re: Another syncro Doka arrives!... or "WTF did I just do!?!" |
where did you get that Nikota workbench? |
Posted: Tue Oct 24, 2017 1:02 am Post subject: Re: Another syncro Doka arrives!... or "WTF did I just do!?!" |
Our local candy store - Alaska Industrial Hardware. Got it quite a few years back. Had to buy a Doka to matching it. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
CdnVWJunkie Samba Member
Joined: February 01, 2004 Posts: 1110 Location: Sarnia, Ontario, Canada
Posted: Tue Oct 24, 2017 2:44 am Post subject: Re: Another syncro Doka arrives!... or "WTF did I just do!?!" |
Cool Syncro. I love the Escorial green.
In regards to your poor starting. I'd check the basics: proper operation of the GPs, no fuel is getting into your fuel system and timing. Also I'm not sure if you're aware of the AAZs achilles heel: crank sprocket key way wear. Unusual starting characteristics with AAZs can often be attributed to wear between the sprocket and crank snout. Take a 19mm or 3/4" 12pt socket and put it on the crank bolt and gently move it back and forth. If you can discern any movement in this union needs to be dealt with quick. |
Posted: Tue Oct 24, 2017 8:59 am Post subject: Re: Another syncro Doka arrives!... or "WTF did I just do!?!" |
Quote: |
Had to buy a Doka to matching it. |
haha ...and you paint your house trims, barn trims to match the Doka too?
I used to work for Nikota, they make very good tools but went bankrupt about ten years ago... |
Posted: Tue Oct 24, 2017 9:43 am Post subject: Re: Another syncro Doka arrives!... or "WTF did I just do!?!" |
0to60in6min wrote: |
I’ve found that living in a temperate rain forest you might as well just make everything green - it’s going to get there anyway eventually
That workbench is great - super stout, easy to add, clamp, bolt to and folds flat. Wondered why I hadn’t seen them in AIH recently. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
Posted: Tue Oct 24, 2017 10:11 am Post subject: Re: Another syncro Doka arrives!... or "WTF did I just do!?!" |
CdnVWJunkie wrote: |
Ahh, so that’s the color? Have been searching for VW colors as I wasn’t sure if it was a stock color or not in Europe and I’m going to need to be repainting that door and a few other spots at some point.
Thanks for the AAZ crank check tip. I’ve read a bit about that weak spot but haven’t done the wiggle test yet - it starts right up with glow plugs now that I got them working so I haven’t focused on the engine much yet. A good reminder to do so soon regardless. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
snowsyncro Samba Member
Joined: January 11, 2009 Posts: 1557 Location: East Preston, Nova Scotia, Canada
Posted: Tue Oct 24, 2017 4:05 pm Post subject: Re: Another syncro Doka arrives!... or "WTF did I just do!?!" |
Alaskaberrys wrote: |
Ahh, so that’s the color? Have been searching for VW colors as I wasn’t sure if it was a stock color or not in Europe and I’m going to need to be repainting that door and a few other spots at some point. |
Paint info here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=527875&highlight=escorial
RonC |
Posted: Wed Oct 25, 2017 12:10 am Post subject: Re: Another syncro Doka arrives!... or "WTF did I just do!?!" |
Thanks Ron for the link, that’s an awesome list kamzcab86 put together! Looks like I’ll be calling the local pain(t) store with some codes now...found some buried seam rust on the drivers side rocker to be dealt with.
...oh boy. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
Posted: Sun Jan 28, 2018 10:20 pm Post subject: Re: Another syncro Doka arrives!... or "WTF did I just do!?!" |
In between sorties of rust search and destroy, I've been slowly piling up more tasks to add to the green beast "to-do" list....
First, the cab height Vindic Canopy arrived!
I had it shipped from Wyoming, bought it from a Samaba add.
The seller disclosed its issues (besides its being 26 years old). Door damage, no keys and the struts were all toast. But pretty nice condition otherwise.
The seller did an amazing job of crating it up, I got lucky there. It would NOT have arrived as it did without them willing to source a large pallet and wrap it all up. Three shipping hops - one truck, one barge and a ferry ride - got it here and it arrived in the shape it left in (no I won't share how much I paid in freight ). These canopies are not known for their strength, in fact I'm hoping to dream up a way to beef up the main canopy in a fashion that would allow a roof top tent. Probably going to be adding a metal arch to the rear and fiberglassing that in. Still in the planning stages there....
First unpack, give it all a good going over and start disassembly;
Hey! Found a beer! Thanks
Six struts to source;
Most of the hardware looks restorable. Might need new handles if I want the locks to work, but after replacing some screws and bolts I think all will work as it should.
To the repair work. Cut out the broken fiberglass and started with the repair;
Then fiberglass filler - note how indented the whole area above the break was. Curious how it was damaged;
1st prime coat sanded. I'm not going to go crazy with the little imperfections, but am wanting to practice for that rust repair on the doka body
3rd and final prime coat;
Krylon rattle can white on the well cleaned inside and refinsihed outside;
Now only two more doors and the top itself....oh boy.
Anybody have info on the rear leg mounts?
Looks like they should be flush with the bed, but looks as tho this doka never had a Vindic mounted as no tell tale holes... _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
fleet_maintenance Samba Member
Joined: November 01, 2013 Posts: 323 Location: Upstate NY
Posted: Mon Jan 29, 2018 5:24 am Post subject: Re: Another syncro Doka arrives!... or "WTF did I just do!?!" |
Looks like you are off to the races. I've always had a soft spot for Dokas. Nice job on the glass work. |
Posted: Mon Jan 29, 2018 11:11 am Post subject: Re: Another syncro Doka arrives!... or "WTF did I just do!?!" |
fleet_maintenance wrote: |
Thanks! As long as that race is a slow one
Having never done any sheet metal restoration work I’m learning a lot with the fiberglass work. Any painting on the doka will be with rattle can - Juneau paint store set me up with good automotive primer, paint and clear coat in cans and this work helps get the technique dialed in. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
syncrodemaya Samba Member
Joined: February 24, 2017 Posts: 106 Location: Vancouver
Posted: Mon Jan 29, 2018 6:09 pm Post subject: Re: Another syncro Doka arrives!... or "WTF did I just do!?!" |
Hey AlaskaB! Here's some photos of the struts I'm using on the doors and also those mounts to the truck bed, looks like you have it in the right spot:
_________________ '88 Sunroof Syncro 2.1L |
Posted: Tue Jan 30, 2018 2:07 am Post subject: Re: Another syncro Doka arrives!... or "WTF did I just do!?!" |
syncrodemaya wrote: |
Hey SyncroD I had looked through those pictures you sent me earlier but missed that one of the leg on the bed. It does look to be flush. Thanks!
It looks as though there is only one bolt holding yours down tho!
And I did use your strut numbers to source some more, thanks again! _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
elizer Samba Member
Joined: May 02, 2016 Posts: 1462 Location: Northern Virginia
Posted: Tue Jan 30, 2018 7:41 am Post subject: Re: Another syncro Doka arrives!... or "WTF did I just do!?!" |
When you get to the rattle can keep the cans warm especially since you are in AK. You can set them in a bucket of hot water and shake the living crap out of them before you start. Do multiple thin layers. Do not be like me and get and spray a layer on a wet layer.
I have done a lot of rattle can and I never follow my own advice. It always turns out ok. Never the best but I have seen some amazing results from people who are more patient than me. |
Posted: Tue Jan 30, 2018 10:27 am Post subject: Re: Another syncro Doka arrives!... or "WTF did I just do!?!" |
Oh yea, so I think there should be more than one bolt to hold down the mounts in the corner...Mike in Belgium didn't put all of them in, thanks for reminding me!
After the engine is running my next priority is also fixing up the Vindic canopy and should bolt it down better. Your fiberglass work is looking great! _________________ '88 Sunroof Syncro 2.1L |
Posted: Tue Jan 30, 2018 11:51 am Post subject: Re: Another syncro Doka arrives!... or "WTF did I just do!?!" |
After the engine is running my next priority is also fixing up the Vindic canopy and should bolt it down better. Your fiberglass work is looking great! |
Really looking forward to hearing about the new engine!
Have you had any luck finding a boat shop for your canopy repairs? If not, it’s not hard, just really messy and fumey. If you’ve no garage you can fume up it can be done outdoors under a cover - coveralls, gloves, good respirator, orbital sander and some warmish dry weather (ok, perhaps that is asking a lot in the PNW...) _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
Posted: Tue Jan 30, 2018 12:01 pm Post subject: Re: Another syncro Doka arrives!... or "WTF did I just do!?!" |
elizer wrote: |
Ha! I can relate to those words - do as I say, not as I do. Anybody with kids does that!
I found the Krylon rattle can on the canopy was quite different then the stuff the paint shop mixed for me to use on the wheels (will post that soon). It flashed pretty quick and I built a layers up fast. Then clear coat 20 min later. Super fumie, respirator was a must. Was working in my shop so temps were controllable. We use a warm box on the construction site to keep spray foam and paint cans up to temp here, but I could see how the warm water would offer better more consistent heating. Good tip. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
Zeitgeist 13 Samba Member
Posted: Tue Jan 30, 2018 12:03 pm Post subject: Re: Another syncro Doka arrives!... or "WTF did I just do!?!" |
Those canopies must have sheetmetal frames inside if they're using rivets to attach the hardware. Just a random observation. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Tue Jan 30, 2018 12:16 pm Post subject: Re: Another syncro Doka arrives!... or "WTF did I just do!?!" |
Zeitgeist 13 wrote: |
Those canopies must have sheetmetal frames inside if they're using rivets to attach the hardware. Just a random observation. |
I really wanted to find that out - but there were no “holes” to peer into and was reluctant to make new ones. I think if there is any metal in there it’s just a piece glassed in under the rivets before the form was glassed in place. I initially thought those were solid forms, but you could hear bits of material ratteling around inside as you flip the panel over. I was initially worried they might start to loosen but they are all rock solid so far. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
