Vangon Sliding Door Latch Replacement
crentist
crentist is offline
PostPosted: Tue Sep 19, 2017 11:51 am    Post subject: Vangon Sliding Door Latch Replacement Reply with quote
A bit ago my neighbor was helping me push my broken down '81 Vanagon and unbeknownst to me while he was doing so he was holding down my sliding door handle and using it as leverage. Afterwards the sliding door refused to open. I was able to determine it was a problem inside the latch mechanism and that it needed to be replaced.
So I ordered a sliding door latch from Parts Palace that was supposed to fit all Vanagons 80-92. Except when I got it I realized that it's very similar to, but slightly different from mine. Mine is on the left, with the extra little hook part and the other one is the one that I bought, which is missing that piece and is slightly smaller. I've tried to find a part that matches mine online, but I haven't been able to (other pic is my latch's serial number). Does anyone know where to get this part? Or of a VW graveyard somewhere in the Los Angeles area that might have one? I'm desperate! Thanks!
pomfritz
pomfritz is offline
PostPosted: Wed Sep 20, 2017 7:53 am    Post subject: Re: Vangon Sliding Door Latch Replacement Reply with quote
I don't know exactly when they switched the part but probably around 86. I replaced mine on an 83 and mine is like the one on the right. The place you got it should try and get you the part you need. Otherwise check ebay for a seller of Vanagon parts in Citrus Heights, CA. Jason, he has a Vanagon boneyard.
83.5 233K. GW 2.3, SS exhaust, My German Frau named her Stefi
crentist
crentist is offline
PostPosted: Thu Sep 21, 2017 10:08 pm    Post subject: Re: Vangon Sliding Door Latch Replacement Reply with quote
Thanks for the advice. Place I bought it from says they don't have any others like it unfortunately.
levi
levi is offline
PostPosted: Thu Sep 21, 2017 11:48 pm    Post subject: Re: Vangon Sliding Door Latch Replacement Reply with quote
https://www.thesamba.com/vw/classifieds/search.php...door+latch
I believe you want a latch no later than 84.
Check the samba classified section above.
One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40
djkeev
djkeev is offline
PostPosted: Fri Sep 22, 2017 4:20 am    Post subject: Re: Vangon Sliding Door Latch Replacement Reply with quote
This thread discusses Vanagon body changes during the production run.....
The sliding door change is mentioned.
Ghia
Vanagon
Beetle
