sgellis Samba Member
Joined: July 06, 2016 Posts: 2002 Location: SW Nova Scotia, Canada
zimblewinder Samba Member
Joined: January 22, 2004 Posts: 893 Location: Australia
Posted: Fri Mar 22, 2019 6:50 am Post subject: Re: Bus CAD model build |
I was thinking of you today. I was following a Suzuki swift AWD (latest model) along here in Japan and it has a very short rear diff that may be a solve for your worm gear problem. I think the SX4 is the same mechanically too. _________________ 58Euro 23 343208 The Ultimate Zimblewinder Machine.
59 mango standard
Wanted- splash pan supports, og pressed bumper coach bolts, ivory blaupunkt knobs (early), armrest alloy strips, NOS door mechanism |
ThumperDone Samba Member
Posted: Sun Mar 24, 2019 7:16 am Post subject: Re: Bus CAD model build |
j.pickens, No I haven't seen a setup like this in person, unless it was a tractor.
Design wise it might be as simple as creating (copy) the bellhousing ring/pinion area of a stock trans and gear it like running in normal 2nd or 3rd gear, like the normal Trans type conversions. This would only require a custom worm drive housing. That could be a cylinder the same dia as the motor to bolt right up to it. Hard part would be sourcing the gears unless I really did snag them from a Dub trans.
The major benefit I see in this design is moving as much weight forward as possible. A side effect, the engine floor area can now be converted to a bolt-in bowl/box that fits that area to house all the electronics out of sight. Making the engine bay a real trunk.
I know I can do it, just what will it take. |
Posted: Sun Mar 24, 2019 7:18 am Post subject: Re: Bus CAD model build |
sgellis, I can respect that. I like doing things once so I prefer them be right the first time if at all possible.
Yes, I even bookmarked his Youtube channel to keep an eye. My bus looks almost exactly like his color, year and all. |
Posted: Sun Mar 24, 2019 7:24 am Post subject: Re: Bus CAD model build |
zimblewinder, Do you mean the Suzuki SX4 and it's differential? If so, ok I game to look. Know where I can find some specs or at least it dimensions? |
easy e Samba Member
Joined: May 28, 2008 Posts: 3930 Location: 1 hr north of Santa Barbara
Posted: Sun Mar 24, 2019 12:44 pm Post subject: Re: Bus CAD model build |
sgellis wrote: |
This is the current state of the frame. Mostly correct but I need to verify the dimensions. |
Maybe draw some (A, B, C, ...) dimension lines & we can help fill in the blanks for you. _________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Posted: Mon Mar 25, 2019 4:31 pm Post subject: Re: Bus CAD model build |
Updated the differential to something that should be able to be built or modded. The dimensions are the same as a stock tranny and the overall length from rear of the motor to the cover of the differential is under the normal tranny length.
The electric motor is modeled at 16" by 9" in dia. so it should fit as it is about the size of the gearbox but need to measure more to know for sure.
The transmission plate is in the correct position in both models to show position of the differential correctly in comparison.
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9787 Location: Exit 7, New Jersey
Posted: Mon Mar 25, 2019 9:58 pm Post subject: Re: Bus CAD model build |
I'm guessing that there's gotta be an existing differential that meets these specs out there somewhere. That setup would go a long way in improving the performance of the retrofit.
It would allow a less powerful, smaller motor, and with electric cars, that is everything. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Allrounder Samba Member
Posted: Sat Oct 26, 2019 11:52 am Post subject: Re: Bus CAD model build |
Do you have a drawing of the small roof windows for a Samba Bus??
I need to get some cut for a friend.
/Rolf |
wcfvw69 Samba Purist
Posted: Sat Oct 26, 2019 2:44 pm Post subject: Re: Bus CAD model build |
I'm really loving these drawings. Nice job! _________________ Contact me at [email protected]
The Samba member since 2004.
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6558 Location: Houston, Texas
Posted: Sat Oct 26, 2019 3:08 pm Post subject: Re: Bus CAD model build |
This is really nice.
I don't know about Fusion 360 but you should be able to model every small detailed piece of metal and have it fit together in your CAD model. From these pieces you can construct the model as a whole. Then if you want to know what a specific piece is you can go through the model and look at it.
I've seen this done in Aveva. _________________ www.vwnos.com [email protected]
TimPrue Samba Member
Joined: February 01, 2020 Posts: 2 Location: Toowoomba, Queensland, Australia
Posted: Tue Feb 04, 2020 3:18 pm Post subject: Re: Bus CAD model build |
Hello sgellis,
We have a 68 Split screen which was originally from Brazil. We had it sandblasted which has exposed extensive rust throughout the lower panels and "chassis". There is so much rust in the main support "subframes" that I am surprised it did not bend in half.
Are you yet in a position to share the CAD files of the drawings you have been compiling?
Regards,
Tim
Toowoomba, Australia |
Posted: Tue Feb 04, 2020 6:30 pm Post subject: Re: Bus CAD model build |
TimPrue wrote: |
Hello sgellis,
Regards,
Tim
Unfortunately I have been very busy so don't have any more drawings ready. I hope to get the cross members finished soon though. I want to insure any drawings I share are good. _________________ My 64 Kombi restoration
My camper interior build
My 54 standard restoration
The Nova Scotian Barndoor (YouTube)
The Nova Scotian Barndoor (CAD drawings) |
vilavolks Samba Member
Posted: Sat Mar 28, 2020 1:28 pm Post subject: Re: Bus CAD model build |
Hello! Was this project completed? |
jammytask Samba Member
Joined: June 02, 2007 Posts: 12 Location: Central France (was Wales)
Posted: Sun Mar 29, 2020 4:46 am Post subject: Re: Bus CAD model build |
That's a highly impressive piece of work so far sgellis, superb. |
jborregoy2k Samba Member
Joined: October 16, 2016 Posts: 30 Location: El Carmen de Viboral, Colombia
Posted: Thu Jul 23, 2020 9:09 pm Post subject: Re: Bus CAD model build |
sgellis wrote: |
Amazing job!. I'm currently restoring a 52 barndoor pickup and will use your frame as a basis to my parts.
It's possible to have this complete frame you show in the picture in Autodesk Inventor or Fusion to adjust it to the one in my car? Will post some barndoor specific parts as soon as I develop the project.
Appreciate your support.
Posted: Fri Jul 24, 2020 5:17 am Post subject: Re: Bus CAD model build |
jborregoy2k wrote: |
The parts I made available are good enough to build from. Remainder need work so have not made publicly available. I will share the models but know they are not perfect.
I can share the complete assembly for inventor but the parts will be just dumb solids. I can share assembly as a F3z but it will need to be imported into a Fusion project so parts do not loose construction data.
Do you have a Fusion 360 login? I can also setup a team and add members to a shared project. _________________ My 64 Kombi restoration
Posted: Fri Jul 24, 2020 3:56 pm Post subject: Re: Bus CAD model build |
sgellis wrote: |
Do you have a Fusion 360 login? I can also setup a team and add members to a shared project. |
I will create one, and send it to you. I'm not familiar with it, but will learn.
Jorge |
3B(G) Samba Member
Joined: June 12, 2006 Posts: 37 Location: Cleebronn / Germany
Posted: Wed Aug 05, 2020 12:27 pm Post subject: Re: Bus CAD model build |
hello
i made the next parts
front outrigger
_________________ greetings from Germany
Daniel
65 Panelvan
05 Multivan |
