Fogerty1970 Samba Member
Joined: August 02, 2012 Posts: 106 Location: The Great American Southwest
Posted: Tue Sep 19, 2017 8:48 pm Post subject: Battery light after re-wiring alt/starter wiring |
I decided to re-wire my alternator and starter wiring after I found this:
https://www.thesamba.com/vw/forum/viewtopic.php?t=686514&highlight=
Given I have a larger house battery, I went with 4awg. One wire from the alternator post to the junction box 12v post, another from the starter to the same junction box post, which replicated the wiring I took out. The blue wire I do not need, as I have an ej22, with a 90 amp alt from a 2001 subaru baja. I basically just re-did the wiring, only made the wires larger for faster charging.
Now the battery light is on/flickers and I am charging at upwards of 14.9V. Idle is somewhat erratic, voltage jumps and falls and the alternator puts out a noticeable whirring noise when all loads are on (lights, blower, stereo, etc.).
Was 4 awg too much, or is it possible the alt is on the way out? Never had the light come on in the previous setup, but the wiring was in need of changing.
Thanks, y'all _________________ 1984 Wolfsburg Westy, EJ22.
"I'd rather have a bottle in front of me than a frontal lobotomy." -T. Waits. |
