dannyX24 Samba Member
Joined: August 05, 2016 Posts: 82 Location: Simi Valley, California
Posted: Thu Jan 18, 2018 1:02 am Post subject: Re: Type 3 truck, with a twist. |
marchi wrote: |
Dont really need drop spindles on a T3 beam. I have the oldspeed narrowed control arms on Flamer, been about 4yrs, love them. the rear end you might beable to just stretch the fender a lil. |
What did you do to lower the front end on the fastback?? |
marchi Samba Member
Joined: August 10, 2005 Posts: 646 Location: Abilene, Texas
Posted: Thu Jan 18, 2018 6:49 am Post subject: Re: Type 3 truck, with a twist. |
The front end is torsion just like the rear, loosen reatining bolt but dont take it out, on opposite side you are adjusting. mark current position, then remove grub screw on control arm and rotate up for lower, thats the basic there is a more descriptive break down in the forums _________________ I drive my VW or I walk
'70 Squareback
'21 Tiguan (daughters)
SOLD
'69 Fastback (Flamer) |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Fri Jan 19, 2018 1:09 pm Post subject: Re: Type 3 truck, with a twist. |
Put a jack under the lower A arm & take the downward pressure off the ball joint when you're removing/installing the horizontal ball joint bolt. You will ruin the threads if you don't! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Fri May 25, 2018 3:42 pm Post subject: Re: Type 3 truck, with a twist. |
Hey folks! Been a little while since I've posted. Been really busy with work stuff and My wife and I are expecting our first kid in November! I would really like to get the truck running before my kid is born so that I can drive it to go get the bodywork started. Is there anybody in ventura county area of southern california that could lend a hand if I get lost trying to get this thing running? it would be nice To have someone around who knows more than I do about these cars (and I don't know too too much 😃).To refresh, I have an engine and trans that came out of a running driving squareback, there is a harness in the car already so I'm going to start working on plugging it all back in.Hope everyone is doing well! -danny |
Posted: Fri May 25, 2018 5:09 pm Post subject: Re: Type 3 truck, with a twist. |
Take it to ISP West in Carson, CA as they are Type 3 specialists! _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Fri May 25, 2018 5:32 pm Post subject: Re: Type 3 truck, with a twist. |
I wish I could Mike! They are definitely the right people and I'm sure they would get a kick out of the car. But I just don't have the money for that and I'd like to do as much as I can for the knowledge/experience. I have a family friend that does bodywork for a living, I know alot of horror stories start that way but I wouldn't take it to someone I wasn't sure did good work lol. Currant plan is to make it run and drive at my place then drive it to said friends place for the bodywork. |
Posted: Sat Jun 16, 2018 12:29 pm Post subject: Re: Type 3 truck, with a twist. |
Quick update, nothing too exciting. Did some rust minor rust repair on the passenger side interior and got a new exhaust to replace the trashed header that was on the engine. Just something to run until the truck gets a newer watercooled powerplant.
Posted: Sat Jun 16, 2018 12:44 pm Post subject: Re: Type 3 truck, with a twist. |
Put this FI/AT engine in & get it running! I love mine in traffic etc! Support the chrome end of that 'single quiet pack' exhaust or it will hang/drag.
Posted: Mon Jul 02, 2018 5:07 pm Post subject: Re: Type 3 truck, with a twist. |
Did a little cleaning and moving stuff around today. Will start the wiring tomorrow. Hope everybody has a fun and safe 4th!
Posted: Mon Jul 02, 2018 5:09 pm Post subject: Re: Type 3 truck, with a twist. |
Mike Fisher wrote: |
Working on it brotha! Hoping to be able to drive it for a little while before academy starts and baby shows up, then drop it off for body work while I'm completely preoccupied for the next year or so. |
VeeDubWolf Samba Member
Joined: July 12, 2010 Posts: 656 Location: Yakima, WA
Posted: Mon Jul 02, 2018 7:01 pm Post subject: Re: Type 3 truck, with a twist. |
Every little bit helps, good to see an update!
A fun/safe 4th to you too! _________________ Two Bugs-
'70 rust-bucket sunroof sedan
'69 PO hack-job special
-Plus a wide assortment of various parts'n'junk |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Tue Jul 03, 2018 10:41 am Post subject: Re: Type 3 truck, with a twist. |
Agreed. Thanks for the update. Keep plugging along as best you can, as it helps create space that you lost. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Tue Jul 17, 2018 2:57 pm Post subject: Re: Type 3 truck, with a twist. |
Got alot of the fuel line and some vacuum line replaced. Figured out I'm going to need some linkage pieces for the throttle body, throttle pedal, and transmission. Also scored a work bench and 2 grinders from Craigslist today!
Posted: Thu Jul 19, 2018 9:33 am Post subject: Re: Type 3 truck, with a twist. |
My OG fuel hose had pinhole leaks, so replace every piece of yours! Put up a WTB ad for all the parts you need to get it running/driving. _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Mon Jul 23, 2018 8:47 pm Post subject: Re: Type 3 truck, with a twist. |
Stripped the old harness off the donor engine and started hooking up the harness in the car. Pretty close to making noise Hopefully!
Posted: Tue Jul 24, 2018 9:37 pm Post subject: Re: Type 3 truck, with a twist. |
Engine and trans mounted, still have alot of the little stuff to button up but I had to drop it on all fours to see it settle down a bit
Posted: Wed Jul 25, 2018 2:41 am Post subject: Re: Type 3 truck, with a twist. |
Dang, it's looking nice! Looks like it was made to be! _________________ Two Bugs-
Posted: Mon Jul 30, 2018 4:09 pm Post subject: Re: Type 3 truck, with a twist. |
Couple small things today, got a throttle return spring, intake bellow on but needs a little adjusting, exhaust is on. I know the exhaust is way wrong but it was super cheap and will be changed when i upgrade to a hotter engine. Also discovered my throttle cable has been broken for a very long time but was left in the car lol.
Posted: Mon Jul 30, 2018 4:13 pm Post subject: Re: Type 3 truck, with a twist. |
Posted: Mon Jul 30, 2018 4:27 pm Post subject: Re: Type 3 truck, with a twist. |
Hook up your heaters & your wife/baby will love you & the pickup! Every car has/needs a heater when it's cold. _________________ https://imgur.com/user/FisherSquareback/posts
