Was there ever an angled adaptor for SP intakes to 1200 heads?
hanksjim1
hanksjim1 is offline
PostPosted: Thu Sep 21, 2017 8:08 am    Post subject: Was there ever an angled adaptor for SP intakes to 1200 heads? Reply with quote
Did anyone ever come up with a simple angled wedge adaptor (or plans for one) to allow single port dual carb manifolds to work on the flat 1200 40 HP heads?
If not, is there some reason it won't work (port sizes, mounting studs, etc)?
I am building a 1385, have a set of NOS square boss 1200 heads and a pair of refurbed baby dells that came with the later single port manifolds.
Would prefer not to have to buy 1300 heads or fabricate custom intakes.
Input from the 40 HP gurus appreciated.
hanksjim1
PostPosted: Sat Sep 23, 2017 8:36 am    Post subject: Re: Was there ever an angled adaptor for SP intakes to 1200 heads? Reply with quote
Anyone? I can only assume there is some technical reason why a simple adaptor hasn't been used. Please chime in if anyone knows why.
slo356
slo356 is offline
PostPosted: Sat Sep 23, 2017 8:37 pm    Post subject: Re: Was there ever an angled adaptor for SP intakes to 1200 heads? Reply with quote
Thought your same thoughts, but have never seen one.
I believe Volkswagen built more 40hp engined cars through '67 than 25/36hp and 1300/1500's. Yet almost nothing in performance parts has ever really been available for the 1200/40hp's. For example, twin carbs setups are available for everything but not 40hp's. I once asked WW owner why he didn't produce a twin setup like the his offering for 36hp's. He told me not enough demand… Personally I find that hard to believe.
So I don't know why the angled adapter you are suggesting hasn't been produced. Seems like a inexpensive piece that would help the 1200/40hp owners go for twin carbs, the single best thing you can do for a horizontal four.
BUT, I would really like to see a high quality twin carb kit for the good ole 1200/40hp's!
'65 T1 Sedan
'87 T3 Syncro
Kjell Roar
Kjell Roar is offline
PostPosted: Sun Sep 24, 2017 1:44 am    Post subject: Re: Was there ever an angled adaptor for SP intakes to 1200 heads? Reply with quote
I think you can adapt 36hp intakes into 40hp heads quite easily, depending on tools and skills. 61 and 62 intakes are equal with 36 hp, 63 and newer got 34mm gasket insread of 32mm, bigger intakes.
Riechert got the intakes for 1200, good quality from Germany. Sells complete or parts. Some delivery time, though.
http://www.riechertmotorentechnik.de/en/solex28.htm
I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438
John Moxon Premium Member
John Moxon is offline
PostPosted: Sun Sep 24, 2017 6:16 am    Post subject: Re: Was there ever an angled adaptor for SP intakes to 1200 heads? Reply with quote
Kits still to be found in the Samba Classifieds and reproduced by Alejandro Martin.
John.
fl59bug
fl59bug is offline
PostPosted: Sun Sep 24, 2017 6:48 am    Post subject: Re: Was there ever an angled adaptor for SP intakes to 1200 heads? Reply with quote
I echo your sentiments 1,000,000,000 times lol. It is frustrating that no one has taken up the cause and repopped some of the critical and/or hard to find parts for our 40 horsers.
Of course it would be icing on the cake to get performance 40 horse parts, but heck I'd settle for things like cylinder heads (bare castings or with all the parts I don't care Smile), crankshafts, intake manifold, pushrods, flywheels.
I really would like to know of there are more 36hp engines still in service or 40s. Seems like the answer to that question, if known, would move the manufacturers to produce whichever parts are going to enhance their economic bottom line.
To the OP this is a great question on the adapter, but I just don't recall ever having seen or heard of anything like this. With such a part available I'm guessing all us guys still limping our rusty crusty plugged up 40 horse intake manifolds along could then use the 1300 and up manifolds? Maybe not though if those manifolds would still be too wide due to the extra width of the later engines they were made for.
earthquake
earthquake is offline
PostPosted: Wed Sep 27, 2017 2:23 pm    Post subject: Re: Was there ever an angled adaptor for SP intakes to 1200 heads? Reply with quote
What if you used a set of PDSIT manifolds and either cut a pie wedge piece out and welded them together or welded the 1200 manifold flange on to the PDSIT manifold, then you could either use the Solex carbs or make a aluminum adapter to mount Weber ICT's Or use your Baby Fred's
I know you don't want to have make a set of manifolds but I don't see any other way.
Casey
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
earthquake
PostPosted: Wed Sep 27, 2017 2:50 pm    Post subject: Re: Was there ever an angled adaptor for SP intakes to 1200 heads? Reply with quote
OK, How about a single two barrel manifold...
this manifold is about 23 1/2" center to center on the head interface, I did not measure the diameter at the head but can if some body want to know let me know. I think with a well tuned Weber 36-40mm DCNF on a 1383 with a header would run great, maybe a cam
Casey
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
Mr.Ragtop
Mr.Ragtop is offline
PostPosted: Thu Sep 28, 2017 12:06 pm    Post subject: Re: Was there ever an angled adaptor for SP intakes to 1200 heads? Reply with quote
Casey
I actually pulled a set out of my junk stash thinking of the same idea. I have a few damaged 40hp stock intakes. Figured I could cut the flanges and make a quick set of dual carb intakes. My only concern is the height may be really short.
hanksjim1
PostPosted: Thu Sep 28, 2017 12:24 pm    Post subject: Re: Was there ever an angled adaptor for SP intakes to 1200 heads? Reply with quote
Thanks for the suggestions guys.
I have been in touch with Alejandro Martin...I was thinking maybe the Sprint Stromberg manifold adaptors (the manifolds are universal, they use adaptors for the 1200 or 13-1600 applications).
Need a bit more info on dimensions to confirm suitability.
A bit spendy at $180. the pair.
My alternative is to just go with 1300 heads. The larger valves might be a bonus and fewer chances of leaks.
Stinde
Stinde is offline
PostPosted: Fri Sep 29, 2017 12:21 am    Post subject: Re: Was there ever an angled adaptor for SP intakes to 1200 heads? Reply with quote
40 horse intakes are rare as we know, i have these and never saw other pair tde set for 40 horse? There is also riechert who sell intakes and full sets like they say but they are quite expencive.
hanksjim1
PostPosted: Fri Sep 29, 2017 4:16 pm    Post subject: Re: Was there ever an angled adaptor for SP intakes to 1200 heads? Reply with quote
Those look very nice...have you ever driven with them?
Stinde
Stinde is offline
PostPosted: Fri Sep 29, 2017 10:37 pm    Post subject: Re: Was there ever an angled adaptor for SP intakes to 1200 heads? Reply with quote
Yes i am, they work real nice! Change after one 30-pict was awesome! I use 34 pci carbs.
PEPPE
PEPPE is offline
PostPosted: Mon Oct 23, 2017 2:45 pm    Post subject: Re: Was there ever an angled adaptor for SP intakes to 1200 heads? Reply with quote
contact Feller Service in France, they realize an adaptor for 1300-1500 manifolds https://www.fellerservice.fr/motorisations/speedwell/
hanksjim1
PostPosted: Mon Oct 23, 2017 2:59 pm    Post subject: Re: Was there ever an angled adaptor for SP intakes to 1200 heads? Reply with quote
Thanks! I just checked their site out; nice stuff!
Angus Dowrie
Angus Dowrie is offline
PostPosted: Tue Oct 24, 2017 4:31 am    Post subject: Re: Was there ever an angled adaptor for SP intakes to 1200 heads? Reply with quote
This is a Riechert kit on my '63 Ghia. Last of the stale-air, first of the 34mm inlets. Still 1200cc, 28 PCIs. bought much of it second hand, but the linkage assembly plus a few other minor bits were bought brand new. All parts were still available as of about 12 months ago.
It does make a noticeable difference, but still not a powerhouse.
1963 Australian Delivery RHD Coupe
Build thread;
http://www.thesamba.com/vw/forum/viewtopic.php?t=610414
Lingwendil
Lingwendil is offline
PostPosted: Sat Oct 28, 2017 2:20 pm    Post subject: Re: Was there ever an angled adaptor for SP intakes to 1200 heads? Reply with quote
That engine is probably one of the top 5 best I've ever seen. It nails the look and spirit of vintage speed! Excellent job!
73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087!
