Bzonic Samba Member
Joined: September 22, 2017 Posts: 62 Location: Cleveland
Posted: Fri Sep 22, 2017 7:36 am Post subject: 59' versus 64' - which one appeals to you? |
Greetings all,
I’d like to tap into the wisdom here and gather some opinions on a few nice beetles that I’m weighing the pros and cons of. I’ve narrowed it down between a 59’ and a 64’ both with some obvious pros and cons inherent to their specs. I’m curious what others would consider the better choice based on my criteria of decent driving experience, originality, and future hassle factors (parts availability). Unfortunately I do not have 100% of the back story on these vehicles but I will list what I know.
The 64’ sea blue – 100% original inside and out. Faded paint but pretty good and not yet buffed out. 31,000 original miles with no rust anywhere and unmolested as far as I can tell. I’m not sure if there will be some routine work necessary in near future. After 31,000 miles what can I expect to need to work on in the near future?
The 59’ capri blue – repainted recently but I’m not sure if much else was “restored”. I know the carpet is wrong and a few other details (fuel gage). Looks very solid overall with a fresh undercoat job too. I’m assuming it has the correct 36hp engine along with the necessity for dead stop 1st gear shifting.
The 59’ is a striking car with the new paint and older details but the drivability of the 64’ and originality are appealing too. Which one would you guys lean towards? Thanks very much for your insight!!
vwfreek61 Samba Member
Joined: May 31, 2004 Posts: 350 Location: Green Bay, WI
Posted: Fri Sep 22, 2017 7:48 am Post subject: Re: 59' versus 64' - which one appeals to you? |
I'd go with the original paint. You never know what's hiding under a fresh repaint. _________________ Kenneth
1964 Bug with Saxomat
1976 VW/Harley Trike Autostick
1987 Vanagon Westy w/Subaru EJ25 and reversed 4EAT |
turbotype1 Samba Member
Posted: Fri Sep 22, 2017 8:02 am Post subject: Re: 59' versus 64' - which one appeals to you? |
64 for sure..... It's only original once _________________
117harv wrote: |
This new fad of get it the lowest, or run it with the worst looks, (patina) isn't cool, it's for the hey everyone look at me crowd, i'm driving a beat down ratty, unsafe, VW, how cool am I ???...your not....
Pissing off the purists since 1997
Wanted: Boyd Motors plate frame
57 Turbo Oval Sliding rag
67 13 window delux walk-thru- now 21
64 all original for the misses
83 Sinka m-TDI diesel |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Fri Sep 22, 2017 9:55 am Post subject: Re: 59' versus 64' - which one appeals to you? |
If the 31k is true- then the '64 is a REFERENCE level car. You may never see another one. Repainted beetles fall from trees around here. I'd pull the 80s crap off it- especially that hood pull chrome thingie and the eyebrows. If those wide whitewalls have an old date on them- jettison those too in favor of period correct narrower WWs. If it had a sunroof- I'd be knocking on their door tomorrow. _________________
EverettB wrote: |
FU#5 |
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1357 Location: Richmond, VA
Bzonic Samba Member
Posted: Fri Sep 22, 2017 10:10 am Post subject: Re: 59' versus 64' - which one appeals to you? |
Thanks guys, My thoughts as well. Anything quirky about the 64' I should be aware of? Tips or tricks? |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Fri Sep 22, 2017 11:05 am Post subject: Re: 59' versus 64' - which one appeals to you? |
Is price an issue? I'm typically VERY skeptical of low mileage claims unless they are well documented. Have you checked the technical tab here to compare? A 31k car is very unusual and I would personally check 20 ways to Sunday to confirm it's true. I mean think about it, 53 year old car with only 31k on it. That's less than 600 miles per year...
All said and done, if the 64 is legit and the prices are comparable I'd choose it. By the same token, I like pre 60's so it's a matter of taste. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
smokey503 Samba Member
Joined: October 01, 2010 Posts: 713 Location: Ridgefield Washington
Posted: Fri Sep 22, 2017 11:29 am Post subject: Re: 59' versus 64' - which one appeals to you? |
For shits and giggles I'd check the pedal rubbers.
If they look worn out most likely there are many more miles on the car.
The 64 is a nice looking car though. _________________ If a car travels the speed of light, would the headlights work? |
Bzonic Samba Member
Posted: Fri Sep 22, 2017 12:27 pm Post subject: Re: 59' versus 64' - which one appeals to you? |
I'm not absolutely certain it is the original 31,000 miles but I will get a chance next weekend to look into it further. The file I saw regarding it's description from the previous owner only stated "100% original inside and out". Granted we all know what sellers can say if they choose to be dishonest. Unfortunately I do not have much more than that on its history. Are there any tell tale signs I should be looking for that indicate it has more than 31,000 on it? It has plenty of paint nicks on the lower front but I suppose that could happen within 31,000. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9759 Location: Oregon
Posted: Fri Sep 22, 2017 12:52 pm Post subject: Re: 59' versus 64' - which one appeals to you? |
Crawl underneath and have a look at the trans. If it's black painted, it's been rebuilt. The stock ones came unpainted.
Like smokey503 said, Check the pedal rubbers for wear. Yea they can be replaced to look new. But most folks don't really think about them. At least where I live they don't
Look for worn areas on the steering wheel too. Even a black wheel will display a dull finish where it has been handled over all the years of driving.
Why not just buy both cars and see which one appeals to you the best?
JK! I'm going on 58yo. So if it were me I'd be partial to the 59. That matches my age
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Fri Sep 22, 2017 2:14 pm Post subject: Re: 59' versus 64' - which one appeals to you? |
The 64 has more things going for it.
spring loaded front hood=no bending
better designed gas tank=more room under the hood
a gas gauge
most likely depending what state you live came with seatbelts
tunnel type fully synchronized box
new style steering column with a better ground for the horn
I like 36 and 40 hp equally, but 64 is a fresh air heater system is much better
more visible front turn signal lamps and rear stop and turn signal lamps.
Depending on your preference manual choke vs auto choke.
largest downside is the 36hp will get you much better MPG.
I'm sure with all the improvements every year the list from VW is even bigger. |
bluebus86 Banned
Posted: Fri Sep 22, 2017 2:21 pm Post subject: Re: 59' versus 64' - which one appeals to you? |
A windshield full of pits is a good sign the vehcile has many miles. Many time pitted glass is reinstalled when car is repainted, for the price of a Bug windshield, that is poor choice. Nothing like good vision.
Now a scratched by wiper windshield may not indicate many miles unless many pits present, Even a low mile car with a rotten wipper blade can scracth its windshield in minutes.
my recenlty aquired Bug had a nice new paint job, only 75K miles documented by the little old lady, garaged kept, yadda yadda, till a couple years before she sold me the bug got in a fender bender and had the whole thing repainted.
The paint shop reinstalled the very heavily scratched by wiper glass, UGH! It must have been driven all rainy season one year with torn rubber blades.
See if the marks on the glass indicate orignal or not. If original and not pitted, thats a good indication of low miles. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Fri Sep 22, 2017 2:26 pm Post subject: Re: 59' versus 64' - which one appeals to you? |
Based purely on your criteria of decent driving experience, originality, and future hassle factors (parts availability), I'd say the '64 is quite a bit closer to what you're looking for. As for myself personally, I'd lean toward the '59 primary due to the fact it isn't a low mileage original, and would therefore be easier for me to enjoy as a driver. _________________ 1960 Ragtop w/Semaphores "Inga" |
Bzonic Samba Member
Posted: Fri Sep 22, 2017 2:27 pm Post subject: Re: 59' versus 64' - which one appeals to you? |
Thanks Rustavenger and Heflin - great info that really starts to make this decision easier. I'm also thinking that if I need to do some work on it I will be starting on a fresh slate and not frustrated by something I discover the previous owner did poorly. As a first time poster I appreciate the truly helpful info. |
Bzonic Samba Member
Posted: Fri Sep 22, 2017 2:33 pm Post subject: Re: 59' versus 64' - which one appeals to you? |
Interesting Mukluk - I perceived the 64 to be a better driver but I completely see your point too. How challenging is driving a 36hp beetle? My first car 20 years ago was a 40hp java green 65 beetle and I remember not having issues too much. 36hp all that much noticeably slower? |
mukluk Samba Member
Posted: Fri Sep 22, 2017 2:59 pm Post subject: Re: 59' versus 64' - which one appeals to you? |
I can't say from personal experience, having only driven 1600's and a 40 horse. Taking into consideration the different gear ratios between stock 36 and 40 horse transaxles, I'd only guess that the 36 wouldn't be much slower than the 40 horse in normal driving up to about 60mph... the few videos on Youtube that I've watched with folks driving a 36 horse give the impression they get around just fine up to that speed. _________________ 1960 Ragtop w/Semaphores "Inga" |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Fri Sep 22, 2017 3:32 pm Post subject: Re: 59' versus 64' - which one appeals to you? |
If the 64 is original, why did they replace the front apron? |
jays58s Samba Member
Joined: August 23, 2004 Posts: 2133 Location: Nor-Cal
Posted: Fri Sep 22, 2017 4:02 pm Post subject: Re: 59' versus 64' - which one appeals to you? |
txoval wrote: |
What makes you think the front apron was replaced? |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Fri Sep 22, 2017 4:05 pm Post subject: Re: 59' versus 64' - which one appeals to you? |
I guess it depends on what your end goal is?
Are you going to modify the vehicle, or keep it stock "as is"? Do you plan on a paint job if you get the 64? I do agree that the 64 has more stock refinements, but the 59 IS A 59!
I'm going to go against the grain for a closer look at the 59. Yes, a fresh paint job, and undercoat are something that usually raise red flags, but what if they WERE done properly? Even a decent paint job is $5k+. If the body/chassis are done, you're just left with any mechanicals. If you want an all original vehicle, quadruple check all information on each vehicle. I don't care if the 64 had 3100 miles on it, I'm not driving it around on 53 year old brake components. At bare minimum, you would need all the rubber/hydraulic components.
Driving the stock version of each vehicle, the 64 would most likely be a little more practical/enjoyable with the factory refinements, but the 59 would get more "street cred". Modified with a stroker engine, the 59 is way cooler. Neither vehicle is going to be practical, but the 59 would be as driveable with the 36hp engine as the 64 with the 40hp.
Last edited by [email protected] on Fri Sep 22, 2017 4:11 pm; edited 1 time in total |
EVfun Samba Member
Posted: Fri Sep 22, 2017 4:10 pm Post subject: Re: 59' versus 64' - which one appeals to you? |
All elase being equal I would be inclined to buy the original paint car over a repaint. Repaints can be used to hide repairs and rust damage. Repaints can vary widely in quality and it's not always obvious until they age.
Of course all else is never equal. I prefer older, most of the appearance differences between a '59 and a '64 are old touches I like. Some of the mechanical changes on the '64 are nice to have, especially for a driver. The 36 is more costly to repair or rebuild, as is the splitcase (and 2nd gear syncro gets a workout.) The 36 is quite noticeably slower because not only do you have 10% less power you also have 7% taller gearing (the 36 horse Bug stock gearing is more like a later Bug with a 4.12 R&P.)
You will have to look at the price and condition of each car. Look for rust and accident damage and value accordingly. A lot of Bugs, even low mile ones, have had accident repair and marking a title for it is a more recent thing. Minor repairs that look right on the outside but slightly show underneath used to be common and can be fine in a driver, but still effect what you should expect to pay for it.
My drivers have been a '60, then a '63, and currently a '57. The '60 had the stock transaxle and 36 horse, then a big bore 40 horse. The split case gearing wasn't bad with either engine but the BB 40 was more powerful. The '63 had a stock 40 horse and I guessed a 4.12 R&P would be OK. NO, that combo sucked on the freeway, the stock 40 is designed for more rpm and needs it compared to the 36. My '57 has the stock 36 horse and a lower geared 40 horse transaxle. That drives pretty good but I have to consciously keep the speed held down to 65 mph on the freeway, and some urban freeway grades still drag me down to 55 mph or so. I've got the older and smaller brakes now too (and more expensive to work on), but a '59 wouldn't have that daily driver downside. _________________
Wildthings wrote: |
