Figuring out correct shocks for a lifted Thing?
MConstable
MConstable is offline
PostPosted: Fri Sep 22, 2017 10:47 am    Post subject: Figuring out correct shocks for a lifted Thing? Reply with quote
Hello guys, I'm tired of getting rattled to death from my gas adjust shocks so want to replace them.
Two problems...my Thing is lifted so I assume they aren't stock length shocks, and there's no part # on them for me to cross reference.
Any advice?
guppysoup
guppysoup is offline
PostPosted: Fri Sep 22, 2017 3:23 pm    Post subject: Re: Figuring out correct shocks for a lifted Thing? Reply with quote
Maybe just measure your gas adjusts and then talk to a Bilstein dealer/expert? I hated the gas adjusts on my Safari (loved em on bugs). The bilsteins made a huge difference for the better!
Good luck.
1973 Thing/Safari
1985 Bug/Bocho wanna be class 11
2010 Nissan Rogue
2014 VW Amarok TDI 4x4
2016 Nissan March
cousineddy
cousineddy is offline
PostPosted: Sat Sep 23, 2017 7:49 pm    Post subject: Re: Figuring out correct shocks for a lifted Thing? Reply with quote
I have the bilstein 5100 class 11 shocks on mine,they ride great on the street and off road
69 vert-draw thru turbo 2110
73 Thing
63ziggy
63ziggy is offline
PostPosted: Sun Sep 24, 2017 7:54 pm    Post subject: Re: Figuring out correct shocks for a lifted Thing? Reply with quote
the most accurate way would be to fully extend the suspension, take a measurement of shock mounting points. then collapse the suspension and take a measurement of shock mounts.
an offroad shop should be able to help locate the proper length shock for full drop and full compression.
with that said, if the front has adjusters and they are cranked, it won't change the shock length needed. similar to rear as long as plates are not notched and are factory plates that may just be re-indexed.
View user's profile Send private message Send e-mail AIM Address Instagram Gallery Classifieds Feedback
mondshine
mondshine is offline
PostPosted: Mon Sep 25, 2017 8:29 am    Post subject: Re: Figuring out correct shocks for a lifted Thing? Reply with quote
Here is a link to a table of Bilstein shocks (listed by physical dimensions):
https://www.my4by.com/bilstein-shock-specs.html
Hope that helps, Mondshine
Brian
Brian is offline
PostPosted: Mon Sep 25, 2017 11:52 am    Post subject: Re: Figuring out correct shocks for a lifted Thing? Reply with quote
Yes, measure twice.
Check out these guys: http://www.eshocks.com/bil_ORsb.asp?Series_Index=Q3&Manf=All&SubChar=Q
'69 Bug
'68 Baja Truck
'71 Bug
Ran when parked
