Tore my top... Patch?
rrankin
rrankin is offline
PostPosted: Fri Sep 22, 2017 1:17 pm    Post subject: Tore my top... Patch? Reply with quote
Can it be patched? Has anyone tried?
I love this top - It's a TTS top so it was expensive and I'd rather not have to buy and install a new one.
Anyone have any suggestions?
Thanks,
Robert R.
Austin, TX
'74 Thing [Fritz]
Austin, TX
View user's profile Send private message Yahoo Messenger Instagram Gallery Classifieds Feedback
ldj1002
ldj1002 is offline
PostPosted: Fri Sep 22, 2017 3:33 pm    Post subject: Re: Tore my top... Patch? Reply with quote
Thanks,
Robert R.
Austin, TX
If it tore easy it will likely tare again and again but it is at least a band aid. If it was tore because of "stuff happens" , carelessness, or other unfortunate reasons then patch it. I took mine off and had a awning shop put a nice patch on it. That was a waste of time and money because the top already had too many birthdays.
74 Thing
74 Thing is offline
PostPosted: Fri Sep 22, 2017 9:45 pm    Post subject: Re: Tore my top... Patch? Reply with quote
Where is the tear (was it a seam or is there a small hole)?
https://www.tear-aid.com/
These guys make a good patch that will get you through the winter-you can pick them up on Ebay in different sizes.
You can go to a convertible top shop as well and see if they can repair it.
EDragnDean
EDragnDean is offline
PostPosted: Sat Sep 23, 2017 12:05 am    Post subject: Re: Tore my top... Patch? Reply with quote
Thanks,
Robert R.
Austin, TX
Should patch easily enough unless along a pressure point such as the front edge, etc.
63 Double Cab http://www.thesamba.com/vw/forum/viewtopic.php?t=443823&highlight=deanos
66 Bus Click to view image - SOLD
73 Thing http://www.thesamba.com/vw/forum/viewtopic.php?p=8111202#8111202
70 BusClick to view image
rrankin
rrankin is offline
PostPosted: Mon Sep 25, 2017 3:39 pm    Post subject: Re: Tore my top... Patch? Reply with quote
Ok for $40 I got a functional patch to get me through until I can buy and install a new top.
'74 Thing [Fritz]
Austin, TX
vwjetboat
vwjetboat is offline
PostPosted: Mon Sep 25, 2017 3:48 pm    Post subject: Re: Tore my top... Patch? Reply with quote
see if it was me.. being where that is tore.. Id put in a zipper & make it big enough to put a surfboard threw.. and say its custom option for surfers..
kubelmann
kubelmann is offline
PostPosted: Mon Sep 25, 2017 6:35 pm    Post subject: Re: Tore my top... Patch? Reply with quote
We have seamlessly repaired soft tops, boat sails, and much more using
Marine Goop is the strongest single component adhesive and is great for multiple marine grade applications. Marine Goop will bond to glass, metal, canvas, wood, vinyl and rope and is ideal for stopping leaks in waders, wet suits, diving masks, rafts, and air mattresses.
https://www.westmarine.com/buy/eclectic-products--...k8QAvD_BwE
hobie16
hobie16 is offline
PostPosted: Mon Sep 25, 2017 6:51 pm    Post subject: Re: Tore my top... Patch? Reply with quote
Take it to a sail maker. I've had complete panels replaced for less than $100.
Don't be fooled by appearances. In Hawaii, some of the most powerful people look like bums and stuntmen.
--- Matt King
If anything’s going to happen, it’s going to happen out there.
---Captain Ron
wbailey2112
wbailey2112 is offline
PostPosted: Tue Sep 26, 2017 8:18 am    Post subject: Re: Tore my top... Patch? Reply with quote
I would take it to an auto upholstery shop for an estimate. Most are very experienced with convertible tops in addition to seats, dash boards, interior panels, carpet, etc. They can most likely patch it or, depending upon the location of the tear, replace the affected panel of the top with a similar material.
'74 Thing
'83 Westfalia
kubelmann
PostPosted: Tue Sep 26, 2017 11:53 am    Post subject: Re: Tore my top... Patch? Reply with quote
I keep Marine Goop on hand fro home brew repairs. It works great and can be nearly invisible if you applied with the top off the car. But if you have access to a good upholstery guy, that can be a great solution. I have a marine and golf cart upholstery guy. He does repairs for $40 hr. Not many problems he is unable to repair on an hour.
