ftp2leta Samba Member
Joined: October 11, 2004 Posts: 3271 Location: Montreal
Posted: Sat Sep 23, 2017 10:55 am Post subject: Fastest way to bleed a van with a new radiator |
I have replaced so many rad this summer that I had it with my manual pumping... So for Vanagon this is the fastest way to fill an empty rad:
-Close front rad bleed screw
-Fill rear EX tank, inject air (SLOWLY) until the EX thank is half full, close air valve, go in front and open rad bleed screw until air pressure is out. Close back rad bleed screw and start again about 3 time. Rad will overflow.... your done.
Voila, Ben
_________________ Working with rust, grease, dirt and dust is a sad truth.
FI part for sale: http://www.benplace.com/parts_sale1.htm
My site: http://www.benplace.com/vw2.htm
Subi conversion: http://www.benplace.com/vanaru_eng.htm
Youtube http://www.youtube.com/user/ftp2leta |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Sat Sep 23, 2017 1:19 pm Post subject: Re: Fastest way to bleed a van with a new radiator |
Thanks Ben. Just installed a new rad last week, but haven't refilled the system yet. I'll have to try this! _________________ This free advice is worth exactly what you paid for it.
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Sat Sep 23, 2017 2:23 pm Post subject: Re: Fastest way to bleed a van with a new radiator |
That fills and bleeds the supply line to the radiator, but you still could have air in the return line, particularly given you have just introduced a whole bunch more air into the system. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
Paulbeard Samba Member
Posted: Sat Sep 23, 2017 3:43 pm Post subject: Re: Fastest way to bleed a van with a new radiator |
Is that's what the starting three times should address, pushing all the air out the bleed valve? That was how I read it. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4800 Location: Bemidji, MN
Posted: Sat Sep 23, 2017 4:33 pm Post subject: Re: Fastest way to bleed a van with a new radiator |
i use a 12v water pump pushing in coolant thru the rad cap nipple. works great to force the air out while still adding coolant.
-dan |
furrylittleotter Samba Member
Joined: May 19, 2008 Posts: 1506 Location: West Seattle
Posted: Sun Sep 24, 2017 3:21 pm Post subject: Re: Fastest way to bleed a van with a new radiator |
I just turn the van upside down and fill into the drain plug.
Neil2 |
Posted: Mon Sep 25, 2017 11:58 am Post subject: Re: Fastest way to bleed a van with a new radiator |
Paulbeard wrote: |
Is that's what the starting three times should address, pushing all the air out the bleed valve? That was how I read it. |
This is for a Subi conversion but I did it on a stock engine.
Why 3 time, to not empty the EX tank and put air back in the system.
Also I should state that this was an "empty coolant wise" van.
Ben _________________ Working with rust, grease, dirt and dust is a sad truth.
